lsf wrote:Hi,
This is an issue I've had for a little while and unfortunately, the technician where I bought the machine doesn't seem to be able to source the problem. So here is my story:
About 1 months ago, my Andreja Premium developed a strange metal high pitched intermittent noise when the pressure rose to 9 bar.
So what are your thoughts about this? Is this noise normal in your opinion? If not, what could it be?
Thanks
Vibe pump driven machines can be noisy, sometimes very noisy. Generally, this is not due to the pump itself being noisy, but rather the vibe pumps shake the bejesus out of the machine and make the case and other parts rattle. If you aren't used to this than you might think something is amiss when in fact it is not.
On the other hand, the problem could be harmonic resonance coming from the plumbing system in the machine, most likely from the overpressure valve ("OPV"). OPVs, which are what you use to adjust the brew pressure, have a spring in them and under certain circumstances you could get a squeal or other noise coming out of the OPV; I have had this problem with my old Cimbali vibe pump machine. There is a tutorial on adjusting the OPV on an Andrea Premium, that I believe is up on the Chris Coffee website but can be found through a link on this website, somewhere, maybe in Dan's review of this machine. You will have to remove the case in order to get at the OPV.
You could try adjusting the OPV back and forth a few times and then get it set back right, around 9 bar. This might solve the problem or you might need to replace the OPV, which may be the culprit in your problem. Or, some other part in the machine may not be properly secured, and an inspection inside the case may well show which part this is. Perhaps all you need to do is to tighten a screw or bolt, or the simple act of removing and then reattaching the case may resolve it.
ken
