Rotary pump cup clarity achievable with a mod ?
Link to "Rotary pump cup clarity achievable with a mod ?"by cannonfodder on Wed Aug 17, 2005 8:10 pm
I may be mistaken, but Malachi's 'clarity in the cup' pointed heavily to the constant pressure that a rotary pump delivers as being one of the major contributing factors in the cup clarity? It took a few reads to wrap my novice mind around the discussion. If that is the case, wouldn't the average home user with our modest barista skills, be able to achieve a relatively comparable cup by simply replacing our vibratory pumps with a rotary? That would eliminate the need to upgrade a perfectly good 'prosumer' machine to the next level (which is essentially the exact same machine with a rotary pump).
I ask the question because I was reading the Synesso thread and the remarks about its cost. Could I theoretically get the same results by modifying my HX to a rotary? I also have to inject that I have no idea what a rotary pump would cost so in the end it may still be cheaper to upgrade to something like a Wega. I am just thinking of the 'next step' in my espresso progression, but that is a year off (or maybe a 06 swagfest article :wink:).
cannonfodder
Link to "Rotary pump cup clarity achievable with a mod ?"by malachi on Wed Aug 17, 2005 9:28 pm
Actually, you need stability in pressure and stability in temp.
malachi
Link to "Rotary pump cup clarity achievable with a mod ?"by framey on Wed Aug 17, 2005 9:38 pm
Just on cost of rotary pumps, here in Australia a spare part price for a typical rotary pump is $350 ish and a vibratory pump runs at about $100
I'm sure I've seen photos where someone had put a smaller than usual rotary pump into a Silvia...?
-Stephen-
framey
Link to "Rotary pump cup clarity achievable with a mod ?"by cannonfodder on Wed Aug 17, 2005 10:10 pm
But assuming you could attain a serviceable temp stability, would the pump upgrade make a marked increase in the cup? Now as Framey stated, $350 for a rotary pump, plus added mods/plumbing to the existing machine quickly makes this an unwise modification. I could sell my existing machine and for the price of the upgrade, get a higher quality machine, which would address both issues.
I take it from comments and debates I have seen, that the best option for temp stability would be a dual boiler with a saturated group. That would eliminate the cooling flush, get the timing just right and I can hit my target temp, routine of a HX. You also need a boiler of adequate volume to match you duty cycle and heating elements large enough to match your shot to shot timing (recovery).
One factor that complicates the issue is constant blend changing. I rarely roast back-to-back identical blends. Different blends prefer different temps so it would be a constant temp adjustment. The only reliable, and simple, way to do that would be with a PID controller. The only system I have seen with that (in a reasonable home price range) is the Brewtus, but you sacrifice boiler size and the rotary pump. So you are back to square one. It does not look like I will be able to avoid the $2k price range when the time comes, unless someone puts out a new machine.
cannonfodder
Link to "Rotary pump cup clarity achievable with a mod ?"by malachi on Wed Aug 17, 2005 11:50 pm
cannonfodder wrote:One factor that complicates the issue is constant blend changing. I rarely roast back-to-back identical blends. Different blends prefer different temps so it would be a constant temp adjustment. The only reliable, and simple, way to do that would be with a PID controller. The only system I have seen with that (in a reasonable home price range) is the Brewtus, but you sacrifice boiler size and the rotary pump. So you are back to square one. It does not look like I will be able to avoid the $2k price range when the time comes, unless someone puts out a new machine.
Actually... I disagree.
I average between 3 and 12 different coffees a week.
With a good understanding of the temp drop over time and practice, flushing is reliable and simple.
For me, the great advantage of an HX machine is the flexibility you get with brew temp. I can pull 10 shots in a row at 10 different brew temps if I want, or I can pull a couple shots of one coffee and then a couple of another - without brew temp issues.
malachi
Link to "Rotary pump cup clarity achievable with a mod ?"by Walter on Thu Aug 18, 2005 6:43 am
Wow, Chris jumping in with a pro HX argument... ;)
But I agree, I use different coffees on a daily base and even though I am fairly new to the business I find it quite easy to adjust my Butterfly's temperature for different roasts/blends.
Cannonfodder you know of Ken Fox's and Jim Schulman's comparison Junior vibe vs. Junior rotary? Since I first read that thread on alt.coffee I've wondered how representative this comparison was and also whether or not it's applicable to the general Vibe vs Rotary disputes. (Now don't get me wrong I don't question their results, but I wonder if such a comparison e.g. on an E61 machine would result in different conclusions)
But I've pondered too about Chris' "Elusive Clarity", where such minimal changes - IIRC, that is - in the chain as omitting the filter seemingly caused major differences in taste. Makes one wonder if such a test with a vibe-machine would produce similar results...
My own interpretations of this effect always seem to end up with what happens in the brewhead. The pump (vibe as well as rotary) generates a more or less laminar flow of hot water, but as soon as this water enters the grouphead/shower the pressure drops and the flow becomes turbulent. This not only makes the extraction process less "linear" it also should cause - significant, IMO - temperature changes on a microscopic level.
