lilotaku wrote:Hello,
I'm fixing up an old mazzer SJ and i was wondering if the lower burr carrier is pressed on. I removed the single bolt that holds it into place, but i can't seem to pull the lower burr carrier out. Any ideas on how to pull it off? This thing is caked with old coffee probably from years back and i wanna try to get this thing thoroughly cleaned everywhere and give it to a friend as a gift. Thanks for any help in advance.
lilotaku wrote: I just shoved in the screwdriver head right below where the shaft meets the burr carrier, gave the handle of the screw driver a few taps and I was good to go.
lilotaku wrote: I am quite familiar with "kent's stolen tools"
Its ghetto, but you'll be surprised at what tools they have around when you need them. I believe the store you might be talking about is the one with the huge table grinder sitting outside rusting. As for who its going too, its for a highschool buddy that graduated with me at Mt. View High school back in 98'.
Paul_Pratt wrote:Jamming things in may cause damage to the shaft. An easier way is to use long bolts and tighten them in sequence. The bolts push against the main body and force the carrier off. The risk of damage is low because the amount of force required is very small.
jesawdy wrote:Very clever, Paul. Thanks for sharing. (BTW, what sort of grinder is that?)
Paul_Pratt wrote:An easier way is to use long bolts and tighten them in sequence. The bolts push against the main body and force the carrier off. The risk of damage is low because the amount of force required is very small.
dingrr wrote:Now that that lower burr carrier is off, I unscrewed three screws from beneath it and the motor still does not come out the bottom. Arrrgh! I can see two additional screwheads that catch the motor windings but the armature should slide out, no? That should give me access to the last two screws.
Mine is a Mazzer Super Jolly.
HB wrote:You're probably right about the bearing, that sounds like one of the Tagex grinders that Lino et al bought. He replaced a bearing for a few bucks and was off to the races. But keep in mind that he's Mr. Handy Extraordinaire. From what he said, getting the motor in and out was a pain because it's pressed into the shell.
lino wrote:It is a pain to press the motor in and out. Sean Lennon suggested a much easier method. Heat it up.
Put the grinder in the oven at a lowish temp 250-300, and wait till you hear the clunk...
BUT... You don't need to get the coil out to change the bearing.
You'll still need to pull/press the lower bearing carrier, and possibly the upper bearing - either off the shaft or out of the housing, or both. A nice cheap puller set or two from Harbor Freight, or the like, works well as you can mix match and grind the tool to fit your needs.
The bearing was about $7 from Enco, if I remember right. The original bearings in the SJ were shielded, not sealed. I replaced them with sealed and it's slightly louder (than a working shielded one), and spins down faster. Seals add friction and noise. The SJ design does a reasonable job of protecting the bearing so it doesn't need seals.
ciao
lino
lilotaku wrote:I did have to carefully align the carrier and did have to take a small rubber mallet and persuade it in.
