Titan Grinder Project: Can it Beat the Mazzer Robur?
Behind the scenes of the site's upcoming equipment reviews.
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by another_jim on Fri Jul 20, 2007 11:55 am
And now for the Entertainment Portion of this Review:
The Robur is the biggest, baddest mother of all grinders. With a boatload of grinders coming through my place, why not put them in the ring with the heavyweight champ and see how they fare?
The ring in this case is two identically set up, PIDed and OPVed Silvias, pulling a home roasted blend of Biloya, Ismaili, Yellow Bourbon, Cenaproc, and Aged Sumatra. Each day, the contender and the Robur will go four rounds, twice at 16.5 gram doses, twice at 13.5 gram doses. I'll shuffle the baskets, taste blind, and score the shots relative to each other, -3 to +3, on crema appearance, crema depth, flavor and body. 0 is a tie, 1 is slightly better, 2 is distinctly better, 3 is a knockout.
Here's the fight schedule so far, look for the Mazzer Super Jolly and Kony also to throw their hats into the ring:
20th - Nemox Lux
21st - Mazzer Mini
22nd - Versalab M3
23rd - Macap MXK
24th - Macap M7K
25th - Fiorenzato Doge Conico
26th - Compak K-10 WBC
27th - Cimbali Max
another_jim
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by peacecup on Fri Jul 20, 2007 2:55 pm
Jim,
Why not put a super-featherweight Zassenhaus or equivalent-quality hand grinder in the ring? We all remember David and Goliath...
PC
LMWDP #049
peacecup
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by another_jim on Fri Jul 20, 2007 4:39 pm
peacecup wrote:Jim,
PC
Send me one and I'll run it.
another_jim
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by another_jim on Fri Jul 20, 2007 5:07 pm
Tale of the Tape
Not much to look at, the Lux, along with the same burr toting Ascaso I-2 and Pavoni PG, is the least expensive grinder that works properly for commercial espresso machines. Most people who've owned one of these have upgraded. They are a PITA to use -- they sound like a jalopy about to explode, they produce a hard clumpy grind that needs a full beauty salon WDT fluffing to pull properly.
But nobody has ever complained about the shots these grinders produce. In fact, in terms of the extraction numbers, the Lux was the grinder that was closest in performance to the Robur. So will lightning strike? Can this little grinder knock out the Robur?
The Fight
(color commentary added later, the shots were blind tasted)
Round 1 -- 16.5 gram dose: The Lux poured well, the Robur was a bit loose. Nevertheless it had a slightly better crema appearance. The shots were equally good in flavor and body, although the Robur's was a hint more acidic. Robur squeaks a 1 point win.
Round 2 -- 16.5 gram dose: Both poured well. The Robur had a slightly thicker layer of crema. It's shot was also sweeter and slightly better flavored. With flavor and body points getting multiplied by 4, it wins the round comfortably by 7 points.
Round 3 -- 13.5 gram dose: The Lux poured a bit loose, the Robur tight. The Robur had a slightly deeper and distinctly better looking crema. But then came the shocker, the Lux tasted distinctly better, it was sweeter, and the Robur shot was excessively bitter. The Lux wins by 5 points. Is an upset in the air?
Round 4 -- 13.5 grams dose: Both shots pour well, and the crema and taste are identical, but the Robur lands a body punch, with a buttery mouthfeel and wins the round by 4 points.
Final result: The Robur takes 3 rounds of 4, but wins by only a narrow overall margin of 7 points (out of a possible 120)
Detailed Scores
Table:
Grinder  Dose  Shot ExtG  ExtR  CPer  CApp  Flav  Body  Swee  Acid  Bitr  Total
Lux      16.5  1.2   20.8  21.4   0    -1     0     0      0    -1     1    -1
Lux      16.5  1.1   21.4  22.0  -1     0    -1.5   0     -1     0     1    -7
Lux      13.5  2.0   18.9  20.6  -1    -2     2     0      1     0    -2     5
Lux      13.5  1.1   20.6  21.9   0     0     0    -1      0     0     0    -4
Legend:
Shot: 0 is tight, 1 is good, 2 is loose, first figure is the test grinder, second the Robur. All shots run to 50mL with crema. If the time difference is more than 6 seconds, the test is redone. Tight/Loose mean differences of 4 to 5 seconds.
