Abe Carmeli wrote:at least for a bottomless P/F, on a dual boiler machine, keep it at room temperature at all times.
terryz wrote:So......
How does the coffee taste?
Abe Carmeli wrote:It is reporting a much wider temperature variation within a shot than I expected. A typical variation on the machine I tested was 1.6-2f from the 10th second on. A ristretto will reduce it, but I was checking 60 ml flow in 25 seconds - a double. (it is fixed on the Thermofilter).
However, if I ran the shot on a cold P/F, the variation shrunk to 0.8f. About half. I consistently repeated the experiment, using the same flush routine, and repeated the result. The brew temp I reached was ~1.5 f lower than one I would reach had the P/F been in the machine at all times. However, it was repeatable.
The Thermofilter uses a bottomless P/F that has less mass than a regular one. My conclusion is: at least for a bottomless P/F, on a dual boiler machine, keep it at room temperature at all times.
Barry wrote:your conclusion does not necessarily follow from your evidence. it sounds like you're rejecting the results of the first method simply because you prefer the results of the second method. using a cold test instrument will pull some of the heat from the brew water sample, which would give you both a lower overall temp indication as well as attenuate some of the temp fluctuations.
Abe Carmeli wrote:I believe you lost me there. Do you mean to say that I prefer an 0.8f temp variation to 1.6f, and that preference dictated my conclusion? If so, you are perfectly right. And my followup question is who doesn't?
Abe Carmeli wrote:My conclusion is: at least for a bottomless P/F, on a dual boiler machine, keep it at room temperature at all times.
barry wrote:my point is it is very likely the .8F temp variation isn't. it's very likely you're getting the same 1.6F variation, only attenuated by thermal losses to the <cold> instrument.
HB wrote:Abe, are you saying the portafilter AND the thermofilter were cold?
Abe Carmeli wrote:Indeed so. But how would the results differ if I had cold P/F and coffee there, instead of the thermofilter puck? Greg says his puck and coffee share a similar heat index. So, wouldn't I get the same results?
barry wrote:it was not intended to simulate the thermodynamics of a coffee puck during brewing.
barry wrote: i think you're trying to infer more to this device than was intended. it was meant to provide a uniform means for measuring the water temperature at the upper water/coffee boundary. it was not intended to simulate the thermodynamics of a coffee puck during brewing. the coffee does attenuate fluctuations in water temperature; this device was designed to minimize that attenuation to better reflect machine brew water performance, not the whole machine/pf/puck dynamic.
--barry "hoping Greg writes some instructions for this thing"
barry wrote:Abe Carmeli wrote:I believe you lost me there. Do you mean to say that I prefer an 0.8f temp variation to 1.6f, and that preference dictated my conclusion? If so, you are perfectly right. And my followup question is who doesn't?
--barry "rose-colored glasses"
barry wrote:Abe Carmeli wrote:Indeed so. But how would the results differ if I had cold P/F and coffee there, instead of the thermofilter puck? Greg says his puck and coffee share a similar heat index. So, wouldn't I get the same results?
i don't think it's the plastic which is causing the results you're seeing; rather it's the heat loss to the probe itself, and to the exposed upper circumference of the portafilter basket.
also, i think you're trying to infer more to this device than was intended. it was meant to provide a uniform means for measuring the water temperature at the upper water/coffee boundary. it was not intended to simulate the thermodynamics of a coffee puck during brewing. the coffee does attenuate fluctuations in water temperature; this device was designed to minimize that attenuation to better reflect machine brew water performance, not the whole machine/pf/puck dynamic.
fwiw, the standardized testing protocol for this device calls for the espresso machine to be at operating temperature for at least an hour before the test, with the thermofilter in the brewhead during this warmup period.
--barry "hoping greg writes some instructions for this thing"
Walter wrote:barry wrote:it was not intended to simulate the thermodynamics of a coffee puck during brewing.
...and I venture to say it couldn't do that. Not even if it were intended to do it...
