Roast Length for Aged & Monsooned
Link to "Roast Length for Aged & Monsooned"by kahu on Tue Apr 17, 2007 11:22 pm
In the article on espresso blending the author, when mentioning aged or monsooned coffees, says "a nice long drawn out roast will eliminate much of the musty tastes of Indonesian coffees and bring forward the buttery chocolates."
So what is a long drawn out roast? An air roaster is going to finish much faster than a Hottop or a Gene Cafe, so what roast is recommended for each of these types for the aforementioned coffees? I have the Gene Cafe and tend keep it high to bring coffees up to the beginning of 1st crack (10 mins), then turn down to 455-460 to finish the roast, per recommendation of Sweet Marias. FC+ usually ends up at 15-17 minutes with manual stop and external fast cooling.
Thanks for any ideas.
kahu
Link to "Roast Length for Aged & Monsooned"by another_jim on Wed Apr 18, 2007 2:24 am
Indos and MMS tend to have high water content, so a minute longer warm up (up to bean temp of 300F) is a good idea. Drawing out the time from 300 to first crack isn't so brilliant, since it will accentuate the woody flavors. Where drawing out pays out with these is after the first crack (above 390 to 400 bean temp). This will lower the environmental temperatures and lower the second crack temperatures. You want to go to a rolling second for these.
With a commercial drum, lower the drop in, higher heat than usual to the first, than back off the heat more than usual. If you have an airroaster, you'll need to bean temp and variable heat, in which case you can follow the profile directly.
another_jim
www.eccocaffe.com: custom coffee roasted in Northern Italian style
Link to "Roast Length for Aged & Monsooned"by kahu on Wed Apr 18, 2007 11:36 am
Thanks, Jim. So since I am using the Gene Cafe, I'm thinking I'll set the temperature to 350, hold it for a minute when it reaches that point (since that's not actually the bean temp), then crank it up for first crack.
On a related note, I have to say the Monsooned aromas while roasting are the most beguiling of the dozen or so types of beans I've roasted so far.
kahu
Link to "Roast Length for Aged & Monsooned"by hbuchtel on Mon Apr 23, 2007 9:26 am
kahu wrote:On a related note, I have to say the Monsooned aromas while roasting are the most beguiling of the dozen or so types of beans I've roasted so far.
I've noticed that too! A real sweetness around 1st crack, right?
Henry
LMWDP #53
hbuchtel
Link to "Roast Length for Aged & Monsooned"by kahu on Mon Apr 23, 2007 11:01 am
Hi Henry,
Yeah, but it's more than a sweetness, something that makes you sort of sit up and say, hey, now that's different! No doubt it's all the mysterious aromas the beans pick up over that year of aging.
Jeff
kahu
Return to Home Roasting
