TimEggers wrote:I have begun my attempts at understanding the drying stage and how it correlates to the other aspects later in the roast such as the conversion of starches to sugars and then the caramelizing of those sugars.
Maybe "drying" is the wrong term, and iot shoub be more like "even heating to 300F." The symptoms of too short a dry phase are chlorogenioc acid tastes (green-bitter/bright) in the roast, especially it's a light one, and inadequate caramelization.
Two things happen between 300 and roughly 380F. First the Maillard reactions start, these turn sugars and amino acids into flavor compounds. Secondly, the remaining water in thebean turns to steam, starting at the center, where the pressure builds to around 15 bar and working outward in a coherent front (this from Illy). The energy required to create the high pressure steam depressed the temperature at the center of the bean. If the temperature of the coffee is not equalized before this it gets extreme by the time the fiorst crack is reached.
The first crack is the point where this steam fron breaks out of the bean. It is also the point where sugars begin to caramelize, and fruit acids, including the chlorogenic ones break down. Even in the best roasts, the beans become uneven at this point, and one wants to slow the roast, so the beans even out in color by the time the first crack starts slowing down. If this is done, one can stop the roast at any lightness with good results. If the temperature differencs are extreme, as in too fast a start, the beans never even out unless one bakes all the flavor out.
However, one can overdry the beans. Water is needed for the Maillard reactions and for caramelization, so a very dry bean will get flat. In the experiment where we pulled iudentical profiles for air and drum roasters, the air roasted beans tasted flatter (an effct only apparent experts, so quite subtle). This is why four to five minutes, maybe even three, is sufficinet for this stage in an airroaster, while one needs around 7 minutes in a drum.
The safes way is to initially roast the beans by sight, and keep them ibelow 300F until they all are a uniform yellow, but no longer than that. I thinkl 4 to 5 minute is about right for most airroasters, although 3 might be the ticket for very dry beans (say old crop ones), and 6 for excesively moist ones.
