HB wrote:It takes a lot of measurements with that approach to convince yourself the data is accurate simply because the slightest error in placement will throw readings off. I learned to recognize the common mistakes just by the plot of the recorded data (usually caused by the probe moving off to the side while locking in the portafilter). Oddly I don't have a lot of recorded data on Silvia because I upgraded before investing in better measurement equipment (Fluke 54-II, type T thermocouples, thermofilter, etc.). The temperature profile data I did collect from Mike Walsh's PID'd Silvia was consistent with what I've read from others: Fast temperature increase, peaks around 5-7 seconds, slowly declines around 2C over the rest of the extraction.
I'm currently struggling with inadequate test equipment to measure my PID'd Silvia.
Ran a series of 28 2oz pulls into styro cup firmly seated in grouphead just like a PF. Therapen punctured through cup to measure. (Therapen <5sec response highly accurate digital thin probe thermometer, just re-calibrated @ 32f & 212f, used by many top Chef's and the FDA inspectors)
I also recalibrated my PID PVOF setting to -15, which yields 200f on PID and 200f at grouphead from thoroughly warmed and idle Silvia. (BTW if not adjusting PVOF that -15 200f setting would equate to 215f PID setting and reading) I had it 5f lower last Saturday so idle PID shots were 5f higher at PF than read on PID, which means most shots were likely pulled too hot, my BAD. And confirmed by smoother better tasting shots since resetting...
First dozen 2oz pulls were with PID at 200f, after the 1st pull each consecutive 2oz pulled as PID reading climbed to 200f. Then I started lowering the start PID temp of the pull to attempt to compensate for too high water temp output. Here comes the actual measured water temps:
1=200f, 2=201, 3=203, 4=203, 5=203, 6=205, 7=205, 8=205, 9=206, 10=206, 11=207, 12=207, lowered PID 13/193f=207, 14/190=207, 15/185=207, 16/180=207, 17/175=206, 18/175=206, 19/175=206, 20/170=205, 20/170=206, 21/170=205, 22/170=205, 23/165=203, 24/165=203, 25/165=203, 26/160=201, 27/160=202, 28/160=201. These were all back to back approx 2oz straight water pulls, so no puck resistance and hence pulled much faster than shots would have been.
Total time for the 28 was only 13 minutes!
How these temp increases would correlate to actual back to back shots I have no idea. I do know based on almost 4 years observation and experience that Silvia does run hotter on back to back shots. This also needs to be taken into account when traditional temp surfing BTW. I NEED one of those "Espresso Machine Thermofilter Temperature Device" that Greg Scace created and carried exclusively by EPNW, for $249.99, ouch! Anyone have one they care to loan me! (I'll gladly put up a deposit
I tried creating something similar awhile back. I've already drilled a whole in my old stock Rancilio double basket tc fed through with failed paper towel packing attempt to emulate shot. (tried with ground coffee too but the larger hole in basket for tc cause way major gushing channeling!-) What I really need to do is get a 3/8" threaded valve to screw on spare PF to regulate flow, drill hole is said PF for tc and seal, then pack PF to emulate shot, like Greg with the EPNW marketed device. I'll just use the my old style spare Silvia PF I keep backflush blank in so drilling a hole for tc no biggy. Hmmm, on second thought not drill hole in PF itself but get a second blank to feed tc through and seal hole. That way same PF can be used for day to day backflush duty and occasional temp measurements.
After those 28 2oz water pulls let Silvia stabilize, PID temp overshot a whopping 13f before coming back down to 200f as set! Normal a couple degree overshoot after a shot. She was definitely overheated.
Again, this is with tc feeding PID mounted on the top of boiler under the stock brew tstat, the common suggested location. I want to figure out a mounting location closer to the grouphead feed from the boiler and see if it helps.
