www.eccocaffe.com: custom coffee roasted in Northern Italian style
Simplified HX Descale [PourOver]
Link to "Simplified HX Descale [PourOver]"by cafeIKE on Tue Jan 09, 2007 3:51 pm
Most of this is covered in another thread, but this is a nice printable summary with a couple of tips to make it simpler. :)
To simplify descaling a [pourover] HX machine, add a Miniature DPST NC Momentary switch in the Auto Fill Sense Line. Wire the double poles in parallel for redundancy. [I added mine through one of the ventilation slots in the base of the machine. I had to file an extra flat for it to fit. I added a finger guard and positioned it far enough inboard to preclude accidental operation. After installation I snotted it over with RTV to ensure water rejection. One could use a sealed switch instead, but I had this one in an old sample kit.]
Let's call it the Manual OverFill Switch or MOS for short.
Mix up solution of citric acid in a separate container. Mix 1 liter / Quart for HX only descale or treble that for typical home HX and Boiler. Concentration should be 1.5 to 2 Tablespoons per Qt / 25-30ml per L
    To Descale HX Only
    - Heat the machine to normal operating temperature
    - Open Hot Water tap until pump starts and let boiler refill
    - Open the steam wand valve slightly and press the MOS for 30 to 60 seconds to overfill the boiler. The trick is to keep enough pressure in the boiler to keep the vacuum break valve closed. The overfilled boiler won't ingest any cleaning solution during the HX descale
    - Close steam wand valve and release MOS
    - Place fill tube in descaling solution and return in a separate container.
    - Draw 4oz / 125ml through the group.
    - Wait 10-20 minutes depending on how long since last descaled :roll:
    - Repeat 6 times.
    - By the end, the water should be almost clear.
    - Place the fill tube in fresh water and flush and repeat for 1 L / Qt through the group
    - Open Hot Water tap until excess water is removed from boiler.
    To Descale HX and Boiler
    - Heat the machine to normal operating temperature.
    - Turn OFF Machine
    - Place two espresso cups under the machine feet on the OPPOSITE side to the Hot Water exit.
    - Open the Hot Water tap and drain as much water as possible.
    - Remove espresso cups
    - Refill boiler and let machine reach operating temperature
    - Open the steam wand valve slightly and press the MOS until water comes out of the steam wand
    - Repeat group flush 6 times. By the end, the water should be almost clear.
    Boiler Flush
    - Turn OFF Machine
    - Place fill tube in clean water and return in a separate container. Use bottled distilled RO water for the refill to minimize boiler scale build up. There seems to be enough citric acid left to ensure operation of the auto fill. Of course, if you use boiler water for other than steam generation, use your favorite water.
    - Open the steam wand valve slightly and press the MOS until water comes out of the steam wand.
    - Repeat twice from Boiler Flush or until the water is tasteless.
cafeIKE
Link to "Simplified HX Descale [PourOver]"by cannonfodder on Tue Jan 09, 2007 4:15 pm
I would suggest that you not flush your boiler twice with bottled water, but flush it through 2 reservoirs full of water to be safe. I run two 3 liter reservoirs of water through my pour over machines boiler (1.5 liter) after a descale. One gets all the green water out, the second is for good measure. I also run a half to full reservoir through the heat exchanger.
When using a vibe pump, make sure you work in sessions. Continually running a vibratory pump will burn it out. Their specifications are not 100% duty cycle. For every second of use allow one to two seconds of rest and do not exceed 50-60 seconds of continuous running.
When dealing with acids, better safe than burning a hole in your tongue and dying a slow death from taste testing to see if you got all the acid out, IMHO.
Nice synopsis of the process.
cannonfodder
Link to "Simplified HX Descale [PourOver]"by oofnik on Tue Jan 09, 2007 4:45 pm
I'll be sure to do this once I get my new machine. Great writeup, thanks!
oofnik
Link to "Simplified HX Descale [PourOver]"by miKe mcKoffee on Tue Apr 10, 2007 10:17 am
    - Turn OFF Machine
Jim's directions suggest soaking the boiler with descaling solution for several hours. If I understand correctly following your simplified directions with boiler filled with descaler, then running descaler through HX and group with 10-20 minute waits repeating six times, that seems to infer only one to two hours boiler descaler soak. I like to target minimum 4 hour boiler descaler soak regardless time since last descaling.
aka Mike McGinness
http://www.mcKonaKoffee.com
miKe mcKoffee
Link to "Simplified HX Descale [PourOver]"by cafeIKE on Tue Apr 10, 2007 2:12 pm
"The Insanely Long Water FAQ" wrote:Once the boiler is filled with descaler, leave it in for two and half hours with the machine off, or one hour with the machine on.
The method works well for a typical home use HX descaled every 3-4 months.
By the 3rd or 4th iteration the solution water is almost clear.
