another_jim wrote:
0. Throw your stopwatch away
1. Stop your shot by the color of the flow.
This drill remains the same for any shot temperature, pressure or dose.
Psyd wrote:F'rinstance, if I were to pull a straight shot that starts to blonde at twenty-six seconds from the time I start the pump, how long does the same shot take to blonde from pump start after the six second pre-infusion?
another_jim wrote:I don't know. I doubt anyone elses data will be good for your machine,
cannonfodder wrote:Don't over complicate the process, it is just espresso.
"For 1.5 ounces of espresso, the extraction should take between 23-30 seconds where the time starts when the espresso begins to flow from the spouts. To prepare excellent espresso, the pour should look like warm honey dripping from the spouts."
another_jim wrote:Here's the proper rule: 0. Throw your stopwatch away. 1. Stop your shot by the color of the flow.
HB wrote:Timing traditionally begins when the brew pressure is applied and the extraction lasts 20-30 seconds. Most commercial espresso machines have rotary pumps and they pressurize nearly instantaneously; the espresso beads on the bottom of the basket in barely 3 seconds. Most home espresso machines have vibe pumps and require 5-7 seconds before the first drops appear on the bottom of the basket. That may explain the differences you have read.
That said, once you get beyond the beginner stage, Jim's advice early in this thread is best:
AUSTINrob wrote:Understood. Well assuming I like the body, taste and look of my espresso, but I want more volume how do I do that? I imagine maybe a different OPV setting? (i've recently dialed it down from 10.5 to 9.5 bars).
Right now I am getting about 2 oz before my shot starts to blonde, and if I try grinding coarser to get more volume, the espresso gets to "thin". (my grind (MACAP), tamp (Auto 30# tamper), PID temperature are all constant)
HB wrote:That said, once you get beyond the beginner stage, Jim's advice early in this thread is best:
cafeIKE wrote:1 - No annoying beep. It's bloody annoying in a busy shop that uses timers to hear the incessant beep.
Psyd wrote:Does 'brew pressure' mean pre-infusion, too? I never got very clear on that in the earlier discussion.
To prepare a 'good' espresso is not an easy task. Many variables can affect the quality of the coffee, such as water pressure and temperature, the amount of ground coffee, how hard it is pressed and (not less important) the practice of the barman. Evidently some of these parameters cannot be controlled in a scientific way, but, for those that can, a few optimal conditions have been empirically determined:
water temperature: inside the machine it should be about 88°C;
pressure: it should be a function of time with profile as shown in Fig. 1;
quantity of coffee: 7 g;
duration: the whole process should take 30 seconds;
production: at the end, we should have about 25 ml of coffee in the cup.
micki wrote:88°C ? That's a bit low ...
