miKe mcKoffee wrote:decided to push on with Silvia grouphead PID heater rope mod
Yeah, I'd read about that particular putty curing experimentAndyS wrote:Hey, that's very cool. Let me know if there's anything I can help with. If you're using the water soluble heat conductive putty, BE SURE to let it dry completely before turning on the power (24-48 hrs). Otherwise, you may hear a very loud BANG when you first turn it on!
Not Andy and I haven't done rope heater Silvia mod yet (rope heater arrived yesterday, waiting on PID, TC & SSR ETA 12/12) With just boiler PID, TC left screw of boiler tstat, I keep coming back to 227 boiler for 200f measured via Thermofilter for first shot from idle with 2oz flush before shot and filling PF, shot (or temp measuring shot) started just us PID coming back up to 200 (227) after flush.Kristi wrote:It's on my list!
--->>>>Let me know if you find any suitable epoxy stuff locally... I need a gallon like a hole in the head - I could imbed the entire Silvia and create a sculpture...
Andy, what temp do you run your a) boiler, and b) rope heater to get 199F(93C) at the shower screen (or whatever you shoot for)? I seem to be down to 206F on the far side of the top of the boiler, and don't know if I'm kidding myself or what...
tia
Kristi
Kristi wrote:Andy, what temp do you run your a) boiler, and b) rope heater to get 199F(93C) at the shower screen (or whatever you shoot for)?
Your 212F boiler temp right in line what I find with superheating grouphead via a dozen of so back to back blanks. But fascinating, where did you mount the grouphead TC? I expected to be running the grouphead closer to shot temp. Since parts ETA for my grouphead mod not due 'til the 12th, and will have just gotten the Bricoletta the 9th, and Christmas and related insanity already decending, likely won't get to Silvia's grouphead mod 'till end of the month after Christmas.AndyS wrote:I've typically been running both the boiler and the grouphead at around 212F to get brew temps ~200F. But I wouldn't take the grouphead temp too literally, it depends on where you measure it.
Kristi wrote:I wonder what the capacity in oz is of the 10 turns of copper tubing...
miKe mcKoffee wrote:Andy, do you have any idea how well this coil around Silvia's boiler inlet preheat method compares to your thermoblock method? I suspect it should work quite well but have no data or input to back it up.
I wonder what would happen if I put a heater in the reservoir and controlled it to 170F or something...
AndyS wrote:The inlet coil is, of course, purely a passive device, so there's only so much that it can do.
You're guesstimating 30ml for volume of water in 10 coils of tubing around Silvia's boiler?! Somehow me thinks that's way way low.AndyS wrote:Depends on the tubing of course, but for typical 1/4" OD, probably around 30 ml, maybe half the volume required for a double.
AndyS wrote:But lately, with this GS3 on my counter, I haven't been doing anything with Silvia. Maybe in a few weeks I'll get back to Silvia.
miKe mcKoffee wrote:You're guesstimating 30ml for volume of water in 10 coils of tubing around Silvia's boiler?! Somehow me thinks that's way way low.
What's the diameter of Silvia's boiler? I'll do the math...
My sincere apologies! Ran the math and you are of course correct for copper tubing with ID of 0.15". Never imagined over six feet of 1/4" copper tubing had such a small actual volume.AndyS wrote:coils = 8
tubing od = .25"
tubing id = .15"
dia boiler = 3"
ml/cu in = 16.4
I get ~24ml
Vibe pumps aren't designed for hot water. I think there's a max temp listed right on the pump. It's pretty low, IIRC.
