Refrigerator or Freezer for Coffee Storage?
Discuss flavors, brew temperatures, blending, and cupping notes.
Link to "Refrigerator or Freezer for Coffee Storage?"by dick-san on Wed Oct 11, 2006 2:29 am
Quite a number of times over the years, I've heard / read the admonition "don't put coffee in the refrigerator nor in the freezer."
Why not? Does the lower temperatures cause rapid deterioration of the coffee, even when in an airtight container? Or is it simply that opening the cold container leads to condensation on the cold beans, which I'm pretty certain does lead to rapid deterioration?
Of course, I'm hoping that the latter answer is the correct one -- I only drink one espresso double a day and would like to try some of the roasters sponsoring this site...
Thanks for any insights.
--dick floyd
dick-san
Link to "Refrigerator or Freezer for Coffee Storage?"by niad on Wed Oct 11, 2006 4:42 am
In the freezer you get ice crystals that gives condensation when you take the bag in and out that is not good for the beans after what i have heard.
A dark and cool place and airtight or with one-way ventilation is probably the best. Maybe if you really want to store the beans you should use the ordinary fridge.
If you get the beans in their original bag i believe you should just store them dark and fairly cool.
Niklas Adolfsson
niad
Link to "Refrigerator or Freezer for Coffee Storage?"by HB on Wed Oct 11, 2006 6:11 am
dick-san wrote:Does the lower temperatures cause rapid deterioration of the coffee, even when in an airtight container? Or is it simply that opening the cold container leads to condensation on the cold beans, which I'm pretty certain does lead to rapid deterioration?
The short answer is that the coffee continues to stale, it's only a question of how quickly the process progresses. One-way valves, nitrogen flushed containers, cold storage, they're our attempt to put off the inevitable.
There's been lots of debate about the freezer life of coffee beans, though I don't recall a consensus on the issue. When I get an unusually large bounty of coffee at one time, I'll divide it up into 1/2 pound lots and store them in airtight Mason jars in the freezer. I defrost them individually before use (no going in and out of the freezer for the reasons you cite). The jar will "burp" loudly when first opened as the CO2 escapes. Ah, love the sound and it at least smells fresh. While I recommend truly fresh coffee for everyday use, an airtight container in the freezer will extend the freshness a bit longer. Note: The jar may be pressurized, but I've never had one burst. I've always jarred coffees a few days post-roast; homeroasters may need to wait for partial degassing if using an airtight jar. Rudedog has an innovative solution:
From Reusing valve bags, do they wear out?
Related topics: Rapid loss of espresso richness past 5 days and What is the latest on the storage of greens? Bob's Storage of Roasted Beans to Maximize Flavor gives a chemist's viewpoint on the subject.
Link to "Refrigerator or Freezer for Coffee Storage?"by another_jim on Wed Oct 11, 2006 4:03 pm
The basic answer is
1. freezing retards staling, and very deep freezing (-40 C or F) eliminates it. Coffee in a home freezer stays fresh for at least a month.
2. it has to be done right, or it's useless. The coffee has to be stored airtight and allowed to warmup completely before reopening the package. Otherwise one gets condensation, which is worse than staling. It is best if as little moisture laden air as possible is stored with the coffee, vacuum pack is best, wrapping tightly or storing in a filled to the stuffing point jar also work well. I use freezer or valve bags which I roll up tightly to expel the air, then seal. This works fairly well, and keeps the coffee fragrant for at least three weeks.
another_jim
Link to "Refrigerator or Freezer for Coffee Storage?"by miKe mcKoffee on Wed Oct 11, 2006 5:32 pm
Because of my consumption style of always having 3 to 5 single origins plus an espresso blend roasted and rest ready freezing roasts has long been a part of my routine. Primarily the espresso blend gets frozen since I'll usually only pull a shot or two per day of it and roast 1/2# batches. The SO 1/2# batches also get pulled as shots for Americanos, caps and straight shots but also get pre-ground and little vac bagged in individual 24oz press pot sizes for work then frozen so usually the vac'd mason jars don't last unfrozen more than a week from rest. When freezing I've always followed Sivetz advice as closely as possible. My version of "hermetically sealed" being vacuum sealed in mason jars. I also use this for having coffee waiting returning from travel.
