Swapping beans in the grinder
Link to "Swapping beans in the grinder"by PapaWhisky on Sun Jun 08, 2008 7:32 am
Any tips for swapping beans in the grinder? I want to be drinking regular leaded in the morning and then switch to unleaded in the evening.
Is there an easy way to be doing this ... short of upending the grinder every evening into a container.
Don't suggest two grinders ... I'm not there (yet)
PapaWhisky
Link to "Swapping beans in the grinder"by HB on Sun Jun 08, 2008 8:13 am
I used to measure the coffee beans and grind until empty.
Link to "Swapping beans in the grinder"by PapaWhisky on Sun Jun 08, 2008 8:33 am
Doesn't the grinder need at least a half full hopper to gravity feed the cutters?
PapaWhisky
Link to "Swapping beans in the grinder"by HB on Sun Jun 08, 2008 8:45 am
No. It's true that most grinders will grind more consistently with the pressure of beans above (the effective grind setting becomes coarser as the weight drops off). But if you consistently dose and grind until empty, the grounds are consistent (or more accurately, they're predictable). Is single dose [without hopper] grinding inconsistent? debates this point.
Link to "Swapping beans in the grinder"by zin1953 on Sun Jun 08, 2008 11:18 am
Method No. 1:
HB wrote:I used to measure the coffee beans and grind until empty.
Method No. 2: Get a second grinder. :wink:
zin1953
Link to "Swapping beans in the grinder"by RegulatorJohnson on Sun Jun 08, 2008 11:28 am
...plan ahead?
i have a 1/4 cup measure that is about one double worth of beans.
i usually make about 5 shots a day.
so i dump in 5 1/2 scoops.
this is going to leave about 1/2 a shot of beans left. i can then happily just grind those away. and scoop in something different.
or you can just dump in the whole bag. make your shots. then you can empty the hopper back into the bag at the end of the day. or to switch beans.
whatever works best for you is usually the best solution.
jon
jon stovall
bevalo.com
thebeaningoflife.com
RegulatorJohnson
Link to "Swapping beans in the grinder"by Marshall on Sun Jun 08, 2008 12:33 pm
There is no good single grinder solution, unless you can afford a Versalab (and some don't care for that machine). I suggest a cheaper burr grinder for brewed coffee.
Marshall
Los Angeles
Marshall
Link to "Swapping beans in the grinder"by narc on Sun Jun 08, 2008 1:38 pm
Over time I've convert over to the effects of popcorning is not a major factor side of the aisle. I just single dose every grind. When switching blends or SO just clean out the grinder & doser, sacrifice a few of new beans, hope your grind is on. If not repeat. Other option is as Marshall suggested. For low volume a Zass or equivalent hand grinder would work. Plus you have a travel grinder.
noel v.
Noel'sAritisanRoastingCompany(NARC)
LMWDP #151
narc
Link to "Swapping beans in the grinder"by cannonfodder on Sun Jun 08, 2008 3:28 pm
You are going to blow a lot of coffee into the garbage changing every day like that. Figure at least one sink shot to adjust the grind every time you change the beans, twice a day. Half of your coffee will go in the garbage. A second grinder may pay for itself.
cannonfodder
Link to "Swapping beans in the grinder"by another_jim on Sun Jun 08, 2008 5:50 pm
PapaWhisky wrote:Any tips for swapping beans in the grinder? I want to be drinking regular leaded in the morning and then switch to unleaded in the evening.
Some grinders are easier than others for either single dose use or switching hoppers. The Rocky is tough for both; but it's light enough so you can simply upend it when you need to switch beans. This may seem inelegant, but it is by far the simplest solution for this grinder.
another_jim
Link to "Swapping beans in the grinder"by cgfan on Wed Jun 25, 2008 11:47 pm
As described and pictured in my earlier post in another thread, I pre-dose and grind one shot at a time. I do not have an issue with popcorning reported by others. Popcorning is avoided by "capping" the "throat" of the grinder with a cheapie plastic tamper, applying subtle pressure on the beans trapped underneath as they feed into the grind chamber.
As can be seen in my post there are a couple of other complementary adaptations that I've made, all contributing to a smooth and efficient workflow that uses 100% of the beans and its grounds.
cgfan
Link to "Swapping beans in the grinder"by JR_Germantown on Thu Jun 26, 2008 8:11 am
Dan, just curious...why "used to"?
Jack
JR_Germantown
Link to "Swapping beans in the grinder"by zin1953 on Thu Jun 26, 2008 8:58 am
I'm not Dan, but having two grinders solved my "switching" problems.
zin1953
Link to "Swapping beans in the grinder"by HB on Thu Jun 26, 2008 10:55 am
JR_Germantown wrote:Dan, just curious...why "used to"?
The grind setting drifts as the beans run out (see Is single dose [without hopper] grinding inconsistent? for discussion). I rarely pull less than 3 shots in a session, so keeping a half-pound of coffee in the hopper isn't an issue.
Link to "Swapping beans in the grinder"by RapidCoffee on Thu Jun 26, 2008 11:17 am
HB wrote:... most grinders will grind more consistently with the pressure of beans above (the effective grind setting becomes coarser as the weight drops off). But if you consistently dose and grind until empty, the grounds are consistent (or more accurately, they're predictable). Is single dose [without hopper] grinding inconsistent? debates this point.
Here's a simple test: without changing grinder settings, grind with a single dose of beans vs. several doses in the hopper. Pull a fixed shot volume (or better yet, weight) and compare the pour timings. I was surprised at the difference: 6-8 seconds faster for single shot grinding on my setup (documented on the thread linked above). This was enough to convince me that popcorning is a significant factor in grind coarseness, at least for single shot dosing. Since then I've shifted to grinding with several doses of beans in the hopper (and upending the 30# SJ when I want to change beans :evil:).
John
RapidCoffee
Link to "Swapping beans in the grinder"by joshuak on Wed Jul 09, 2008 5:50 pm
does the hopper on your grinder have a sliding tray to close the spout? if so you could just order a second hopper from the manufacturer
* edit: my bad, i'm new here and forgot to check your equipment in your profile :?
joshuak
Link to "Swapping beans in the grinder"by k7qz on Thu Jul 10, 2008 10:45 am
His profile lists a Rocky otherwise joshuak post is right. I don't have a second hopper for my big Mazzer so I just close the throat slide, run the grinder until the chamber is empty, lift out the hopper, pour out the remaining beans and then pour in the new blend. Sure, I waste a couple of shots of beans this way but it's a minor waste IMO in the grand scheme of things considering what I've otherwise spent in my quest for espresso perfection...
I also have a Rocky and another-jim is right- the Rocky is light enough to upend it and "out with the old, in with the new".
k7qz
Link to "Swapping beans in the grinder"by Eric on Mon Jul 14, 2008 11:55 am
I only load a single shots worth of beans in my MACAP M4 and place an old 53 mm basket on top of the beans. The basket prevents the beans from flying out and any residual popcorning effect is exactly the same for each shot. I use the same basket to measure the volume of beans.
eric
Eric
Eric
Link to "Swapping beans in the grinder"by cannonfodder on Tue Jul 15, 2008 10:14 pm
I have a Cimbali grinder. They are not conducive to changing beans constantly but I love the grinder, so I got another.
cannonfodder
Return to Tips and Techniques
