Temperature Stability . . . . from a Heat Exchanger
Link to "Temperature Stability . . . . from a Heat Exchanger"by Ken Fox on Tue Dec 27, 2005 10:00 pm
I am posting this both here and on alt.coffee because there are people I respect who participate in one venue or the other and I'd like to get opinions from all of them.
Having wasted about three whole days datalogging shots with the Scace Thermofilter on my Cimbali Juniors, I had nothing to show for it but a bunch of horrible looking graphs that were beginning to convince me that one could never get temperature stability out of a HEX machine and that the PID Jim Schulman and I put in (with some assistance from Barry Jarrett) a couple of years ago had accomplished nothing. I was getting ready to call my banker to see about a loan on a new LM GS3:-)
I've had a number of emails going back and forth with such local luminaries as Jim Schulman, Barry J., even Andy S., and I was getting ready to jump off the roof or hang myself in the closet. Jim kept saying I didn't have the flush down low enough, I should try 110ml, Barry said, hey, temperature stability, HEX, no can do, which was more or less what I inferred from my emails with Andy as well. I seemed to have my choice of good first shots but overheated seconds and thirds and so forth, or hot first shots followed by good later shots.
And then----- I got LUCKY. I started to do some datalogging while playing around with the boiler temperature and the flush volumes. And here is what I found: by reducing the boiler temperature to well below anything I've used before, 231F, which equates to about 0.6 bar on my front panel gauge, and markedly reducing the cooling flush down to 45ml (an ounce and a half, about a third of what I've used before), I struck PAYDIRT.
It would be nice to compare these results to what I can get on the same machine under pstat control, down at the same temperature range and with the same flush; I don't have time to do that now since I'm headed off on a trip soon, but I'll try to get to it in January. I don't think that pstat control can match these results, as the gentleness of the curves and the consistency of them would not easily be obtained with the ~6 degree hysteresis present in my boiler with the pstat calling the shots.
I think these results, which I have now duplicated in 3 separate series this afternoon, show that this works, and validates the approach of reducing HEX boiler temperature, reducing flush size, and replacing the Pressurestat with electronic temperature control. If anyone else out there has a PID'd HEX machine, it sure would be nice to see this duplicated on another type of machine.
Just a note about methodology before I post the links to the graphs: The idea was to start off from an idle period, which is the hardest for any sort of espresso machine as this tends to produce either overheated or cool groups depending on the machine. I pulled one thermofilter shot about 15-30 seconds after the small cooling flush, then waited 1min 30 seconds to pull the next one, and so forth. Although on my earlier testing I'd removed the Scace PF in between shots, I've been convinced by my own testing that this accomplishes nothing because the Thermofilter just measures the water as it flows through and any impact of the PF temperature (it is a chopped PF and the probe is far away from metal or other heat sinks) is eliminated after 1 second into the shot. Therefore, after the small cooling flush I returned the Scace device to the group and left it there throughout the 10 or 12 minutes it took to do each series. One other reason for doing this is that the basket they are using on the Thermofilter doesn't seal well with Cimbali group gaskets and once I have a good seal in there I don't want to risk a poor seal on later shots which would make it hard to trust the measured results.
Have a lookie at these graphs of shots, pulled as above, on a lowly Heat Exchanger machine:
ken
Ken Fox
Link to "Temperature Stability . . . . from a Heat Exchanger"by another_jim on Tue Dec 27, 2005 11:36 pm
(cross-posted on alt.coffee)
I had a chance to look at these before and was stunned and mute. With
a bit more thought, I have some thoughts, although they may be a bit
incoherent:
-- I'm guessing you've gotten close to converting your machine to a
single boiler. With the Cimbali one piece HX and group, and the group
acting as a heat sink; I'm guessing the HX stabilizes around 210F -
220F, and that with the cold inflow, you're basically getting shot
temperatures inside the HX all the time.
