Hello:
Spironski wrote:At the time I was surprised that the screens had such different paterns ...
From what I can see, there is not just a difference in
pattern between the screens in the photo but also what seems (to me) to be a considerable difference in both the
size and
number of holes.
Provided I have counted right, the old screen has 80 holes and the new one has ~120.
Given that every other possible variable remained constant and if they were the same size, that would be an increase in hole surface / flow of almost 50%. Now, if you then take into account that the new screen's perforations appear to be ~ 25% larger, that makes quite a difference in 'screen performance' so to speak.
ie: the new screen is not behaving like the old one. Now you have a lot more water hitting the puck at 'contact' time than before, pre-infusion occurs at a much faster rate.
Now, is this the cause of your difference in taste? I really cannot say, but the screens are not the same, that's for sure.
Hope you sort it out.
Cheers,
CIV
