aindfan wrote:I just have the best luck with these lever machines. First, two failed Gaggias, and now, a Lusso that arrives with a severely dented drip tray, a lever about 10 degrees off center, and enough water stains and other splotches of something that just leave me convinced that this machine was more than tested. That would be a bit too much splashing for just a test.
Oh, and did I mention that the boiler appears to be mounted off in some direction? (Doesn't look vertical) I'll post pictures a bit later. I'm waiting for a call back from a 1st-Line tech.
Dan,
I am sorry to see that this purchase did not arrive to your satisfaction and our intentions. Please note that I have been on vacation since August 5th, and I will be returning on this Monday, August 17th. On top of this, I know some of my other employees have been on vacation or been out sick during this time period. Therefore, I apologize if you did not receive a call back this past Friday.
Please also note the machines are inspected before they leave. This is performed just before the grey Instapak is added to protect the unit from damage in transit. However, it is very evident that my staff took a shortcut and did not double box the Ponte Vecchio box. This definitely caused the drip tray damage. This is the easy fix.
The hard fix is the boiler shifting. This has happened to two other PVs in the last month - not cheap since 1st-line eats the cost as the carriers insurance makes excuses for everything now. This is where I am uncertain how any packaging can stop the inertial forces of shipping to cause the boiler to shift.
As for the limescale, this is how they come from the factory. They do not drain all the water from the boiler, and the residual turns into this. All the units have this as well as the water stains that come from leakage out of the boiler during shipping. Most likely, the boiler shifting caused a break in one of the internal pipes. At this time, we do not test the units with water because the DOA due to manufacturer's defect has been less than 1% of shipments.
So far, we have had no returns on PV machines. The 2 other machines that were damaged have not been returned yet. So, we have no used units to ship out.
Finally, please do NOT use the machine as another poster suggested. This will 100% ruin our ability to even file a damage claim, nevermind being successful in acquiring an insurance payment from the carrier. Please call me on Monday morning so we can get this squared away for you. Once again, I apologize this happened.