ExtG, ExtR: Percentage solubles extracted, G is the test grinder, R the robur
CPer, CApp: Crema persistence and appearance. Negative scores means the Robur wins, Positive means the Test grinder. These scores are added to the final tally
Flav, Bod: Flavor and Body. These scores are multiplied by four for the final tally.
Swee, Acid, Bitr: Sweetness, Acidity Bitterness: organoleptic categories NOT added to the score.
Total: The total score, CPer + CApp + 4*Flav + 4*Body
Will the Mini do better? Same time, same station, tomorrow.
another_jim
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by another_jim on Sat Jul 21, 2007 6:15 pm
Tale of the Tape
As Dan said when introducing the Titan Grinder Project, in many ways the whole thing is about the Mazzer Mini. It is the grinder of choice for most espresso amateurs. As the smallest sized commercial grinder, designed for catering, hotels, or decaf grinding, it is a sensible choice for the home. It is bullet proof reliable, serviceable, and not too big for the kitchen. The titan grinders being tested here, designed as main line grinders for multigroup machines in busy espresso bars, are not particularly sensible choices for home grinding. It is the prospect of finding a grinder that is distinctly better tasting than the Mini that's tempting enthusiasts.
Going from the Lux to the Mini was a quick lesson in why people want commercial gear for their home use. The Lux, despite its stellar performance in the taste department, is a complete PITA to use, whereas the Mini is a delight. The grinds are ready to use out of the doser, no sifting required, it operates silently, and relatively quickly. Obviously, the Robur is even quicker, and the grinds are even fluffier, the noise level is about the same. But the ergonomic improvement from Mini to Robur is a tiny step, whereas from the Lux to the Mini it is a monster journey. There is no need to upgrade if ergonomics is what you are looking for.
The Fight
This time there was no excitement at all. The Robur edged the Mini slightly in taste (1 point) in every round. The Robur's shots were a hair more aromatic, sweeter, and acidic (adding transparency and flavor) each time. The difference was slight even when going back and forth between the two shots; it would not have been detectable if one were tasting the shots separately. There were some crema points one way or the other, but the overall score was -15 to the Mini.
Detailed Scores
Table:
Mini     16.5  1.1   22.0  20.2   0     1    -1     0     -0.5  -0.5   0.5  -3
Mini     16.5  1.1   23.9  22.6   1     0    -1     0     -0.5  -0.5   0.5  -3
Mini     13.5  1.1   21.3  21.3   0    -1    -1     0      1    -1     0    -5
Mini     13.5  1.1   20.6  22.8   0     0    -1     0      0    -1     0    -4
Legend:
Running Score Sheet
This is a new section. The Robur is not just the fairground strongman taking on all comers. It is so consistent in its performance that it can be considered a measuring instrument for comparing grinders. So here's the tally so far:
Table:
Nemox Lux         -7
Mazzer Mini      -15
The Lux, at it's best, can produce a better cup than the Mini at its best. I still wouldn't want it, or any of the other current grinders using this burr set, as my home grinder, since it's such a PITA. But manufacturers should look at it in terms of using that burr set made by Trespade, mount and motor to produce a more ergonomic grinder.
Tomorrow, the Versalab.
another_jim
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by another_jim on Sun Jul 22, 2007 9:11 pm
Tale of the Tape
The Versalab M3 was built to be the ultimate grinder for home espresso enthusiasts. It costs as much as a Titan, but is optimized for generalized home use. The coffee drops straight through, and none is retained in the grind chamber. The grind wheel is easy to move from Turkish to Presspot, and is ultra fine adjustable to boot. It uses the legendary DRM Conical/Planar burr set which tops even the Robur for the size of its grind surfaces. A quiet DC motor allows for variable speed control. In terms of usability, there is no better cupping or all round lab grinder available. For espresso only use with limited blends, the design is not optimal.
Unfortunately, Versalab is more a design than manufacturing company, and this shows on the grinder's nitty gritty production engineering details. The drive system -- belt, drive shaft couplings, and bearings -- are undersized and failure prone. The company is unable to respond effectively to these problems. The belt tends to slip, as does the grind setting lock. All this means that around 10% of the time the grinds are unusable.