Four hours is a long time to leave metal in hot acid, however mild.
cafeIKE
Link to "Simplified HX Descale [PourOver]"by TimEggers on Tue Apr 10, 2007 2:18 pm
Excellent write up. I needed an HX descale "for dummies" thank you! :D
Tim
LMWDP #202
TimEggers
Link to "Simplified HX Descale [PourOver]"by miKe mcKoffee on Tue Apr 10, 2007 3:01 pm
cafeIKE wrote:Four hours is a long time to leave metal in hot acid, however mild.
Just curious, base on?
aka Mike McGinness
miKe mcKoffee
Link to "Simplified HX Descale [PourOver]"by cafeIKE on Tue Apr 10, 2007 3:15 pm
miKe mcKoffee wrote:Just curious, base on?
Pique
cafeIKE
Link to "Simplified HX Descale [PourOver]"by miKe mcKoffee on Tue Apr 10, 2007 3:39 pm
cafeIKE wrote:Pique
:?: Mine was a serious question not meant as a provocation. Is there a basis to believe a long multi-hour soak of a prosumer espresso machine's internals with a mild citric acid solution will be damaging? There may well be, I'm no chemist!
In fact, just checked Urnex site for Dezcal directions which state "Professional Use: Add 1 oz (28 g) of powder for each 16 oz (500 ml) of hot water. Stir to dissolve. Hold solution in vessel for up to 30 minutes. Rinse all parts thoroughly." This seems to support your shorter duration suggestion rather than Jim's several hours.
aka Mike McGinness
miKe mcKoffee
Link to "Simplified HX Descale [PourOver]"by cannonfodder on Wed Apr 11, 2007 11:59 am
It really depends on the solution you use. I use a commercial descale solution that is very strong. I descale a commercial boiler that was many years old in 2 hours and it was clean as a whistle. That same solution will dissolve the edges off of brass bolts and hex heads if you leave it in solution too long, it is very strong stuff.
So the soak time needed will depend on the solution used to descale the machine, the severity of the scale and the temperature of the water. The hotter the water, the more aggressive it works.
cannonfodder
Link to "Simplified HX Descale [PourOver]"by another_jim on Wed Apr 11, 2007 4:18 pm
cannonfodder wrote:It really depends on the solution you use. I use a commercial descale solution that is very strong. I descale a commercial boiler that was many years old in 2 hours and it was clean as a whistle. That same solution will dissolve the edges off of copper bolts and hex heads if you leave it in solution to long, it is very strong stuff.
This is correct with one caveat. With commercial descaler, you will not neutralize the acid to a safe level with the scale in the machine, so one needs to watch the time. The 1.5 to 2 tablespoon citric per liter solution will be neutralized by heavy scale, and isn't all that aggressive to begin with, so it can be left in for a while. I go overnight on cold machines and 2 to 4 hours on a hot one (depending on how lazy I've been in scheduling).
The usual caveat -- this citric solution is roughly 50% to 75% the strength of lemon juice, and it'll pick up light scale. If you have a heavily scaled part, or a valve, orifice, or piping junction, that has scaled severely (even if it's not that much calcium), it won't do the job in a reasonable amount of time. You'll need to take a part like that out, sit it in a commercial or higher concentration of citric, and remove the chunks as they come loose. I've had emails on parts that would scale severely in a few months even with fairly soft water. A simple citric flush didn't do anything for them. These generally are found on new models, since such parts' designs are revised when they show up.
I have a force fill switch on my Tea for descaling, works great. I tried a 3 position switch with a grounded third position that disabled the autofill entirely, so it wouldn't mess up my shots. But after I forgot to put it back after a hectic session, I gave up on that idea.
Speaking of autofills -- since they carry current, they can attract scale (and an odd pasty sort of grunge) even in soft water. It's worth cleaning off the wand once a year, when doing a descale. Make sure to use a marker before removing it, so you know how deep to push it back.
another_jim
Link to "Simplified HX Descale [PourOver]"by Ozark_61 on Fri Aug 24, 2007 7:22 pm
Guys - Once, in haste, I removed the autofill probe without knowing what it was - so I don't know what level it should be at. Is there a way to guesstimate the depth it should go to? I thought I once read the boiler should be half full in normal operation (see - I'm a half full kind of guy).
Geoff
Ozark_61
Link to "Simplified HX Descale [PourOver]"by cafeIKE on Fri Aug 24, 2007 7:38 pm
Ozark_61 wrote:Guys - Once, in haste, I removed the autofill probe without knowing what it was - so I don't know what level it should be at. Is there a way to guesstimate the depth it should go to? I thought I once read the boiler should be half full in normal operation (see - I'm a half full kind of guy).
Geoff
Somewhere between 50 and 75%
More water = more steam longer
Less water = quicker recovery
You may want to look at Ken Fox's Boiler Fill and Shot Temp Stability
cafeIKE
Return to Espresso Machines
