Rumour of Dual Boiler, PID, Rotary Vibiemme: appears to be true - Page 3
Link to "Rumour of Dual Boiler, PID, Rotary Vibiemme: appears to be true"by Abe Carmeli on Fri Feb 29, 2008 7:59 am
Kudos to Jim and Vibiemme for pushing in that direction. Since this is still in development, a couple of points to improve the design:
It appears that the temperature controller is showing 102 c (215 f). That is obviously brew boiler temperature as opposed to brew temperature - an offset function on the controller would fix that. (this is only a convenience enhancement of course). The resolution appears to be 1c. I hope that the US model will use fahrenheit or have a 0.5c degree resolution. If you bother to use a PID design, why not utilize it.
Perhaps the reason for the 1c resolution is inherent in the design. Without preheating the water entering the brew boiler, (H/X in the steam boiler a'la synesso or a mixing valve a'la GS3) 0.5c resolution is questionable. The machine may not be able to produce it consistently.
Abe Carmeli
Abe Carmeli
Link to "Rumour of Dual Boiler, PID, Rotary Vibiemme: appears to be true"by Jacob on Fri Feb 29, 2008 8:29 am
1 C resolution is maybe OK for the display, but not for setting the target for the brew-temp IMHO
Yesterday I asked at a Danish forum about the possibility to change the setting to Fahrenheit and today a new owner told us that it's indeed possible on his European 230v model - He found some menus that others had missed and tonight they all go looking for even better target-resolution hidden in these menus :D
Jacob
Link to "Rumour of Dual Boiler, PID, Rotary Vibiemme: appears to be true"by MoBak on Fri Feb 29, 2008 8:35 am
Abe Carmeli wrote:It appears that the temperature controller is showing 102 c (215 f). That is obviously brew boiler temperature as opposed to brew temperature - an offset function on the controller would fix that. (this is only a convenience enhancement of course). The resolution appears to be 1c. I hope that the US model will use fahrenheit or have a 0.5c degree resolution. If you bother to use a PID design, why not utilize it.
Hi Abe,
This has actually been discussed quite a lot on espressobar.dk. The user guide that come with the machine don't say anything about the possibility to switch to Fahrenheit, but actually one of the guys who already bought the machine found that that it is possible. The conclusion from the users on EspressoBar was exactly as you say, that by changing to F you get a detail of around 0.5c. And that should be good enough.
But the PID Controller also has 3 other menus, that are not described. Maybe in some of these menus you are even able to adjust decimals. I have borrowed a machine for a week to test it and make a review of it. I'm trying to figure out which possibilities the menus give.
EDIT: You beat me with a few minutes, Jacob :)
MoBak
Link to "Rumour of Dual Boiler, PID, Rotary Vibiemme: appears to be true"by Jacob on Fri Feb 29, 2008 8:39 am
:lol:
Be careful not change the PID 'system-settings' :wink:
Jacob
Link to "Rumour of Dual Boiler, PID, Rotary Vibiemme: appears to be true"by Fore on Fri Feb 29, 2008 11:02 am
I heard the rotary plumbed in isn't avail. till this fall? Wish this first version had also been a rotary.
Fore
Link to "Rumour of Dual Boiler, PID, Rotary Vibiemme: appears to be true"by MoBak on Sat Mar 01, 2008 4:59 am
I've now tried to use the machine in Fahrenheit mode. Unfortunately it does not make it more accurate, since you can only adjust it in steps of 2 F degrees
MoBak
Link to "Rumour of Dual Boiler, PID, Rotary Vibiemme: appears to be true"by Jacob on Sat Mar 01, 2008 5:36 am
:shock: If you only can set the target temperature to 200 or 202 F, you can be sure that the perfect temperature would have been 201 F! This means that the machine 'per definition' will be 1 F off (+/- any instability) :roll:
Jacob
Link to "Rumour of Dual Boiler, PID, Rotary Vibiemme: appears to be true"by RapidCoffee on Sat Mar 01, 2008 10:26 am
Gregg K wrote:It's pretty poor quality video, but anything that will calm me in my anxious anticipation is good.
Not just the video quality that looks poor. 34 seconds into the video, the pressure ramps up to 9 bars. By the time the videographer pans back to the shot, just a few seconds later, it's already blonded. Yuck!
John
RapidCoffee
Link to "Rumour of Dual Boiler, PID, Rotary Vibiemme: appears to be true"by Fore on Sat Mar 01, 2008 10:57 am
Boy that's surprising, 2F PID controlled. I thought it'd be more accurate than that.
Fore
Link to "Rumour of Dual Boiler, PID, Rotary Vibiemme: appears to be true"by cannonfodder on Sat Mar 01, 2008 6:48 pm
RapidCoffee wrote:Not just the video quality that looks poor. 34 seconds into the video, the pressure ramps up to 9 bars. By the time the videographer pans back to the shot, just a few seconds later, it's already blonded. Yuck!
I noticed that as well. It was not an appetizing shot. That PID range does not sound right. We will have to see if there is a difference in the US version, they should be landing soon.
cannonfodder
Link to "Rumour of Dual Boiler, PID, Rotary Vibiemme: appears to be true"by zin1953 on Sat Mar 01, 2008 7:14 pm
I think we ALL hope so, Dave -- I know I do.
zin1953
Link to "Rumour of Dual Boiler, PID, Rotary Vibiemme: appears to be true"by MoBak on Sun Mar 02, 2008 4:55 am
Probably why he calls the video "Fast shot...", don't you think?
Visit our new website about WBC: www.WBConEspressoBar.com
MoBak
Link to "Rumour of Dual Boiler, PID, Rotary Vibiemme: appears to be true"by Jacob on Sun Mar 02, 2008 5:35 am
MoBak wrote:Probably why he calls the video "Fast shot...", don't you think?
Too easy and not good enough - as a pro shop, they need to show a decent shot (no matter how many shots it takes)!
Sorry MoBak for not replying to your 'besked' at espressobar.dk - I first saw it late last night (I'm, as you know, new to that forum).
Jacob
Previous
Return to Espresso Machines