The raison d'etre of this grinder is great taste. The designer, John Bicht, claims it is analogous to an audiophile Hi-Fi system, bringing greater transparence and clarity to the cup. Does it fulfill this claim?
The Fight
The first thing that stood out was that the crema from the Robur was better in each round. The Robur tends to beat all grinders in this department, but in this case it was more marked than with the Lux and Mini. The Robur took a point on crema in each of the first three rounds.
The first round, at 16.5 grams, went to the Versalab on taste by 1 point. The M3's taste was a little more distinct, especially in reproducing the sherry notes of the aged sumatra in the blend. The second round went to the Versalab on body. In the third round, at 13.5 grams, the Versalab was a little too sweet and flat, and the Robur took the flavor category by a point.
So going into the final round, the grinders were even, and the claims of the Versalab were looking good. But in the final round, the sloppy production engineering came back to haunt it. Today was a "bad pour day" in my kitchen, and I had to adjust the grind settings, and burn through a lot of coffee in each round of the fight. Even with this, the pours were running slightly fast or slow in each round. The Silvia is an unforgiving machine, and the blend I put together is even more so -- if the pour is off, the loser will get clipped by 8 to 10 points. In the final round, despite having loosened the grind immediately before hand, the M3 produced a 5 seconds tight shot -- the inherent variability and slippages in the drive system had produced one of those inconsistent grinds. I decided to score it, since I'd given the grinder more tweaking than even the Lux up to this point. That ended its run, it got clobbered on crema and strongly beaten on taste, losing the round, and the contest, by 10.5 points. To its credit, it tied the Robur in the number of rounds it won.
Detailed Score
Table:
VL M3    16.5  0.2   17.7  22.6   0    -1     1     0      0     0     0.5   3
VL M3    16.5  1.2   20.2  20.2   0    -1     0     0.5    0     0     0     1
VL M3    13.5  0.1   18.3  22.1   0    -1    -1     0      1    -1    -1    -5
VL M3    13.5  0.2   18.3   NA   -1.5  -2    -1.5   0      0    -1    -2    -9.5
Legend:
Running Score Sheet
Table:
Grinder          Score       Rounds Won-Tied-Lost
Nemox Lux         -7              1-0-3
Mazzer Mini      -15              0-0-4
Versalab M3      -10.5            2-0-2
Tomorrow, the first of the Titans, the Macap MXK
another_jim
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by luca on Mon Jul 23, 2007 7:54 am
Great work as always, Jim. You're just making me want that Robur more and more. Apparently mazzer are working on a doserless one.
Nice to see some good data to show that the lux is good value. Personally, I can't stand the lack of stepless adjustment on it, but it seems to be a great little grinder. I got to try out an Ascaso i2 mini on the weekend ... essentially the same grinder, but with stepless grind adjustment. Seemed a little quieter, too - a definite winner.
I'd like to ask for a small favour, though - could you post up the actual tasting results? My school of thought is that you optimise taste and body, then worry about crema, so I'd like to see how the grinders compare without crema as a criterion.
Cheers,
Luca
luca
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by another_jim on Mon Jul 23, 2007 11:12 am
luca wrote:Nice to see some good data to show that the lux is good value. Personally, I can't stand the lack of stepless adjustment on it, but it seems to be a great little grinder. I got to try out an Ascaso i2 mini on the weekend ... essentially the same grinder, but with stepless grind adjustment. Seemed a little quieter, too - a definite winner.
The Lux is the least well finished of these Trespade grinders, but the step size is just about adequate. The switch from 13.5 to 16.5 grams took three notches, so I think a notch correction on a bad pour will usually be about right.
Done. It's edited into each "contest" post. There's extraneous information, since I was hoping to have an analytically worthwhile dataset when I'm done.
another_jim
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by another_jim on Mon Jul 23, 2007 6:45 pm
Tale of the Tape
68mm conical grinders have been around a long time, and every grinder manufacturer makes a model. These are rated at the same pounds per hour capacity as the ubiquitous 64mm flat burr grinders (like the Jolly). They are more expensive, but some cafes prefer them for their longer burr life and cooler operation. 62mm conicals are something new, and there are only two models, the Kony and Macap. These are rated at about the same grinding speed as 50mm - 60mm flat burr catering grinders (like the Mini), and have a size somewhat more suitable for home use than the regular size commercial conicals. For commercial use, they are too slow except as decaf grinders. The Macap MXK is, like all Macaps, built for economy; in this case as a competitor to the Mazzer Kony. But while the exterior may not be as fine as the Kony's, there's no skimping on the innards, which are solid.