-- One question will be how well the steam works at this boiler
pressure. Home lever machines, like the Elektra, Pavoni, and
Micro-Cimbali operate at around this pressure. These are all very good
steamers, better than low end home HX machines. So, with the proper
steam tip, you may get good performance, albeit more slow.
-- The other question is what happens if you start nudging the boiler
pressure up and the flush amount along with it (adjusted to keep the
average temperatures of all the shots in each series roughly equal). Does the
stability get more ragged slowly? Or will it stay at this stability
level for a while, then go back to normal HX behavior.
-- In Italy, most bars keep steam pressures low, usually around 0.8
bar, and have HXs suited to that temperature. Dual boiler machines are
not even a blip there. Perhaps you are getting closer to the way these
machines were designed to perform.
-- Finally, there's always been a "Nah, no way" reaction to running
the steam boiler of an HX with a TC placed inside the HX. Your data
shows it may not be so farfetched after all.
another_jim
Link to "Temperature Stability . . . . from a Heat Exchanger"by lennoncs on Tue Dec 27, 2005 11:41 pm
Congratulations Ken!
You have found that "DPlot Religion"
nice looking graphs, I am going to ruminate on them a bit before I comment but it looks promising.
Cheers,
Sean
lennoncs
Link to "Temperature Stability . . . . from a Heat Exchanger"by Ken Fox on Wed Dec 28, 2005 12:18 am
another_jim wrote:(cross-posted on alt.coffee)
incoherent:
Hi Jim,
I'm eating dinner and in between courses running Scace/Fluke runs. I pushed the PID down to a boiler temp of 229 and ran two more sets, with (I think) EIGHT shots (or was it nine?) in the latter of the two sets, filling up my fluke. I just turned the temp down two degrees more, to 227; I think that varying the flush amount will just make this too complicated. It seems as if reducing the boiler temperature does not reduce the brew temp, degree for degree, but less than that. As to raising the temp, I'm already in the 202's with the graphs I already posted. Does anyone advocate brewing much above 203.5? I could go higher but I think it is pretty obvious that I could go up a degree without a problem and beyond that may be a second round of bean roasting rather than providing useful data:-) If this setup can do, say, 198-203 or thereabouts, I think that is most of the useful range.
As to steaming performance, you can hide all sorts of sins in milk. I think the response time is quick and one could just bump it up 2 or 3 or 5 degrees if one wanted to make cappas, leaving it at a lower level the rest of the time.
I'd give up a tiny amount of temperature stability not to have to fool around with 55ml vs. 40ml flushes and just standardizing on 45 for straight shots. Plus, it is pretty hard to measure 5 ml differences so I have programmed in the flush on one of the programmable buttons and just leaving it there.
Thanks for your input!
ken
Ken Fox
Link to "Temperature Stability . . . . from a Heat Exchanger"by Ken Fox on Wed Dec 28, 2005 12:20 am
lennoncs wrote:Congratulations Ken!
Cheers,
Sean
Thanks for your help, Sean! I think I"m onto something with this, and since I seldom am, it is a bit of a rush. If it wasn't so repeatable I'd have my doubts but when you see the same number for 15 seconds straight on the datalogger, it is hard to ignore.
Take care, I'll have more to post later.
ken
Ken Fox
Link to "Temperature Stability . . . . from a Heat Exchanger"by Ken Fox on Wed Dec 28, 2005 4:25 am
Some more shot temperature graphs at different boiler temperatures:
At 227F, the shot reproducibility is only fair and there is quite a spread between shots although not following any real trend:
and
228 was not (yet) tested and might well get the range of reproducible shot temps down to 200F
229F has nice reproducible shot temperature characteristics:
and
231F was shown in the original post at top.
