Should I keep my La Pavoni Europiccola or KitchenAid Proline espresso?
A haven dedicated to lever espresso machine aficionados.
Link to "Should I keep my La Pavoni Europiccola or KitchenAid Proline espresso?"by fishairflow on Mon Apr 28, 2008 10:01 pm
Hi guys...newbie here...just got an amazing deal at WS - picked up 1 La Pavoni Europiccola. Here is the problem. I drink about 1 cup of espresso in a week and so far have been using KitchenAid Proline Espresso machine.
Now comes in the picture La Pavoni - how does that stand against my KitchenAid Machine? I mean I know there is a steep learning curve and that I will end up using 3-4 lbs of coffee before I figure out where in the name of good lord is the lever, but I don't mind the time it would take to learn how to brew with this beautiful machine.
I keep reading some reviews and people are loving this machine but are referring to something called Cremina as a better lever machine ? I just want an entry level machine which I can use and abuse to learn how to make that espresso with beauty.
Should I stick with KitchenAid or take the next step ?
BTW - I paid 299 $ for both machines
fishairflow
Link to "Should I keep my La Pavoni Europiccola or KitchenAid Proline espresso?"by HB on Mon Apr 28, 2008 10:23 pm
Considering that you could resell the La Pavoni on eBay a few months from now for what you paid today, why not try it and decide later?
www.cafemakers.com: good coffee brings good business
Link to "Should I keep my La Pavoni Europiccola or KitchenAid Proline espresso?"by caeffe on Tue Apr 29, 2008 1:46 am
I may have a different experience due to the grinder I have...
I never quite experience this stated difficulty in getting a good shot using the europiccola. I may have choked 1 or 2 pulls and from it I learned when it is choking and when it is too easy to pull - whereupon the 'barista' learns to adjust to try and save the shot.
What I'm trying to say and ask - what grinder have you got it paired with? In my newbie experience, a good grinder will make a world of ease when using any manual lever.
LMWDP #162
caeffe
Link to "Should I keep my La Pavoni Europiccola or KitchenAid Proline espresso?"by TUS172 on Tue Apr 29, 2008 10:27 am
You are in 'Lever Head' territory and you're asking if you should continue with a la Pavoni Euro or a semi-auto KitchenAid? :roll: Hmmmm... Stick with the Pavoni.
Bob C.
(Now officially a lever purist!)
LMWDP #012
TUS172
Link to "Should I keep my La Pavoni Europiccola or KitchenAid Proline espresso?"by fishairflow on Tue Apr 29, 2008 11:34 am
thanks guys....I have read lot of threads..and in the Lever territory - is this a good starting machine with the right price?
Also - Does it matter that the portafilter is not 56 mm but is just 51mm? I never understood the significance but I was told by the guys at macys that bigger was better :)
fishairflow
Link to "Should I keep my La Pavoni Europiccola or KitchenAid Proline espresso?"by Cathi on Tue Apr 29, 2008 12:07 pm
My vote is to keep both until you've spent some time learning more about the Pavoni. I think that once you've had a chance to get to know the proper way to use it, you will prefer the results that you've hand-crafted rather than from a machine that makes the decisions for you. OTOH, if you decide that you don't have a preference or for whatever reason, Dan's advice makes sense.
Cathi
LMWDP #113
Cathi
Link to "Should I keep my La Pavoni Europiccola or KitchenAid Proline espresso?"by fishairflow on Tue Apr 29, 2008 2:30 pm
thank you guys....I will keep you posted...the machine should be here tomorrow or day after tomorrow....
BTW - Love how helpful people are here on the forum..... :)
fishairflow
Link to "Should I keep my La Pavoni Europiccola or KitchenAid Proline espresso?"by HB on Tue Apr 29, 2008 8:51 pm
fishairflow wrote:I never understood the significance but I was told by the guys at macys that bigger was better
Not so, I've had many enjoyable espressos from levers equipped with "small" portafilters (Elektra Microcasa a Leva - 49mm, Olympia Cremina - 49mm, Ponte Vecchio Lusso - 45mm). If you have a penchant for big gulp lattes, then I suppose a 58mm triple basket is worth considering.
Link to "Should I keep my La Pavoni Europiccola or KitchenAid Proline espresso?"by fishairflow on Wed Apr 30, 2008 3:10 am
just checked the UPS site...it is to be here tommorow (well in about 15 hrs)....
now - is having a pressure monitor on top of the machine important?
I can hardly wait....any suggestions as to what coffee I should use as the first one? I know this is blasphemy but starbucks is just around the corner....may be i can get by for 2-3 days till I get a chance to get some good stuff?
I remember once I tried O'doro Miscela Gusto coffee ( I got some beans from the local barista) and it was amazing - for the first time in my life I had seen good quality crema from kitchenaid machine. I hope I will get the same from this machine...
Will keep you guys posted...thanks.. :)
fishairflow
Link to "Should I keep my La Pavoni Europiccola or KitchenAid Proline espresso?"by zin1953 on Wed Apr 30, 2008 9:53 am
fishairflow wrote:. . . Does it matter that the portafilter is not 56 mm but is just 51mm? I never understood the significance but I was told by the guys at macys that bigger was better :)
That's because Macy's is bigger than Gimbel's . . . .
The diameter of the basket is close to, if not irrelevant. Notice that the "Four M's of Espresso" -- Macinazione [grind], Miscela [blend], Macchina [espresso machine, and Mano [the skilled hand of the barista] -- don't include one for basket . . . I have one machine which uses a "standard" 58mm ; my other one uses a 49mm basket -- both deliver great espresso!
Cheers,
Jason
P.S. Leave the KitchenAid; grab the Pavoni (with apologies to Francis Ford Coppola, although I think he'd approve).
zin1953
Link to "Should I keep my La Pavoni Europiccola or KitchenAid Proline espresso?"by fishairflow on Thu May 01, 2008 11:30 am
alright guys...got the machine yesterday...and played around with it...
1st. Made espresso with KitchenAid and La Pavoni -
The KitchenAid had certainly more crema but the coffee tasted VERY acidic
The La Pavoni - shot was much less acidic but very little crema...but this will change.
I had one problem though - while I was pulling shots on La Pavoni -
1st I raise the lever and wait for the group head to fill up with water - after about 10 seconds I push the lever down. - But half way down - there is no water coming out and there is very little resistance. I would then have to lift the lever again and do the same procedure.
Can you guys help please?
Thanks...
fishairflow
Link to "Should I keep my La Pavoni Europiccola or KitchenAid Proline espresso?"by fac10 on Thu May 01, 2008 3:35 pm
fishairflow wrote:...half way down - there is no water coming out and there is very little resistance...
The lack of resistance is caused by air in the piston chamber. I find that if I coordinate my pulls with the pressurestat, so that the lever is in the up position and the chamber starts to fill while the heater light is still on, I get more water and less air, and hence the resistance on the pull starts sooner, ultimately producing more shot volume. The pressurestat can usually be coaxed a bit by letting out some steam right before you're ready to start.
Recently I have also started using 4 or 5 micro-pulls during the pre-infusion stage, returning the lever to the top position each time to get a bit more water in. When this works correctly, the final pull starts with resistance and flow nearly from the top lever position. The trick is to work the micro-pulls fairly quickly, as going too slow can produce an over-extracted shot.
Before I started the micro-pull technique, I was using a single pre-infusion pull, and then raising the lever to replace the water before the final pull. But I found that even this small 1/4 pull for pre-infusion can cause problems when the lever is raised. The objective of the micro-pulls is to minimize the vacuum created above the puck, which tends to disturb the puck and cause channeling.
fac10