The testing today was a breeze and a joy. Both grinders poured perfect each time, and the two pours looked like a synchronized swimming team. I turned on the machines simultaneously, 7 seconds later the pours clicked on and stayed rock steady till the end. There was no need to send the grinds to the WDT beauty parlor, since they emerge ready to use from the doser. The round with the Mini was close to this, but this is the first time where I feel I could reproduce the same results ad infinitum: both grinders were that rock solid consistent. I feel very comfortable saying that with this pair what I saw is exactly what any buyer will see.
Not surprisingly, I liked the MXK's ergonomics: the grinder is quiet, the chute is very wide and easy to clean, and the doser clears out as well as most. My only niggle is that the clackety-clack of the Macap dosers is too loud.
The Fight
The two 13.5 gram rounds came first. In the first round, the Macap surprised me with an intense shot that was balanced perfectly enough to beat the Robur's sweeter, laid back one. Score 4 points for the Macap. In the second round the extra intensity backfired; the Macap's shot was slightly unbalanced towards the bitter, and the Robur took the round by 1.5 points. The first 16.5 gram round was a repeat of the first 13.5, the Macap was more intense, and balanced enough to pull it off and win by 3 points. In the last round, the tables were turned, and the Macap's shot was a hair flatter, losing by 2.5 points.
Yes folks, we have our first Robur beater: the Macap MXK splits the rounds, but squeaks by with a 3 point win. In all fairness, the subjective element looms large here: the losing Robur shots were mellower and sweeter, but I thought the nigh perfect balance of the Macap shots more than compensated.
There is something immensely solid and consistent about the way shots from the Robur taste; this is not just a psychological carryover from the size of the grinder itself, but is totally apparent in the accumulated blind tasting. If this is what you want, you are probably not going to find anything cheaper that delivers it. But this cup profile has a built in margin of safety (although not as much as the Mini's), and it can be beaten by grinders that reproduce the flavors more cleanly and closer to the edge.
Obviously, grinders walking this tightrope aren't going to pull it off each time; but the MXK is a big league grinder, and works consistently enough to be this "edgy" and remain consistent. The Versalab, yesterday, also won rounds with clearer, more finely delineated tastes; but it didn't back this up with the consistency required to walk the tight rope of intense, perfectly balanced shots; so when it lost, it lost big. The Macap MXK does have the required consistency, it won its rounds clearly, and when it lost, it was by a hair. It impressed me in the previous tests, and this one seals the deal. It gets my first, big thumbs up, "you can buy it with confidence" recommendation, especially for people who want to get very clean and crisp tasting shots, while never having to run to the nearest sink to gargle. The Versalab promises consistent clean taste; the Macap delivered in the direst of test conditions, up against the Robur.
Detailed Scores
Table:
MXK      16.5  1.1   20.8  21.4   0.5   0.5   1    -0.5   -0.5   1     1     3
MXK      16.5  1.1   22.0  20.8  -0.5   0    -0.5   0      0.5  -1    -1    -2.5
MXK      13.5  1.1   20.6  21.3   0     0     1     0      0     1     1     4
MXK      13.5  1.1   22.8  22.8   0.5   0    -0.5   0     -1     0     2    -1.5
Legend:
Running Score Sheet
Table:
Nemox Lux         -7              1-0-3
Macap MXK         +3              2-0-2
Tomorrow, the MXK's big brother, the Macap M7KR.
another_jim
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by RapidCoffee on Tue Jul 24, 2007 12:39 am
another_jim wrote:Yes folks, we have our first Robur beater: the Macap MXK splits the rounds, but squeaks by with a 3 point win. In all fairness, the subjective element looms large here: the losing Robur shots were mellower and sweeter, but I thought the nigh perfect balance of the Macap shots more than compensated.