232F has nice tight reproducible curves. I only did one series, but with 10 consecutive shots. One of the later shots lost a couple seconds of initial data when I forgot to push the datalogger button on time:-) this does not effect the important part of that curve so I included it in the plot:
It is obvious from viewing all the graphs I've posted that this technique, e.g. a low boiler temperature in a PID'd HEX boiler, with a very small initial flush, works well over a certain temperature range and less well when you get below it. This range appears to be from about 200F to 204F intended shot temperature. It would not surprise me if the new double boilers also have a certain range in which they can maintain stable and consistent shot temperatures and fail to maintain them at other intended shot temperatures. Has anyone subjected their dual boiler machine to this kind of testing?
ken
Ken Fox
Are HX machines the way to go?? Mebbe not!
Link to "Temperature Stability . . . . from a Heat Exchanger"by edna713 on Wed Dec 28, 2005 10:24 am
After slogging through the lengthy prose from Fox, who was testing shot temps between dinner courses, and is NOW calling his Cimbali jr. a lowly HX machine, I have a question:
WHY IS IT SO HARD TO GET CONSISTENT TEMPS FROM HX DESIGN MACHINES?? why all the fiddling and folderol?
Is an (expensive) HX espresso machine REALLY an upgrade??
Dave
edna713
Full Range of Data between 227F and 233F Boiler Temps
Link to "Temperature Stability . . . . from a Heat Exchanger"by Ken Fox on Wed Dec 28, 2005 2:22 pm
I've managed to waste a bunch more time datalogging my PID'd Cimbali D1, and found a range where I can get very tight temperature distributions (aka "flat shot profiles") with the current setup of low boiler temperatures and a small initial flush. Some of these temperatures (especially at the far ends) don't produce as tight a temperature distribution or reproducibility from shot to shot. Even in these cases, however, it appears that the first couple of shots are pretty consistent, just the reproducibility suffers after two or three shots. This could be a function of PID programming, flush volume (which I've kept constant for ease of use), or other factors I've not considered. This is not a perfect system by any means and although it offers a good deal of control in the desired shot temperature range of 200 to 204, it falters above and below that and doesn't offer intra-degree control. It may well be that even the new dual boiler machines have a range where they produce consistent temperature shots and a range where they are less reliable. This may be a design limitation in 2005 of trying to accomplish this degree of temperature control. It would be great if some users of GS3s, Synessos, LMs, Brewtus's, Technos, and others, who have access to a Scace Thermofilter and Datalogger, if they could run series like these and post their results. I must warn you, however, that this sort of stuff eats a LOT of time!
The data collection (shot) frequency was set at one shot per 2 minutes to approximate the work rate of a reasonably skilled home barista who takes the time to dose and distribute and tamp well enough to avoid channeling and other common pitfalls we know know we all commit in the era of the bottomless PF.
Here are the curves in ascending order from boiler temperatures of 227F to 233F:
227F:
228F:
229F:
230F:
231F
232F:
233F:
At their best, I think the demonstrated stability is probably about as good as the results I've seen posted from any other machine, but again, as set up this works best over only a certain range of shot temperatures. I made a cappuccino this morning at a boiler temp of 231F, and although the frothing was slow, copius microfoam was produced. I'd say the froth quality was better than I have been getting at higher boiler temps but it does obviously take a few seconds longer to get the job done. If I was making mostly milk drinks, where shot quality is less important, I'd bump the temperature up a few degrees and maybe go back to a larger flush. For straight shot making, however, low boiler temps and a smallish flush seem to produce the best results, at least on paper.
ken
Ken Fox
Re: Are HX machines the way to go?? Mebbe not!
Link to "Temperature Stability . . . . from a Heat Exchanger"by AndyS on Wed Dec 28, 2005 2:24 pm
edna713 wrote:After slogging through the lengthy prose from Fox, who was testing shot temps between dinner courses, and is NOW calling his Cimbali jr. a lowly HX machine, I have a question:
It's hard to get consistent temps from ANY espresso machine. Even a DAVE-PIDed Silvia!
If you get yourself a Scace device and do some testing, you will find this out for yourself.
