The risk of using a timer
Link to "The risk of using a timer"by Fullsack on Sat Dec 29, 2007 11:32 am
The boiler cap leaked and this morning I had an empty boiler and no power. Looks like I am in for at least a new heating element, but maybe a new boiler, pressurestat and reset mechanism as well.
Notice how the pressurestat and reset mechanism are leaning downwards, it must have gotten pretty hot.
Doug Jamieson
Full Sack Jack Coffee Roasters
LMWDP #017
Fullsack
Link to "The risk of using a timer"by cafeIKE on Sat Dec 29, 2007 4:26 pm
One advantage of a PID is that it won't allow the temperature to go over the upper alarm temperature, 255°F here.
Whether that will save the heating element is as yet undetermined. :wink:
cafeIKE
Link to "The risk of using a timer"by Psyd on Sat Dec 29, 2007 4:30 pm
Fullsack wrote:The boiler cap leaked and this morning I had an empty boiler and no power. Looks like I am in for at least a new heating element, but maybe a new boiler, pressurestat and reset mechanism as well.
I'm not sure exactly what I'm looking at, here, 'Sack. You mean that the boiler drained overnite, and while you slept the timer turned the element on and superheated the boiler?
I'm not sure that the timer is the culprit in that scenario, but maybe I misunderstood. If it had been on in a 24/7 manner, it would have had the same result?
What am I misunderstanding?
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Link to "The risk of using a timer"by HB on Sat Dec 29, 2007 6:11 pm
Fullsack wrote:Notice how the pressurestat and reset mechanism are leaning downwards, it must have gotten pretty hot.
Thanks for posting the photos. I don't understand why the over-temperature safety didn't cut off the power. If it's like other steam boilers, it should have tripped around 165C. The Lusso also has a low-water shutoff. Why didn't it cut off power?
I fried a heating element once... the heat bent it around so tightly, I had to pry it out of the boiler. :shock:
Link to "The risk of using a timer"by Fullsack on Sat Dec 29, 2007 9:38 pm
Psyd wrote:I'm not sure exactly what I'm looking at, here, 'Sack. You mean that the boiler drained overnite, and while you slept the timer turned the element on and superheated the boiler?
That's about it, not the timers fault, I was trying to do to many things at once and didn't tighten the boiler cap enough. If I was awake during the meltdown, I probably would have heard it and saved myself from this mess.
If you turn on a machine manually for a 24/7, you are usually around when the pressure first builds, so these types of stumbles can be headed off before they become damaging.
Doug Jamieson
LMWDP #017
Fullsack
Link to "The risk of using a timer"by Fullsack on Sat Dec 29, 2007 9:53 pm
HB wrote:Thanks for posting the photos. I don't understand why the over-temperature safety didn't cut off the power. If it's like other steam boilers, it should have tripped around 165C. The Lusso also has a low-water shutoff. Why didn't it cut off power?
No idea why, but the little red button never popped. Same thing wrecked our Thanksgiving turkey one year :)
There wasn't a drop of water in it.
My heating element isn't budging either, the Lusso may be totaled.
Doug Jamieson
LMWDP #017
Fullsack
Link to "The risk of using a timer"by terryz on Sun Dec 30, 2007 5:46 pm
I wouldn't say totaled ( unless that is what you want :wink: ) but it did get hot didn't it!
If the element will not loosen up, try tightening first and then loosen. Replace the thermo reset and the P-Stat for sure. It seems that you had quite an event, as it is rare to have the P-stat stick, and a thermo switch fail, but it is an espresso machine after all, so I guess anything is possible.
Terry Z
Chief Reality Administrator
Espressoparts.com
terryz
Link to "The risk of using a timer"by Fullsack on Tue Jan 01, 2008 8:53 pm
terryz wrote:I wouldn't say totaled ( unless that is what you want :wink: ) but it did get hot didn't it!
Thanks Terry, the tightening first trick worked, good thing, it's a great machine and I'd hate to have seen it turned into a parts horse.
Doug Jamieson
LMWDP #017
Fullsack
Link to "The risk of using a timer"by Psyd on Fri Jan 04, 2008 3:01 pm
Doug, is this you guys?
Had to know what the heck Full Sack Jack Coffee Roasters was. If it is, lemme know if you can find lodging and coffee for a location sound mixer.... ; >
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Link to "The risk of using a timer"by Fullsack on Fri Jan 04, 2008 10:04 pm
Psyd wrote:Doug, is this you guys?
It's Josh's story, I guess that's how he imagines us :) Get a hold of Josh, if it works out, you can crash at my place.
Doug Jamieson
LMWDP #017
Fullsack
Link to "The risk of using a timer"by narc on Fri Jan 04, 2008 10:47 pm
Doug, is your Lusso boiler missing the low water cut off unit? Or did you remove it before taking the photo? Initially I found this "safety" switch a bit of a pain. But now I'm thinking maybe a good thing. Good to hear you are able to salvage the Lusso.
noel v.
Noel'sAritisanRoastingCompany(NARC)
LMWDP #151
narc
Link to "The risk of using a timer"by Fullsack on Mon Jan 07, 2008 2:35 am
narc wrote:Doug, is your Lusso boiler missing the low water cut off unit? Or did you remove it before taking the photo? Initially I found this "safety" switch a bit of a pain. But now I'm thinking maybe a good thing. Good to hear you are able to salvage the Lusso.
Noel,
I saw the "Cannonfodder" Lusso pictures, (great photos!), on the "Smackdown" thread, so now I know what you're talking about. No, my Lusso never had that. Mine must be an older model, my pressure gauge is different as well.
Doug Jamieson
LMWDP #017
Fullsack
www.dailygrind.com: artisian roasted coffee and espresso equipment
Return to Espresso Machines
