King Seven wrote:Slightly confused by the wiring to a motor on my old Gothot sample roaster. It has 4 wires - Blue, Brown, Yellow/Green and Black. Does this mean it is 2 phase? (sorry if that is a stupid question....)
Not a stupid question, as you Brits have done some slight changes recently. Quite often, the same cable is used for quite a few different applications (My eighties La Pav Pub still has an Italian Standard 220V cable on it, but is wired for 110V) and may contain a wire that isn't connected at either end. While I'm not entirely familiar with British wiring standards, I am passable at them, and fairly familiar with industrial standards. Ish...
That said, there is very little that is designed to run on two phases. *Usually* stuff gets designed to run on a single phase, or on three phases. I've run into lots of each, and never discovered anything that will run on two. It's still possible. The best way to do it is to follow the leads back to see where they go (and pics won't hurt) and find out what they're doing. This will tell you how they want to be wired. My LP has a wire living in the sheath that does nothing, and I just consider it a ready spare.
Green with Yellow is going to be ground, Blue is (probably, when was this thing last connected to power, and where was it?) Neutral, and Brown is Live. Black is usually used for a Live line, but if it were three-phase, there would be a grey in there somewhere. Post some pics of the other end, and we'll be able to decide whether you're going to electrocute yourself or set the thing on fire. Or maybe, just maybe, get it right!