To cut the long story short, my hypothesis is, that the turbulence in the grouphead have a somewhat detrimental effect on the taste - especially to what Chris refers to as "clarity" - of the espresso and that instead a laminar flow in the cake should be able to provide this. But on the other hand, this also would probably reduce or even minimize crema...
Walter
Link to "Rotary pump cup clarity achievable with a mod ?"by cannonfodder on Thu Aug 18, 2005 9:33 am
Don't misunderstand my comment about the cooling flush routine. I agree with both of you that a stable temp can be achieved. I use a HX now and am perfectly happy with it at this time. I was just thinking of taking one of the existing variables out of the mix. It is just one less thing to worry about in the morning routine (read this as lazy).
It is definitely something to contemplate when it is time for the next upgrade. But as to my original question, would a rotary pump make a significant improvement in the cup, I am leaning toward a solid maybe as an answer. It sounds like there are too many other considerations. The cost/time vs. cup improvement in modifying my existing machine does not appear to justify itself.
I did not know of Schulman's comparison on alt.coffee, I will have to look it over. I just changed my ISP and have not had time to set up the usenet account. I don't spend much time in the news groups anymore.
The more I learn, the more I realize how much more there is to learn.
cannonfodder
Link to "Rotary pump cup clarity achievable with a mod ?"by HB on Thu Aug 18, 2005 9:58 am
I've not done a side-by-side comparison of rotary versus vibration pumps. But given the care Jim and Ken put towards attempting to discern a difference while finding little, I'm doubtful it's a worthwhile consideration for your average home barista except for the quiet it affords. That said, if I went through the trouble of a conversion, I would replumb to enable the E61 lever's "mid position" for preinfusion under line pressure. It's my hunch that enhancing the machine's preinfusion a la the Synesso would make a bigger improvement than the rotary conversion.
Link to "Rotary pump cup clarity achievable with a mod ?"by Abe Carmeli on Thu Aug 18, 2005 10:21 am
HB wrote: That said, if I went through the trouble of a conversion, I would replumb to enable the E61 lever's "mid position" for preinfusion under line pressure. It's my hunch that enhancing the machine's preinfusion a la the Synesso would make a bigger improvement than the rotary conversion.
This is a good point, and right on time. I'm starting my rotary conversion next week, and preinfusion was near the top on my list. Rotary ramps up pressure immediately to set pressure on a home E61. The preinfusion chamber works well with a vibe pump, but once you convert to rotary, it will go to max pressure in about 2 secs. A little too fast for real preinfusion.
Abe Carmeli
Abe Carmeli
Link to "Rotary pump cup clarity achievable with a mod ?"by Walter on Thu Aug 18, 2005 10:47 am
So, does that mean that preinfusion on E61 machines hasn't really worked all those decades before the E61 made it onto the prosumer machines with their petty vibe-pumps? :?
Walter
Link to "Rotary pump cup clarity achievable with a mod ?"by HB on Thu Aug 18, 2005 10:57 am
Yes, that's one way of putting it.
If you look at the brew pressure gauge of some plumbed-in machines, they will be at line pressure whenever the pump isn't running (assuming there's no solenoid cutoff). The pump doesn't engage until the end of the stroke and raising the lever halfway will allow water to flow under line pressure. That is, water is still coming through the same pathway (i.e., through the pump); in one case it is "passive" from line pressure, the other time it's being driven by the pump's vanes.
Obviously the temperature of the incoming water is the same in both cases. This is part of the original E61 design intent. I understand some cafes used a tank on the second floor to provide the static pressure... I think that Schomer describes this setup in his book.
Link to "Rotary pump cup clarity achievable with a mod ?"by AndyS on Thu Aug 18, 2005 8:05 pm
malachi wrote:Actually, you need stability in pressure and stability in temp.
Keeping in mind that in our little coffee world, the word "stability" remains ill-defined.
Some folks think stability means that the average temperature and pressure of each shot is the same within a certain tolerance. Schomer says temperature stability means a ruler-flat temperature curve throughout the extraction. Other folks want to see the particular "profile" (rising or falling curve) of temperature and pressure to be the same for every shot. Recently malachi went a step further and theorized that 60-120 hz pressure pulse vibrations during an otherwise perfect pressure profile might be detrimental.
There are different definitions of "stability."
-AndyS
AndyS
Link to "Rotary pump cup clarity achievable with a mod ?"by AndyS on Thu Aug 18, 2005 8:11 pm
HB wrote:I've not done a side-by-side comparison of rotary versus vibration pumps. But given the care Jim and Ken put towards attempting to discern a difference while finding little, I'm doubtful it's a worthwhile consideration for your average home barista except for the quiet it affords.
Nothing in espresso is EVER settled with one test. In this case, Jim proved that the espresso made by one vibe-equipped Cimbali Junior wasn't significantly different from the espresso made by a different, rotary-equipped Junior. This was a really neat experiment, but we shouldn't regard it as a universal proof.