Jim, thanks for your fine work. But I'm going to post a dissenting opinion. In my three weeks with these two Titans, I thought the Robur produced consistently better shots than the Macap MXK*. My reaction to the Macap was similar to Dave's reaction to the Kony: harsher, edgier pours that highlighted individual flavors, but were less balanced, and overall less pleasant to the palate. I clearly preferred the Robur.
From a private Titan grinder thread, at the start of June:
RapidCoffee wrote:A confession: I'm trying to be fair and rational about my evaluation, but it's been tough. The Robur is a strong contender for best espresso grinder on the planet. :shock: The Macap is a very good grinder, nice ergonomics, and a much better fit for the home user... but you know what? Conicals shmonicals, it's not exactly knocking my socks off. Maybe I just prefer Mazzers.
But take this with a grain of salt. For one thing, Jim is undoubtedly a far better cupper than me. For another, we may simply have different taste preferences.
* I'm pretty sure the "small Macap" is the MXK model, with 63mm burrs.
John
RapidCoffee
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by another_jim on Tue Jul 24, 2007 1:06 am
RapidCoffee wrote:But take this with a grain of salt. For one thing, Jim is undoubtedly a far better cupper than me. For another, we may simply have different taste preferences.
In the review, we'll get all the boilerplate stuff right, I hope; for the thread, I'm going off memory (in the fond hope that there's not some knockoff MXK out there that somebody might buy).
As I said, in this round, all eight shots poured perfectly, and all eight would have had ratings of 3.5 to 4.5 in competiton (the Silvia won't make it to 5 unless lightning strikes; I was sorry I hadn't pulled some of these on the Semi). So my giving the nod to the MXK is partly subjective, and part that my blending and roasting style have adapted to using the M3, which is a similarly bright grinder. The blends key components are the Biloya for acidity, the Aged Sumatra for bright bitters, the Cenaproc for sweetness and caramels, with the Ismaili and Brazil doing the chocolate and kola nut back beat. The balance I'm looking for in the tests, is that between the three front ingredients. The Robur tends to emphasize the sweetness and the two background components (although not as much as the Mini, from which the blend tasted slightlly flat and comfort food-ish); this is the Robur's vulnerability, where a slightly brighter grinder can beat it, if it produces perfectly balanced shots.
Dave and you are set up around the SJ, which sounds as bass dominant a grinder as the Mini. To you, the MXK would tend to taste too bright for your regular blends and pulling technique.
another_jim
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by another_jim on Tue Jul 24, 2007 10:04 pm
Tale of the Tape
We are now entering the true titanomachia. The Kony and MXK are the conical equivalents of the Mazzer Mini, that is, decaf or catering conicals. The 68mm conicals, like this Macap M7K, are grinders built to service three and four group bar machines. The grind speed is about the same as the Robur's, that is, ridiculously fast for home use, with a double being done in 5 or so seconds.
The Macap is not as tall or heavy as the Robur, and has the lightest motor of the 68mm grinders, only 350 watts, same as the MXK's according to the faceplate. However, it runs louder than the MXK, especially at startup, and is larger than the Super Jolly or other 64mm flat grinders, since it is housed in an enclosure roughly the same height as the Mazzer Major or Macap's large flat burr machines. Despite this, the usability of this grinder is as good as the MXKs. The version I'm testing has click stops for the grind adjustment, rather than a worm gear. Given the much wider travel required to set conical grinders, this does not impact the ability to set the grind to the exact pour one wants. As with all Macaps, worm gear versions are available.
Just as yesterday, the testing was a breeze. These grinders operate ultra-consistently. Three pours had completely identical pour times, in the fourth, they were 3 seconds apart.
The Fight
These may be top Italian grinders, but they may as well have been 1980s Italian soccer teams for all the excitement this match generated. The shots looked and tasted identical, and in order to generate any scores at all, I had to get really picky. Based on this, I gave two rounds to the Robur, and one to the Macap. In the final round, nothing I tried yielded any sort of difference between the two shots. Other grinders got close in scoring to the Robur, but this is the first time where the entire taste experience was well nigh indistinguishable. These grinders are on exactly the same page when it comes to taste profile. My score sheet gives the Robur a 3 point, and 2 to 1 round edge, but trust me, nobody will ever tell these grinders apart under normal tasting conditions.
