I've been using my new Alexia for about three weeks now. Shots are fairly consistent and the coffee is excellent with plenty of schiuma. Since this is my first E61 machine, I do have some basic operator questions:
1) When I turn the machine on, as it warms up, I'll get some water dripping out of the shower head or the bottom, depending on where I last left the lever. Normal?
2) Once a shot is done, the gauge indicates that the system is still under pressure. Should I bleed it off with the water nozzle, or just leave it, or partially bleed the pressure?
3) Low water indicator. From what I can tell, there isn't one that illuminates a light. There's supposed to be a float in the reservoir, but I can't tell if it does anything.
4) Refilling the boiler. I followed Chris' instructions upon start up and everything is fine so far. Every few shots, I turn on the pump until I start building pressure, which surely indicates the boiler is full. Do you guys do the same?
5) I only received instructions from Chris with the machine. Is there a manual from Quickmill that's available? I speak Italian, so translation isn't a problem.
Thanks in advance for any replies!
