Bill and I have swapped some notes on the fact that it seemed like a good thing to add to our equipment. So I asked the counter guy at EPNW, he reached around the corner into the warehouse and asked a desk guy( sorry GUY- I was too busy talking to you I forgot your name) and he strongly cautioned against the practice. ( I was confirming temp on the model I was inquiring about)
He said:
If you put one on, and if the Pstat fails and hangs on. the OPV will most likely keep bleeding off steam and defeat the temp rise. That the temp to interrupt would not occur as "I was" planning.
He cautioned that it could give the false sense of security and that the only real way to protect against element overheat( boiler out of water etc) was to install a probe type thermostat that would be close enough to the element to react when indeed the water runs out and the area near the element finally gets upto the 265 degree range. I don't have the number of what he showed me but will add it shortly.
I was very clear , as was he- That he would not do the strap-on( no pun intended
Food for thought for those of us with machines that have one of a kind elements etc..
So what's the groups thoughts on this.. I am merely sharing this for discussion. I took his advice since he worked at a reputable service parts supplier/ that is a friend of this site/ Big supporter of us all / and did I mention the Promised land for stuff I need?