-AndyS
AndyS
Link to "Temperature Stability . . . . from a Heat Exchanger"by Ken Fox on Wed Dec 28, 2005 3:20 pm
AndyS wrote:It's hard to get consistent temps from ANY espresso machine. Even a DAVE-PIDed Silvia!
Hi Andy,
You are among the most rigorous and conscientious "espresso-scientists" out there, and I really respect your judgement and your observations.
Could you tell us what if anything you have found on the idea of there being a "sweet spot," a certain band of temps that a machine might be able to pull flat curve shots at, and that the ability to do this declines as one gets to the fringes of this "band?" It seems only logical to me that you can only tune such a system (as an espresso machine) so well, and in the design the engineers would have to decide where they wanted the machine to be the most stable.
Any observations you have on this issue would be very interesting, at least to me.
ken
Ken Fox
Link to "Temperature Stability . . . . from a Heat Exchanger"by AndyS on Wed Dec 28, 2005 4:10 pm
Ken Fox wrote:You are among the most rigorous and conscientious "espresso-scientists" out there, and I really respect your judgement and your observations.
C'mon, Ken. Didn't your parents ever tell you that flattery will get you nowhere? :o
Ken Fox wrote:Could you tell us what if anything you have found on the idea of there being a "sweet spot," a certain band of temps that a machine might be able to pull flat curve shots at, and that the ability to do this declines as one gets to the fringes of this "band?" It seems only logical to me that you can only tune such a system (as an espresso machine) so well, and in the design the engineers would have to decide where they wanted the machine to be the most stable.
Sorry to tell you that I have no data on this. Certainly your point makes sense: the band of temps within which machines will exhibit good thermal performance cannot be unlimited....
-AndyS
AndyS
Link to "Temperature Stability . . . . from a Heat Exchanger"by Ken Fox on Wed Dec 28, 2005 4:23 pm
AndyS wrote:Sorry to tell you that I have no data on this. Certainly your point makes sense: the band of temps within which machines will exhibit good thermal performance cannot be unlimited....
I bet that Dr. Illy has read every single one of your posts
ken
Ken Fox
Link to "Temperature Stability . . . . from a Heat Exchanger"by Ken Fox on Mon Jan 02, 2006 4:49 pm
Cheers,
Sean
OK, Sean, you've had almost a week to ruminate on these graphs. Whaddya think?
ken
p.s. I don't regard these graphs as the limits of what can be done on this machine as the PID could be reprogrammed and shot and flush temperatures varied. It is just a start and I think it shows that a lot more can be gotten out of a HEX machinne, certainly THIS one, than had been previously assumed. Being as I am in California right now visiting my parents, I won't be able to do any further testing for more than a week.
Ken Fox
Link to "Temperature Stability . . . . from a Heat Exchanger"by MJ's Cafe on Sun Jan 08, 2006 12:47 am
I've been reading this site for a while now and need a good lie down as my head is swimming with pid's and hex's and the ramifications. I'm in Taiwan setting up an espresso bar and recently bought a Faema e92 elite due to considerations of service availability in Taiwan and not having a spare internal organ to sell in exchange for a La Marzocco. To my horror I am now presented with 'flushing' options for a HX machine and doing triple backflips with a pike finish to get temperature stability out of my machine. What's going on in the world of espresso machines where we do our best to put all the other factors in place for great espresso only to be let down by machines that fluctuate like butterflies on amphetamines? Can you point me to a few articles/forum chats on this site to try and improve my shots through stabilising my HX machine?
God perfected it, we're playing catch up.
MJ's Cafe
Link to "Temperature Stability . . . . from a Heat Exchanger"by HB on Sun Jan 08, 2006 12:04 pm
MJ's Cafe wrote:Can you point me to a few articles/forum chats on this site to try and improve my shots through stabilising my HX machine?
