gscace wrote:For our use - folks using commercial gear in a light duty environment, temperature issues are pretty much moot.
gscace wrote: Grinder housings are aluminum, which has a pretty high thermal coefficient of expansion. Depending on the design, it's entirely possible that burrs move relative to each other quite a bit when temperature changes. This would be due to motors being mounted in one part of the housing (near the bottom), while the upper burrs are a spaced quite a distance away, usually threaded into the top. Thermal expansion in grinders using a conical burrset is likely to be less of a problem than for flat-burr grinders for the reason that Nick presents.
Greg, I'm not sure how these two statements fit together, but I'm intrigued with your idea that moderate temperature changes might cause the grind setting to change more in some grinders than in others. Because I like to put numbers to things when possible, here's a little chart that takes a SWAG (scientific wild-ass guess) at comparing how the temperature of the grinding chamber is affected by grinding one 13 gram dose in a Mazzer Mini and in a 3-phase Robur.
This chart is partially based on the ideas that I struggled with
here and
here, which involve a lot of speculation. But I suspect it is
somewhere in the ballpark. It summarizes variables like how much energy is consumed, how much is converted into heat, how much is absorbed by the grind chamber, the mass of the grind chamber, and the material characteristics of the grind chamber.
The gist of it is in the last column:
grinding a single small dose in the Mini potentially heats up the grinding chamber four or five degrees F more than it would in the Robur.Please feel free to critique (or savage
) this analysis.
RapidCoffee wrote:Based on temperature data taken in the chutes of the Mazzer Kony vs. SJ grinders, there was no compelling reason to believe that temperature plays a major role in grind quality, at least not for these grinders under typical home conditions.
RapidCoffee wrote:One more piece of speculation here, and then I'm done: coffee beans are subjected to high temperatures (400-500F) for long periods of time (many minutes) during the roasting process. Unless the beans are heated to much higher temperatures during the much shorter grinding process, this argues against heat being a major factor. Grind particle properties (size, shape) are more likely to play a significant role in determining pour characteristics, especially when evaluating grinder forgiveness (not taste).
John, I'm not saying that temperature plays a major role in grind
quality. But it is possible that, as Greg says, temperature plays a role in grind
adjustment. And it is also possible that grind chamber temperature plays a role in drying out the partially ground dose that sits in the grinder between shots. Both of these mechanisms might help explain why the bigger grinders seem to need less frequent adjustments than the smaller grinders.
I think you'll agree that comparing the cutting surface length of conical grinders vs. planar grinders may explain differences in grind quality, but does not explain differences in grind repeatability.
Also, you make a good point that any inadvertent "heat treatment" in the grinder pales compared to what the coffee has already experienced in the roasting process. But in roasting, the beans are whole. There is a HUGE difference between what happens with whole beans (miniature pressure capsules) and with ground beans (finely subdivided with cellular structure partially destroyed). I bet if we compared the result of roasting whole beans vs finely ground green beans using the same input temperature profile, the differences would be profound. It is similar to the shelf life comparison of whole roasted beans (10-14 days) vs ground roasted beans (10-60 minutes?)