-AndyS
AndyS
Link to "Rotary pump cup clarity achievable with a mod ?"by HB on Thu Aug 18, 2005 10:06 pm
Abe Carmeli wrote:The preinfusion chamber works well with a vibe pump, but once you convert to rotary, it will go to max pressure in about 2 secs. A little too fast for real preinfusion.
The preinfusion for the Microcasa is all manual; I wait ten seconds during which the brew pressure is 1.2 bar. The E61 vibration pump machines I've tested reach max pressure in six seconds, maybe a little less. The three rotary (non E61) machines I've looked at closely (La Spaziale S1, Cimbali Junior and Elektra A3) rocket up the pressure in a few seconds; droplets are forming in four. The Lineas I've tried behaved similarly, i.e., the pour starts long before it would for an E61 / vibration pump.
And yet the extractions from the A3 are sooooo-o-o much easier than other rotary pump machines I've tried, and the only thing I can point to is the effects of preinfusion. Hey, that's only three seconds... how'd it happen so quickly and effectively? This observation is forcing me to rethink the importance of the length of the "preinfusion pause", a thought which leads me to a concrete question:
    What's the programmed prefusion delay for the Synesso Cyncra?
Background: I briefly used the Synesso Cyncra in the BGA booth at the SCAA conference in Seattle. As I understood it, you had the choice of a manually selected preinfusion delay by pushing the pump switch halfway across, or a programmed preinfusion delay by pushing it straight across. It seemed like the pour commencement times were consistent with other commercial machines, but like I said, I only used it briefly... Chris or other Synesso fan, would you fill in the details?
Link to "Rotary pump cup clarity achievable with a mod ?"by barry on Thu Aug 18, 2005 10:56 pm
cannonfodder wrote:Now as Framey stated, $350 for a rotary pump, plus added mods/plumbing to the existing machine quickly makes this an unwise modification.
it's not nearly that expensive to do. off the top of my head, it should be around $150.
barry
www.cafemakers.com: good coffee brings good business
Link to "Rotary pump cup clarity achievable with a mod ?"by Abe Carmeli on Thu Aug 18, 2005 11:03 pm
barry wrote:it's not nearly that expensive to do. off the top of my head, it should be around $150.
I am in a middle of a rotary conversion now. Small pump & motor will cost ~ $200-250.00. Tubing, fittings, line pressure regulator, gauge, valves ~ $70-150 depending on options you chose.
Abe Carmeli
Abe Carmeli
Link to "Rotary pump cup clarity achievable with a mod ?"by barry on Thu Aug 18, 2005 11:47 pm
Abe Carmeli wrote:I am in a middle of a rotary conversion now. Small pump & motor will cost ~ $300.00. Tubing, fittings, line pressure regulator, gauge, valves ~ $70-150 depending on options you chose. If you go with a commercial machine pump and motor, add another $200.00
i suggest you consider different equipment sources.
barry
Link to "Rotary pump cup clarity achievable with a mod ?"by FXDXT on Thu Aug 18, 2005 11:50 pm
This is not a true statement for all E61 rotary pump machine.
When I adjust the pressure on my Lyra the pressure starts off slowly and increases in speed until it reaches 130 psi. This action takes about 7 to 9 seconds, if memory services me correctly. I am not using a cheap gauge. My current set up is an Ashcroft test gauge. http://www.ashcroft.com/products.cfm?doc_id=117
Is this not preinfusion?????
Tom
FXDXT
Link to "Rotary pump cup clarity achievable with a mod ?"by JonR10 on Fri Aug 19, 2005 6:00 am
FXDXT wrote:When I adjust the pressure on my Lyra the pressure starts off slowly and increases in speed until it reaches 130 psi. This action takes about 7 to 9 seconds, if memory services me correctly.
My experience matches Tom's exactly. I can't say if this is a pre-infusion because the pump does engage instantly, but I can say for sure that it takes several seconds for pressure to start building. Once the pressure begins to build then it ramps up very quickly.
JonR10
Link to "Rotary pump cup clarity achievable with a mod ?"by AndyS on Fri Aug 19, 2005 6:22 am
HB wrote:The three rotary (non E61) machines I've looked at closely (La Spaziale S1, Cimbali Junior and Elektra A3) rocket up the pressure in a few seconds; droplets are forming in four. The Lineas I've tried behaved similarly, i.e., the pour starts long before it would for an E61 / vibration pump.
This is easily fixed with a gicleur (orifice) downstream of the pump. Most people use 0.6-0.8mm). Bill Crossland from ESI said that the automatic Lineas shipped without gicleurs, but the semiauto Lineas generally had them. Presumably this was because if you were a semiauto barista, you cared.
On my rotary Silvia I used a 1/8" needle valve rather than a fixed orifice. This allows me to adjust the length of "preinfusion" to just about anything.
Dan, what is it about the A3 that made its "preinfusion" different from the others?
-AndyS
AndyS
Next
Return to Espresso Machines
