www.klatchroasting.com: USBC champion, voted 2007 WBC 'best espresso'
Rush of steam from Pavoni Pro when pulling blank shot
A haven dedicated to lever espresso machine aficionados.
Link to "Rush of steam from Pavoni Pro when pulling blank shot"by Brendan on Tue Feb 28, 2006 5:16 am
Hi , well I aquired this machine a while back and it seems to make pretty good coffee but the more I read about them the more confused I get . One thing I don't understand is pulling a shot with nothing in the basket , I've heard people do this to clean out the group . If I try this as soon as I raise the lever I get a rush of steam going everywhere and burning my hands as I rush to shut it off . Do you think my machine needs new seals ? It was fairly old when I got it and I don't know if this has ever been done .I would appreciate any help with this problem
Regards Brendan
Brendan
Re: La Pavoni professional
Link to "Rush of steam from Pavoni Pro when pulling blank shot"by hbuchtel on Tue Feb 28, 2006 5:44 am
Brendan wrote:If I try this as soon as I raise the lever I get a rush of steam going everywhere ( . . . )
Regards Brendan
Where is the steam coming out from?
Can you stop it by lowering the lever?
Henry
LMWDP #53
hbuchtel
Link to "Rush of steam from Pavoni Pro when pulling blank shot"by Brendan on Tue Feb 28, 2006 4:02 pm
The steam gushes out the porta filter where the coffee usually comes out . It stops as soon as I lower the arm .
Brendan
Brendan
Link to "Rush of steam from Pavoni Pro when pulling blank shot"by hbuchtel on Wed Mar 01, 2006 5:22 am
Is there only steam coming out or water as well?
Henry
hbuchtel
Link to "Rush of steam from Pavoni Pro when pulling blank shot"by Brendan on Wed Mar 01, 2006 3:43 pm
Steam and water Henry.
Brendan
Link to "Rush of steam from Pavoni Pro when pulling blank shot"by hbuchtel on Wed Mar 01, 2006 10:02 pm
Sounds good to me. At normal operating temperature the pressure in the boiler is quite high (around 1 bar) so the water should come gushing out as you described.
What does your boiler pressure gauge read when you are doing this?
Henry
hbuchtel
Link to "Rush of steam from Pavoni Pro when pulling blank shot"by Brendan on Thu Mar 02, 2006 4:59 am
Boiler pressure at the gauge say 1-1.5 . Are you saying what is happening is normal ? It's just I read about these people pulling blank shots to clean out the pf I suppose , and it seems a bit dangerous to me . Thanks for your input
Brendan
Brendan
Link to "Rush of steam from Pavoni Pro when pulling blank shot"by Mark08859 on Thu Mar 02, 2006 10:15 am
I also will run some water through the group after brewing in order to help clean it. When I hold the lever by its handle, however, steam never touches my hand. Perhaps you should do it w/o having the PF attached. That may be affecting the direction of the steam. Also, have you tried bleeding off some steam prior to running water through the group?
Mark08859
Link to "Rush of steam from Pavoni Pro when pulling blank shot"by srobinson on Fri Mar 03, 2006 12:04 am
As the guys say, this looks pretty normal based on your description. If you want to see a violent blank shot, you should do a first pull on the Elektra A3.
Steve Robinson
LMWDP #001
srobinson
Link to "Rush of steam from Pavoni Pro when pulling blank shot"by Brendan on Fri Mar 03, 2006 3:11 am
Thanks
Brendan
Link to "Rush of steam from Pavoni Pro when pulling blank shot"by espressoperson on Fri Mar 03, 2006 9:56 am
Brendan wrote:Boiler pressure at the gauge say 1-1.5 . Are you saying what is happening is normal ? It's just I read about these people pulling blank shots to clean out the pf I suppose , and it seems a bit dangerous to me . Thanks for your input
Brendan
Find a pitcher or mug that you can slip under the grouphead and that is high enough to confine the steam/water. It's safer and also keeps the drip tray from filling up.
MichaelB, LMWDP #24
espressoperson
