(split from My new Elektra Microcasa a Leva by moderator...)
Karl,
Since you just purchased your machine I assume that you have a manual with it. I recently bought an abused Micro Casa a Leva manufactured in 1983. I have not made anything worth drinking yet because I am systematically going through the machine and finding problems. It almost feels like a rescue program.
When I pulled the piston I was amazed to find the bottom of the piston and the screen mostly covered in grease! Along with that, there was some corrosion on the side of the piston and the group cylinder wall. Although the gaskets look OK, I have ordered a new set. My question is: how does one remove and replace the gaskets?
The location of the grease made me think that the machine was left on for an extended period of time, and/or it is running excessively hot. There are also signs of deformation on the bakelite water fill knob. I have had to make a gross adjustment to the p-stat to get it to read below 1.5 bar.
I'm not really sure of what the pressure is since the gauge is very dodgy. I will be substituting another gauge for the final adjustments, but at least the safety pressure release valve no long spits and sputters.
The machine is so simple in it's design and construction that I am confident that no permanent damage has been done. Now if I can find out how to replace the gaskets, I'm optimistic that it will all have been worth while.
Bob
