orwa wrote:In my case, the puck appearance is most often dependent on how fresh the coffee is. That is, I get levelled, nice and dry pucks that come off easily when the beans are allowed to rest for sufficient time after roasting, whereas I get this sort of a wet surface otherwise. This, along with other observations regarding how over-temperature brewing effects the puck apearance/characteristics, makes me think that in my case, the appearance of the puck is easily correlated with brewing quality. For example, when the coffee do not rest for enough time, the wet-appearance of the puck correlates with the taste imperfections that you cannot avoid in a coffee that has not rested for enough time. Also, when the water temperature is too high, you get a layered puck that doesn't neatly get knocked off at once but rather comes off in layers, or will lead to the part of the puck adjacent to the bottom of the basket to adhere to the metal. On the other hand, when the water temperature is too cold, this do not effect the puck but manifests itself in the light crema, and the shallow extraction. These are my humble reservations with regard to how the puck looks like on my Professional and how it correlates with some factors.
Moreover, I would like to comment that it is still reasonable to demand a nice and dry puck that comes off at once with a (direct-)lever machine even though there is no direct mechanism to release the pressure from the group immediately after brewing. This is because of the good amount of very hot air that resides above the brewing water within the group, or within the brewing chamber, which very effectively dries the puck at the end of the extraction in case the lever was pulled all the way down. I even use that feature to dry the second-type pucks after steaming milk by simply raising the lever, locking in the portafilter and just leaving the lever. The steam power at the point of frothing will then be sufficient to dry the puck automatically in a cool fashion.
Wow!...all such good stuff....much applies to me, I'm afraid....
I've been home roasting 7 years, and am pretty sure my 5 day rested blend (which has been complimented by several CG'ers and GCC folk) is not the culprit. A very nice blend in my Anita.
I suspect it's partly technique, funky temperature (layered pucks have been a problem using the CMH grinder, though I'm pretty sure thru no fault of the grinder) and maybe my inexpertiness with the flat bottomed Reg. I had the very slight curved 58 Reg previously.
Anyone with a convex they want to sell?
I really appreciate the time you took to reply. I just SO messed up right now!
