Tamping with single spout portafiler...??
Link to "Tamping with single spout portafiler...??"by electricjesster on Fri Aug 08, 2008 12:47 pm
I have a silly question - how do all of you tamp with a single spout portafilter?
I've always used a double spout portafilter but recently decided to use a single spout. Since the spout is off to the side, it's really hard to push down and tamp it. The only thing I can think of is making some cheesy little jig to hold it.
Does anyone have this problem?
thanks!
electricjesster
Link to "Tamping with single spout portafiler...??"by inputusername on Fri Aug 08, 2008 1:02 pm
electricjesster wrote:I have a silly question - how do all of you tamp with a single spout portafilter?
thanks!
Try the Bumper Portafilter Tamp Stand & Rest...it should work nicely for you:
http://www.espressoparts.com/prod...mp_Stand_Rest.html
http://www.chriscoffee.com/produc.../bumbertamperstand
inputusername
Link to "Tamping with single spout portafiler...??"by cafeIKE on Fri Aug 08, 2008 1:10 pm
I found it easier to hold the tamper piston up, quickly invert the PF and whack it down on the tamper.
Seriously, with a little practise, unless making gorilla tamps, it's easy. Rest the PF level on the counter. Hold the tamper so thumb, index and middle fingers form triangle around the piston. Use your finger tips to align the tamper with the basket and press the piston with the fingers.
I've seen some baristas rest the PF at an angle, but they have half tamped the basket with their hand, loading a 18 or 20g double.
cafeIKE
Link to "Tamping with single spout portafiler...??"by Dink0617 on Fri Aug 08, 2008 1:45 pm
I had considered the Bumper stand but for $40 I felt it was a little steep for what it actually is. I bought a small wooden pencil box for a dollar at a thrift store, cut a slot in one of the sides, works fine. While it may look a little "cheesy" it does the job.
Dink0617
Link to "Tamping with single spout portafiler...??"by Mark08859 on Fri Aug 08, 2008 3:05 pm
You could simply remove the basket, tamp, and then place the basket back in the PF.
Mark08859
Link to "Tamping with single spout portafiler...??"by electricjesster on Fri Aug 08, 2008 6:18 pm
Thanks for the suggestions! I tried removing the basket and tamping. I got all frazzled trying to get it back into the portafilter after it snapped into place and loosen the coffee. :(
electricjesster
Link to "Tamping with single spout portafiler...??"by r-gordon-7 on Fri Aug 08, 2008 6:34 pm
I guess that's the advantage of ridgeless baskets - they're easier to place inside the portafilter after tamping, without disturbing the tamped grounds. (Their disadvantage comes later, when the basket takes flight during an errant knock somewhere near the knockbox... :wink: )
r-gordon-7
r-gordon-7
LMWDP #188
r-gordon-7
Link to "Tamping with single spout portafiler...??"by zin1953 on Fri Aug 08, 2008 7:41 pm
r-gordon-7 wrote:I guess that's the advantage of ridgeless baskets - they're easier to place inside the portafilter after tamping, without disturbing the tamped grounds.
AMEN!
r-gordon-7 wrote:(Their disadvantage comes later, when the basket takes flight during an errant knock somewhere near the knockbox... :wink: )
I have never had that happen.
zin1953
Link to "Tamping with single spout portafiler...??"by DavidMLewis on Fri Aug 08, 2008 11:47 pm
My solution, back before I got the bottomless PF, was to go to the hardware store. I found a black PVC pipe adapter, 2 1/2" as I recall, that fit the bottom beautifully. I had to take a file and cut a notch for the handle, and I had a very functional and aesthetically acceptable tamping stand for about $2. If you were in Santa Cruz I'd give it to you, but it would cost more to mail than it would for you to make.
Best,
David
DavidMLewis
Link to "Tamping with single spout portafiler...??"by cannonfodder on Sat Aug 09, 2008 4:50 pm
electricjesster wrote:Thanks for the suggestions! I tried removing the basket and tamping. I got all frazzled trying to get it back into the portafilter after it snapped into place and loosen the coffee. :(
Take the spring out of the portafilter and you can just drop in the basket. You will have to hold it with your thumb so it does not fall out when you knock out the puck. I purchased the bumper stand and consider it worth every penny I invested. It works good for singles, doubles and gives you a nice elevated and padded bottomless tamping stating. The tamper sits nicely in it as well.
cannonfodder
Link to "Tamping with single spout portafiler...??"by electricjesster on Sat Aug 09, 2008 6:54 pm
Well, the cheap side of me won over - I took DavidMLewis's suggestion and made one out of a piece of plastic tubing. Just gave it a try and it works great. Looks a little cheesy and I need to file the edges a little, but for $1.50... :)
electricjesster
Link to "Tamping with single spout portafiler...??"by RapidCoffee on Sun Aug 10, 2008 12:35 am
Just for completeness: you can tamp reasonably well without any external devices, by resting the portafilter on the edge of the countertop. But I also recommend either a) prepping a ridgeless basket outside the PF or b) using the Bumper tamper stand.
