Abe Carmeli wrote:I wish that were true, it would have made life easier for all of us. But in my experience, the intrashot result as measured with the Scace is sharply different than when measured with a T/C in the coffee puck a-la Schomer or by snaking the T/C over the lip. Scace will show a much wider temp variance than the coffee method. The coffee itself attenuates the reading. As an example, a stock home machine will show a 5f intrashot with Scace, while with coffee, it will show around 2-3f.
Maybe this discussion is more suitable for the Scace device thread, but as a response to Abe and Chris and my thoughts about the use of the Scace device method vs. Coffee Basket method:
What I observed with the 'Schomer method' in comparison to the data published at HB about the Scace device is a difference that's primarily in the first 5-6 seconds of the shot or so. In fact, the coffee method (if done properly, so that the probe is level and visible on top of the packed coffee) seems to get to target temp faster than the Scace method.
I was wondering: With the coffee method you have just a small room between shower screen and coffee puck to be filled with water until the probe is fully submerged in water. With the Scace thermofilter, in order to have the same water debit as the coffee method while having a solid 'puck', there's a larger volume to be filled up before the probe is completely submerged in brewing water. In your opinion, is there any chance that the slower growth with the Scace device (e.g. the graphs in Bob's post http://www.home-barista.com/forums/scace-thermofilter-temperature-device-t453-101.html) is related to filling up that volume, while the coffee method fills up the empty volume very fast and then starts soaking the puck with the rest of the water debit difference?
That would also mean, that a significant portion of the smaller differences in variability and higher average temps with the coffee method that some people observed can be attributed to what the probe 'sees' in these first few seconds. Which would further mean, one can't draw the conclusion, that the Scace method is more sensitive than the coffee basket method based on higher observed variabilities (as it 'picks up' wider variabilities), but this wider variability at the start of the shot is primarily a product of the used method?
And Chris, I'm writing this not to defend the relevance of the data I showed (you seemed to get impatient with me
Cheers,
Wolfgang
