The results are interesting, to say the least, since I didn't get what I expected. When I did these experiments on the Versalab M3, lower doses in the same basket led to higher rates of solids extraction. In the LM triple basket, a 12 gram dose extracted at around 24%, while a 19.5 gram dose extracted at around 16%. Andy did a set of observations using the Mazzer Mini, and got similar results.
Here they are. Each grinder has a pair of rows, the first for the Ambrosia, the second for Red Line. There are three data columns for the doses of 12 grams, 15.7 grams, and 19.5 grams. The figure in the chart with the percent sign is the solids extraction, the figue in brackets my overall rating of the shot using the 0 to 6 WBC scale. I prefer the taste of Red Line to Ambrosia, but this is mostly subjective, since I tend to prefer livelier, lightly roasted espresso.
- Table:
TITAN GRINDER SOLIDS EXTRACTION
Grinder Blend 12.0gr dose 15.7gr dose 19.5gr dose
Small Macap Ambrosia 26.3% (2.3) 24.2% (3.0) 21.8% (2.3)
Small Macap Red Line 23.5% (3.5) 23.3% (3.5) 23.6% (3.2)
Big Macap Ambrosia 26.3% (3.0) 22.3% (2.7) 22.3% (2.7)
Big Macap Red Line 26.1% (3.5) 22.0% (3.3) 21.5% (3.5)
Robur Ambrosia 22.9% (2.0) 22.3% (3.0) 22.3% (3.0)
Robur Red Line 22.7% (2.3) 22.0% (3.5) 24.2% (3.2)
The big news is that these grinders do not under-extract at any dose. There is a slight drop off in the smaller Macap, but not nearly what we saw with the regular sized grinders. In regards to dose. my preferences are consistent between the two blends, I like one dose on each grinder a bit more than the others. However, it doesn't seem to have anything to do with solids extraction.
If this result remains consistent, it could explain the move to large burr grinders, or perhaps large conical ones, since one doesn't have to worry about under-extracting at higher doses. However, I'll need to collect more data before this is reasonably certain.
