A little background. I used to live about 1 block from a very good little coffee shop that could whip up whatever I needed Cappuccinos, lattes, even the occasional espresso shot. Then I moved about 3-4 hours away from the closest coffee shop the headaches and caffeine dt's sent me to order a refurbed gaggia and mdf. Now things are financially a little better so I'm shopping again
I would like to keep the budget somewhere around $1500, but I understand with a new grinder I may need to push closer to $2000. When it comes to type of machine HX versus Double boiler, ect I'm utterly confused because I have no experience with either. But I know I don't want to have to wait between pulling a shot and steaming milk.
It will be used daily, I usually make between 3-4 lattes each morning before work. I sometimes drink straight espresso's, but to be honest I can't seem to get a decent shot out of my machine. (I use fresh roasted beans ordered from Intelligentsia usually BC, rarely running over 2 weeks old). I tamp and believe I have the grind right based on what I've read here and on other boards. Ok, ok... To be honest the upgrade bug has bit me too
Anyway back to my original questions. I would like your input on equipment that would best fit my needs, because from what I've read most of you are coming from the same roots.
-Mainly milk based drinks, but some straight shots.
-Budget: around $1500 (I could be coaxed higher, but cost/benefit ratio + the WAF (wife acceptance factor
-Little to no turn around in-between multiple shots/steam sessions
-Wiring/plumbing not a problem I can do both, and I'm not afraid to learn certain eccentricities of various types of machines (see the HX flush)
Thanks for any input