Once frozen I do not defrost an entire frozen batch but rather measure out what's needed for the grind session and immediately re-vacuum seal the jar and return it to the freezer. This removes any negative moisture influences IMO. After letting the beans sit in the grinder 5 minutes or so grind away.
Here's a video of my 5 bean pre-roast Summer Jam Blend (3 DPs, 2WPs, zero Robusta). This was part of the pile I roasted Aug 29th for the Sept 4th Espresso Jam I hosted. Mason jar vacuum sealed and frozen the next day Sept 5th at 7 days post roast. FWIW it was mason jar vacuum sealed room temperature direct from roast cooling. It's been removed from freezer for a shot at least a dozen times since then.
(my first shot video, using video function Olympus C-750, primarily a still camera)
Lighting could definitely be better and should have zoomed in more. As may or may not be able to be seen end of shot crema was still a good 75% Guinnessing to ~30% or so. Total pull about 1.5oz, crema not what it was at day 6 before freezing over a month ago, but still quite tasty!
miKe mcKoffee
Link to "Refrigerator or Freezer for Coffee Storage?"by Ken Fox on Thu Oct 12, 2006 3:58 am
dick-san wrote:Quite a number of times over the years, I've heard / read the admonition "don't put coffee in the refrigerator nor in the freezer."
--dick floyd
Here's what I do: I roast every 2-3 weeks, in quantities too large to use up before it stales. I also roast for a friend who happens to be my internist. All of my friend's coffee goes into sealed valve bags evacuated of excess air and frozen immediately. As a precaution I put a piece of tape over the valve because these valves use a drop of oil in them and the oil will freeze with the valve either open or closed. The tape is to be removed when the valve bag is removed from the freezer for use.
With coffee I will use myself, about 1/2 to 60% goes into mason jars, filled to the rim, and immediately frozen in a cold (between -10 and -20F) freezer. The rest is used over the ensuing 8 to 10 days. The frozen coffee tides me over in between roast sessions and for when I return from vacations.
I never keep coffee frozen for more than 3 months and generally it is for about 2-6 weeks. With this approach I have never detected any significant degredation of the coffee compared to the fresh/never frozen coffee that makes up about 1/2 of my overall home consumption. I believe but cannot prove that it is most helpful to freeze the beans within a very short time after roasting, say within an hour.
ken
What, me worry?
Alfred E. Neuman, 1955
Ken Fox
Re: Refrigerator or Freezer for Coffee Storage?
Link to "Refrigerator or Freezer for Coffee Storage?"by miKe mcKoffee on Thu Oct 12, 2006 9:23 am
Ken Fox wrote:I never keep coffee frozen for more than 3 months and generally it is for about 2-6 weeks.
One of these days (years) I'll find out just how long it can keep. Have a pound that I vacuum bag froze going on six years ago. :shock: It was part of the last shipment received of pre-roasted when just starting home roasting. But wouldn't really be a good staling test coffee 'cuz it was their Nawlins style coffee, darker roast with chickory. And so it sits abandoned in the freezer, just haven't had the heart to throw it away. Someday I'll bust it open and make a press pot to see if there's any life left. But will have to make a batch of Beignets first of course. :wink:
ken
Makes sense especially if taking the entire frozen batch out to thaw before consuming in the ensuing days. If only taking out for the grind and returning to freezer seems 3 days rest or so before freezing might be better.
miKe mcKoffee
Link to "Refrigerator or Freezer for Coffee Storage?"by miKe mcKoffee on Thu Oct 12, 2006 12:45 pm
Tried my hand at another video showing how 7 day rested then 6 week vacuum sealed frozen beans pull. Used clear glass demi rather than cut crystal, zoomed in closer and added some hi-tech lighting (19.2v Craftsman flashlight with I believe krypton bulb :lol: )
Appears to be a good 90%+ crema end of shot Guinessing to ~45% 30 seconds post shot. This is my blend of 100% Arabica Caffe' Rosto 15min gentle tickling a wee bit into 2nd profile roasted to light FC, 4min drying equalization stage to 300f, level ramp to start of 1st ~9:30, 15min end of roast cooled to 125f ~2min, pre-roast equal part blend of Aged Sumatra, Brazil Cerrado DP, Brazil Cerrado WP, Harrar DP and Kona WP. Shot pulled ~202f.
