Sticky brew pressure gauge on Anita?
Link to "Sticky brew pressure gauge on Anita?"by quar on Wed Jul 20, 2005 11:27 am
Is anybody else seeing their brew pressure gauge stick on their Anita?
After pulling a shot, the needle remains at the last pressure it indicated. I can drop it back down by running the pump for a few seconds w/o a PF locked in, but it sometimes starts creeping back up.
Is that normal behavior for such a gauge?
Mike
quar
Link to "Sticky brew pressure gauge on Anita?"by HB on Wed Jul 20, 2005 11:50 am
The brew pressure gauge should return to zero immediately following the "whoosh" of water into the driptray, then it will eventually creep back up as pressure builds in the heat exchanger. Try raising the lever halfway until water dribbles out, but before the pump engages. At that point the gauge should definitely return to zero. If it doesn't, time to call the service department.
PS: It's not an easy read, but the E61 patent description and diagram below explain what's going on at the lever's halfway position, specifically:
When lever (15) operating the cam (6) is lifted and thereby the lobe of cam lifts stem (16) of the dispensing valve (5), the dispensing valve (5) is in turn lifted off its seat against the force of the spring (18), permitting water under pressure to flow from the chamber (3) through the gicleur (2) and the valve chamber (20) and into the chamber (14) which communicates with the group via a conduit (4).
Link to "Sticky brew pressure gauge on Anita?"by quar on Wed Jul 20, 2005 11:53 am
Hmm....I've been wondering about that...I don't seem to be able to get water to dribble out of my Anita. Water doesn't flow until the pump engages.
Mike
quar
Link to "Sticky brew pressure gauge on Anita?"by HB on Wed Jul 20, 2005 11:59 am
Well, it's not much water and it takes awhile for the pressure to build up. If you're able to make espresso and water evacuates as expected, you're golden. The rest is obsessing over minutia. ;-)
Link to "Sticky brew pressure gauge on Anita?"by quar on Wed Jul 20, 2005 5:34 pm
My pressure gauge can be unstuck by doing this, but it is not reliably returning to zero after ending a shot...Looks like I need to call Chris.
I probably haven't been letting the handle sit at the halfway point long enough. I've only given it a couple of seconds.
Espresso has been great though!
Mike
quar
Re: Sticky brew pressure gauge on Anita?
Link to "Sticky brew pressure gauge on Anita?"by mrego on Wed Apr 26, 2006 8:15 pm
quar wrote:Is anybody else seeing their brew pressure gauge stick on their Anita?
Mike
I've had my Anita for about 2 weeks and noticed that I am having the same issue with the brew pressure remaining at the last pressure after pulling the shot.
I've just finished reading an article by Alex Lamber in the April/May issue of Barista Magazine (page 55), he states that this is normal.
I'm wondering about if this is just an issue with the Anita, or is it the norm for all other brands of espresso machines?
mrego
mrego
Link to "Sticky brew pressure gauge on Anita?"by quar on Wed Apr 26, 2006 9:43 pm
mrego wrote:I'm wondering about if this is just an issue with the Anita, or is it the norm for all other brands of espresso machines?
It's normal for all machines, not just the Anita.
Mike
quar
Link to "Sticky brew pressure gauge on Anita?"by 1st-line on Wed Apr 26, 2006 9:51 pm
quar wrote:It's normal for all machines, not just the Anita.
Mike
Normal for direct plumbed machines as water line pressure will show, but it should go down on vibe pump machines unless the connection of the brew pressure gauge is placed behind a solenoid valve that maintains the pressure between the pump and the solenoid valve.
Jim Piccinich
1st-line Equipment, LLC
1st-line
Link to "Sticky brew pressure gauge on Anita?"by HB on Wed Apr 26, 2006 10:41 pm
mrego wrote:I've just finished reading an article by Alex Lamber in the April/May issue of Barista Magazine (page 55), he states that this is normal.
I've not read the article, but I wonder if he was even referring to an E61 vibe pump HX machines like Anita. That's not the usual Barista Magazine fare. In any case...
Thermosyphon circuit and heat exchanger (solenoids / valves omitted)
When the lever is down, the system is closed. The idle pressure reading will therefore be partially from thermal pressure. Recall that the HX completely full of water and immersed in a bath of steam and super-heated water under pressure; after a few minutes, the gauge pressure will creep up as the heated water expands (an expansion valve will vent some water if the pressure rises too high).
As Jim noted, it depends on where the tee for the pressure gauge is located (before or after the solenoid directing water to the group or boiler). For Anita, the tee is at the HX exit towards the group:
Brass expansion valve on lower left, HX exit toward group on upper right, brew gauge tee in center
See the threads E61 Group Espresso Machine: Detailed Interior Schematics and E61 patent explanation for more details / diagrams (thanks to Lino!).
Link to "Sticky brew pressure gauge on Anita?"by mrego on Thu Apr 27, 2006 9:26 pm
The tee location for the pressure gauge is something that I had never considered. To me, it just seems a little odd having the Anita showing 7-9 bar or so, when
the machine is just sitting there and not brewing, but, what do I know. This just goes to show that the more you read this forum the more you learn.
Thanks for all that replied and educated me on my new purchase.
mrego
mrego
Link to "Sticky brew pressure gauge on Anita?"by Teme on Fri Apr 28, 2006 9:17 pm
My Andreja does the same. I understand that the Isomac Tea also does this due to the location on the brew pressure gauge pick-up (don't know about other machines with a brew pressure gauge). I have always assumed it to be normal...
Br,
Teme
Teme
Link to "Sticky brew pressure gauge on Anita?"by kav on Tue May 23, 2006 4:20 pm
I'd always heard that the pressure gauge reading wasn't meaningful unless the pump was running. My Anita's gauge has never sat at zero, but works perfectly when it needs to. No problem!
kav
Return to Espresso Machines
