Replacement portafilters for cremina?
A haven dedicated to lever espresso machine aficionados.
Link to "Replacement portafilters for cremina?"by farmroast on Fri Sep 19, 2008 8:39 am
What portafilters(not naked) will work on a cremina. Elektra mcal, La pavoni, others? Which works/fits best. And any modifications needed? Best source?
thanks,
farm
farmroast
Link to "Replacement portafilters for cremina?"by rawman on Fri Sep 19, 2008 5:57 pm
I'm pretty sure my MCAL PF did not fit on the Cremina 2002. The Cremina's PF did fit on the Elektra though. I can double check when I get home.
Edited to remove link to bottomless PF, after re reading the post.
LMWDP #189
rawman
Link to "Replacement portafilters for cremina?"by orphanespresso on Sat Sep 20, 2008 4:07 pm
Just checked La Pavoni pre millenium and Elektra on Cremina 67. Both could fit with modifications. Elektra to Cremina: tight fit of pf body to group but clears all around-looks like a filing of the lugs would squeeze it in-plus is the lugs are ramped in the same direction as the Cremina. La Pavoni has more room on the pf rim than the Elektra but lugs a little wider, therefore more filing to fit, and the lugs are ramped in the opposite direction, but likely filing them flat would solve it, but they are a little thinner than the Cremina so it may not be a problem. The pf handle on the old LaPav are a little short compared to the Cremina, and the new LaPav handles which are a reasonable Cremina replacement don't fit the old pf bodies. Maybe you could pick up a used LaPav pf and try it out...the new ones for the premillenium are pretty spendy. The Elektra pf is much cheaper than the LaPav premillenium, by about half, and the handle looks more Creminian, but as I said, it's a pretty tight fit in the group.
Doug
Doug Garrott
Orphan Espresso
orphanespresso
Link to "Replacement portafilters for cremina?"by farmroast on Sun Sep 21, 2008 9:45 am
Doug
Thanks for checking.
Ed
farmroast
Link to "Replacement portafilters for cremina?"by orphanespresso on Mon Sep 22, 2008 3:04 am
No problem...that's what the Home Lever Machine Interchange and Reference Collection is for. Nice to be able to put it to good use.
Doug Garrott
Orphan Espresso
orphanespresso