I have to admit I'm not enamored by the M7K's style: it's big without being imposing, and it starts up noisy. But if you want the consistency and taste profile of a Robur, and are on a budget, this one is definitely worth a very long look.
Detailed Score
Table:
M7K      16.5  2.1   21.4 22.0    0     0    -0.5   0     -1     0.5   0    -2
M7K      16.5  1.1   21.4 22.6    0     1     0.5  -0.5    0     0.5   0     1
M7K      13.5  1.1   21.3 22.1    0     0    -0.5   0      0    -0.5  -0.5  -2
M7K      13.5  1.1   20.6 21.3    0     0     0     0      0     0     0     0
Legend:
Running Score Sheet
Table:
Nemox Lux         -7              1-0-3
Macap MXK         +3              2-0-2
Macap M7K         -3              1-1-2
Tomorrow, the Fiorenzato Doge Conico
another_jim
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by luca on Wed Jul 25, 2007 9:20 am
Sweet, thanks for adding those scores, Jim. Interesting that you're not seeing bigger separations between the grinders.
luca
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by another_jim on Wed Jul 25, 2007 11:38 am
luca wrote:Sweet, thanks for adding those scores, Jim. Interesting that you're not seeing bigger separations between the grinders.
All the grinders being tested have reputations for making excellent espresso, which turn out to be deserved. Also, the scale I'm using, based on the steps in Barista competition, makes a point a distinct difference, 2 points a large difference, and 3 points a whopper. In retrospect, I should have used a finer scale, since I'm rarely seeing more than 1/2 point differences.
The Titans are distinguishing themselves slightly on grind quality, but more on the intangibles -- they are rock solid consistent and steady. At this point my jaw would drop if I got a sink shot from any of them. When Intelly switched from the LM Swifts to the Robur, because they found the Roburs more consistent, I didn't see how this was possible -- how could a conventional dosing grinder be more consistent than something that dosed and tamped automatically? Now I understand. I've never used the large 64mm or 72mm flat burr grinders, so I don't know if this shot making reliability is something they also have.
My leg of the testing is mostly about gauging differences in shot and taste quality, and not so much ergonomics or consistency. My shot making practice is too improvisational for me to be a good judge of these. But in some sense, this leg has been a dud, since the taste differences are so minor. I'm guessing the final review will focus more on the process of using the grinders, where most of the differences lie.
another_jim
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by another_jim on Wed Jul 25, 2007 5:17 pm
Tale of the Tape
There's a lot of Italian grinder companies whose name you probably don't know despite seeing their grinders in cafes every day. Companies like Bregant, Casadio, or Eureka mostly produce grinders that are badged and sold by espresso machine manufacturers. Fiorenzato was a grinder company in this style until they started producing their own line of machines; now they market their grinders under their own name. The Doge Conico is their flagship grinder, a 68mm conical with a 500 watt (2/3 HP) motor. This is a very impressive grinder. The case is as well finished as the Mazzers, the doser is perhaps the best and cleanest I've used, and the burr carrier is beautiful -- a springloaded, floating system, like the Mazzer, that is made of polished brass, and which, unlike the Mazzers, turns easily and smoothly. My only caveat is that it lacks a motor starter, and there's about 2 seconds of loud clatter when the motor starts.
The Fight
Another Italian soccer match. The cup profile of the Fiorenzato is indistinguishable from the Robur's, and I was grasping at the least hint of difference to score the rounds. The Robur took two on flavor, since there was a hint of astringency to the Fiorenzato shots. For all I know, this is due to the grinder not having been used much during this testing process, and the burrs still being unseasoned. In any case, the Robur took two rounds and the match by half a point, the Fiorenzato took one round. One round was a tie, with indistinguishable shots.
Based on the performance of the Fiorenzato today, and the big Macap yesterday, the buzz surrounding the Robur appears to me to be slightly undeserved. These two big 68mm conicals perform just as fast and just as well; and the same probably applies to the versions produced by other grinder manufacturers. The 3 phase Robur may edge them out, but all these conicals come in 3 phase versions, so even that may be a wash.