How I Stopped Worrying and Learned to Love HXs is geared towards semi-commercial machines, but the principles are the same. Commercial HXs rebound much faster than their smaller siblings, so I use the the flush-n-go technique (or sometimes called the "pro's method") exclusively in their case rather than the rebound method described in the HX Love article.
www.vanelis.com: top-notch espresso equipment and customer support
Link to "Temperature Stability . . . . from a Heat Exchanger"by MJ's Cafe on Thu Jan 12, 2006 11:51 am
Thanks for the articles. It feels like I've gone a long way from turning the hissing, spitting tomcat into a friendlier beast. I haven't rigged up a thermometer yet but noticed my shots were coming out a lot steadier, blonding less and also noticed much more crema than I was previously getting. I'm now looking for a good thermometer (may use a similar rig to the one schomer discusses) to really start testing the temperatures in the group. thanks again! :)
MJ's Cafe
Another note about the flush
Link to "Temperature Stability . . . . from a Heat Exchanger"by mteahan on Thu Jan 12, 2006 4:43 pm
Keep in mind that without coffee or sufficient restriction in the probed based portafilter, the PI chamber won't be used. The chamber will bleed off 50 or 60cc which will mimic the preflush about which everyone seems to be obsessing.
Michael
Michael Teahan
Espresso Part Source
mteahan
Frigging with the rigging
Link to "Temperature Stability . . . . from a Heat Exchanger"by MJ's Cafe on Fri Jan 13, 2006 12:09 am
I've been wondering about that michael. After checking a few articles on how to rig up a portafilter with a temperature probe and the importance of having the head of the probe level with the top of the puck: see Schomer article: (how do i work this bloody url insertion thing?) http://www.lucidcafe.com/cafeforum/schomertable13.html
"After the porta-filter has heated up thoroughly in the group head grind a shot and pack it over and around the bead probe. It is crucial that the bead just shows on top of the packed coffee. If the bead is sticking up too high it may contact the metal dispersion screen and create an erroneous reading. If it is buried inside the packed coffee it will take 10 to 15 seconds to obtain a true reading of what the machine is doing as brewing water permeates the packed coffee."
Schomer advocates packing the shot 'over and around the bead probe'. How do I do that and 1) avoid damaging my tamper on the head of the bead and 2) ensure the shot is as close in consistency as a normal shot would be without packing around the bead? I was going to have a go and use my ol' friend trial and error but thought to ask you guys first and avoid the potential of a few hours of frustration, hair pulling and tantrum throwing.
cheers, mark.
MJ's Cafe
Re: frigging with the rigging
Link to "Temperature Stability . . . . from a Heat Exchanger"by Ken Fox on Fri Jan 13, 2006 2:24 am
MJ's Cafe wrote:I've been wondering about that michael. After checking a few articles on how to rig up a portafilter with a temperature probe and the importance of having the head of the probe level with the top of the puck: see Schomer article: (how do i work this bloody url insertion thing?) http://www.lucidcafe.com/cafeforum/schomertable13.html
"After the porta-filter has heated up thouroughly in the group head grind a shot and pack it over and around the bead probe. It is crucial that the bead just shows on top of the packed coffee. If the bead is sticking up too high it may contact the metal dispersion screen and create an erroneous reading. If it is buried inside the packed coffee it will take 10 to 15 seconds to obtain a true reading of what the machine is doing as brewing water permeates the packed coffee."
cheers, mark.
Then was then and now is now. If you really want accurate measurements, get a Scace Thermofilter and either a Fluke datalogger or another datalogger. The Scace device was developed because of the severe limitations of the Schomer basket technique. You will drive yourself crazy with the Schomer technique, and your readings won't be worth anywhere as much, nor be repeatable, like the Scace device readings. You will also end up with hot coffee sprayed all over your clothing, and your kitchen, if you use the Schomer technique long enough.
kne
Ken Fox
Link to "Temperature Stability . . . . from a Heat Exchanger"by HB on Tue Jan 17, 2006 10:56 pm
Follow-on discussion split to WBC standards don't reflect real world usage...
Next
Return to Espresso Machines