If you're gonna go spouted, it might as well be a single spout.
John
RapidCoffee
Link to "Tamping with single spout portafiler...??"by joshuak on Thu Aug 28, 2008 2:27 pm
you can also rest the very front of the pf against the edge of your counter so that the spout is abutted against it, and tamp there.
o===[   ]_____________
     \/ | Counter edge
i wonder if my picture will resemble at all... :lol:
joshuak
Link to "Tamping with single spout portafiler...??"by Mark08859 on Thu Aug 28, 2008 4:01 pm
RapidCoffee wrote:Just for completeness: you can tamp reasonably well without any external devices, by resting the portafilter on the edge of the countertop. But I also recommend either a) prepping a ridgeless basket outside the PF or b) using the Bumper tamper stand.
I do have the Bumper tamper stand. But, in all honesty, it is simply easier (for me anyway) to tamp into the PF basket in stand-alone mode. I have removed the retaining spring/clip from my PFs and have never had a problem with a "flying" PF basket while using my knockbox.
Mark08859
Link to "Tamping with single spout portafiler...??"by r-gordon-7 on Thu Aug 28, 2008 4:06 pm
Mark08859 wrote:I have removed the retaining spring/clip from my PFs and have never had a problem with a "flying" PF basket while using my knockbox.
Were my hand-to-eye coordination only half as good as yours! :mrgreen:
r-gordon-7
r-gordon-7
LMWDP #188
r-gordon-7
www.dailygrind.com: artisian roasted coffee and espresso equipment
Link to "Tamping with single spout portafiler...??"by babola on Thu Aug 28, 2008 4:22 pm
In my case, Bumper tamping stand is definitely worth every cent. At $40 one could hardly argue against it, it gives me an elevated flat and rubber padded tamping surface, and works for naked, single or double spouted portafilters, it even works for those longer (XL) spouts. It duplicates as a tamper stand or resting place as well. The front round rubber base part is excellent for slight vertical knock to level the grounds in the p/f prior to distribution and tamping.
Needless to say it's also my wife's favourite since I'm not putting any more dents into a benchtop :)
Don't hesitate to get one, I as many was a bit sceptical prior to purchase, but love it to bits now.
babola
Link to "Tamping with single spout portafiler...??"by stefano65 on Thu Aug 28, 2008 5:08 pm
Take a piece of a 4x4 as tall as is a comfortable working high from your counter and your elbow
drill a 2" hole in the middle deep enough for the portafilter and spout to seat in it
then drill 2-3 hole in the left side as deep as the spout
painted any color to match your counter
done
15 minutes of time and a scrap of wood
Stefano Cremonesi
Stefano's Espresso Care
stefano65
Link to "Tamping with single spout portafiler...??"by erics on Thu Aug 28, 2008 5:17 pm
Another good solution, certainly repeated in some previous posts above, is to:
a. Remove the springs from all of your PF's and tamp the basket in the "unused" PF on a rubber mat.
b. The basketless PF you will use is sitting in the machine - nice and hot.
c. Do your flush, remove the PF, shake and wipe dry, insert the prepped basket.
d. Pull shot.
Knocking the grounds out of the basket (by itself) is never a problem as long as you let it cool a little.
Skål,
Eric S.
erics
Link to "Tamping with single spout portafiler...??"by HB on Thu Aug 28, 2008 7:49 pm
I either tamp with the portafilter wedged against the counter's edge, or remove the portafilter retainer clip and drop in a new basket for each shot. Since I'm frequently testing equipment, I've gotten into the (bad) habit of weighing each dose precisely. I should follow my own advice from Exercises for tuning your barista techniques and practice volumetric coffee dosing more often. :oops:
Link to "Tamping with single spout portafiler...??"by cafeIKE on Fri Aug 29, 2008 8:45 am
Please see How important is tamping? for my latest escapade :wink:
cafeIKE
Return to Tips and Techniques