Detailed Scores
Table:
Doge     16.5  1.1   22.0 23.2    1     0    -0.5   0      0     0     1    -1
Doge     16.5  1.1   21.4 21.4    0     0    -0.5   0      0     0     0    -2
Doge     13.5  1.1   21.3 19.1    0     0.5   0     0.5    0     0     0     2.5
Doge     13.5  0.1   20.6 19.8    0     0     0     0     -1     1     0.5   0
Legend:
Running Score Sheet
Table:
Nemox Lux         -7              1-0-3
Macap MXK         +3              2-0-2
Macap M7K          -3              1-1-2
Fiorenzato Doge   -0.5            1-1-2
another_jim
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by cannonfodder on Wed Jul 25, 2007 9:58 pm
another_jim wrote:The Robur took two on flavor, since there was a hint of astringency to the Fiorenzato shots. For all I know, this is due to the grinder not having been used much during this testing process, and the burrs still being unseasoned.
I wonder if this could explain the less than stellar cup I got from the Kony. Could the harsh/bitter experience I had be due to grinder break-in? I tried to run a lot of coffee through the grinder to break it in and season the burrs. I ran somewhere around 8-10 pounds of coffee through the Super Jolly and Kony. More than half of that was run through the Kony. I would guess 6-8 pounds.
cannonfodder
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by RapidCoffee on Wed Jul 25, 2007 10:15 pm
cannonfodder wrote:I wonder if this could explain the less than stellar cup I got from the Kony. Could the harsh/bitter experience I had be due to grinder break-in? I tried to run a lot of coffee through the grinder to break it in and season the burrs. I ran somewhere around 8-10 pounds of coffee through the Super Jolly and Kony. More than half of that was run through the Kony. I would guess 6-8 pounds.
I wondered the same thing about the Macap MXK, especially after Dan mentioned a similar break-in experience. I got the Macap new, and only ran 2-3# through it. Why would a grinder need more than a few seasoning shots to grind optimally? I dunno. Maybe the burrs need time to seat properly.
John
RapidCoffee
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by another_jim on Wed Jul 25, 2007 10:38 pm
I was ready to hit the supermarket for a big bag of Stewarts (a local mass market coffee with no objectionable taste) to run through the grinder if there was anything obvious. What I got was so subtle, I didn't know what to make of it -- the barest hint in the initial hit of the coffee on the tongue. After that, it was all the same. There was no point in even taking a second taste, whatever the difference, it was well below my threshold of tastebud fatigue, and the second sips tasted totally the same.
I should have explained this for the last two tests of the Doge and the M7K -- the half point differences mean I can't taste them on the second sip, so that they are frustrating, like seeing something out of the corner of ones eye, but not when looking at it full on.
another_jim
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by Paul_Pratt on Thu Jul 26, 2007 5:18 am
Hi Jim,
So glad to see that you gave the Lux a decent score. I use an Isomac branded one with a 1 group machine and the shots are great. Sure the build quality isn't the best and the adjustment pin is so flimsy it's ridiculous and the noise, arghh the screaching noise of the motor is enough to have the neighbours cats thinking they are in for a bit of action...
But it does grind extremely well and produce great coffee. It's important for people to keep an open mind and not believe great espresso can only come from the best equipment money can buy.
Paul
Paul_Pratt
Link to "Titan Grinder Project: Can it Beat the Mazzer Robur?"by another_jim on Thu Jul 26, 2007 1:43 pm
Some book keeping on the scores:
I can't help noticing that my scoring criteria have changed ever since I started testing the large conicals against the Robur. I've become much more picky, and have been awarding half points in flavor at the barest hint of a taste difference. In previous rounds, I'd have scored these even. The half points in previous rounds would have been full points in these.
I hate to do post-hoc revisions; but in order to keep the scoring comparable, I must revise the scores of the first three grinders. I've added a half point to the flavor category whenever the winning margin is 0.5 and 1 point (the higher scores are unaffected).
There's an additional reason for doing this. People are curious how their regular home grinders would fare, so I'm getting in a Rocky and a Zassenhaus, two popular home grinders after the rounds with the Titans are done. I'll be scoring them on the revised scale, so the earlier grinders need to be corrected to keep the comparisons of the domestic grinders on the same page.
another_jim
Next
Return to The Bench
