I spot welded two K-wires to the bottom outside of my dog bowl (DB). The wires are welded directly to the stainless, around 1/8" apart, so the bowl is part of the junction. The setup included a mixing bowl "enclosure" for the DB, both to protect the t/c and reduce heat loss.
Hooked the t/c up to a Fluke 54 and roasted a cup of beans.
What I observed on the thermometer really surprised me. Simply moving the heat gun (HG) a little closer or further away, while manually stirring the bean mass, allows temperature control easily within +/-10F. With a little bit of concentration, I think it could be controlled within +/-5F.
The captured roast profile is not quite as smooth as what I see from my PID'd Poppery I, but it is a helluva lot easier to set up the HG/DB operation. And making game-time adjustments as the roast progresses is much easier than modifying a ramp-soak profile in a PID.
FWIW, I observed that first crack took place when the Fluke indicated approx. 415F. This is around 15F higher than I usually see in in the chimney of my P-I. Second crack was at around 455F, again around 15F higher.
Even though a quick Google and HB search did not turn up reports of similar adventures, I'm confident somebody has measured some roast temps using a HG / DB roaster.
I'd be interested to hear about those results, in particular any lessons learned regarding differences in roast profiles measured this way compared to hot air roasts where the sensor is located in the air discharge stream.
Jim
Thermocouple placement on bottom of DB
Close-up of thermocouple welds
Captured roast profile