The proof is in the cup and it was delish! :wink:
miKe mcKoffee
Link to "Refrigerator or Freezer for Coffee Storage?"by Ken Fox on Fri Oct 13, 2006 4:06 am
miKe mcKoffee wrote:Tried my hand at another video showing how 7 day rested then 6 week vacuum sealed frozen beans pull.
There are several well known people who make very strong blanket statements about freezing coffee. It is my impression that these people have virtually no experience with it. It would be fairly easy to do a blind tasting comparison of previously frozen vs. never frozen, but equivalently "aged" coffee to see if good tasters can tell the difference. My guess is that they can't, but this remains to be tested. One of these days Jim S. and I might get around to testing this hypothesis, but we would be delighted if someone else would take it upon themself/themselves to do this instead, since this sort of testing is extremely tedious.
ken
What, me worry?
Ken Fox
Refrigerater or Freezer for Coffee Storage?
Link to "Refrigerator or Freezer for Coffee Storage?"by dick-san on Mon Oct 16, 2006 3:13 am
Thank you for all the insights and data -- I feel more comfortable about trying coffees from online roasters now.
The only time I ever froze espresso coffee was in 1992 when a former son-in-law, who liked to make big gestures, gave me a big steel barrel of Illy Cafe for my birthday. I can't remember how much coffee it contained but it must have been at least 8-10 pounds (his brother was an Illy distributor -- did get a nice 6 cup selected artist set from that connection too, tho the marriage didn't last long <g>). Since I'd only had the Cremina for less than a year, my palate wasn't developed enough to be very discriminating about any deterioration over time -- my main memory is of how much room the barrel took up in the freezer <g>
Thanks again.
--dick floyd
dick-san
Re: Refrigerater or Freezer for Coffee Storage?
Link to "Refrigerator or Freezer for Coffee Storage?"by miKe mcKoffee on Mon Oct 16, 2006 2:21 pm
dick-san wrote:Thank you for all the insights and data -- I feel more comfortable about trying coffees from online roasters now.
Well get on over to the Soho Espresso "Best of Five" giveaway thread and get writing. You may win get a couple pounds free! :wink:
miKe mcKoffee
Link to "Refrigerator or Freezer for Coffee Storage?"by cannonfodder on Wed Oct 18, 2006 9:11 pm
I have taken to vacuum packing my greens and putting them in the deep freeze (-30f) until needed. I retrieve the coffees that I need replenished, open the bag, put three pounds in a cotton drawstring bag, vacuum the bag again and back to the freezer. The greens are out of the freezer no longer than a few moments.
The green sit on the counter in their cotton bag to slowly thaw. I have not noticed any ill effects from the deep freeze. I have never tried to pack roasted coffee. I just roast what I need for four days, twice a week.
cannonfodder
Link to "Refrigerator or Freezer for Coffee Storage?"by Climb14er on Mon Oct 30, 2006 10:37 am
I order two one pound bags of Intelligentsia Black Cat whole bean every order and freeze one of the bags in a double freezer zip lock.
Doing this four times, I've noticed no difference between the frozen whole beans and the ones that I use right from the 'factory'.
Climb14er
Coffee storage (unopened roasted coffee)
Link to "Refrigerator or Freezer for Coffee Storage?"by dsm363 on Sat Jan 27, 2007 2:20 pm
I just finished my first lb of Intelligentsia espresso and loved it. With shipping $5 on a $12 lb of coffee, I was hoping to order 3-4 lbs at a time. Since these are roasted on a weekly basis, do they store well for weeks as long as you don't open the bag or is just ordering what I need for the next month the best? Thanks.
Dave
dsm363
Link to "Refrigerator or Freezer for Coffee Storage?"by jesawdy on Sat Jan 27, 2007 9:20 pm
Some will disagree, but here is what I have been doing... it works for me.
I let the roasted beans rest for 3-4 days in the sealed bag. I place a piece of scotch tape over the one-way valve, and then I put the bag in the freezer until I need it. When I need it, I pull the bag out of the freezer, let it warm up a bit (to room temp if humid and I am getting condensation on the bag), pull the tape off the bag and just use it until it's gone. I pour 1-2 days worth in the grinder hopper, and leave the rest in the bag. The bag does not return to the freezer after opening.
Most of time, my beans aren't in the freezer for too very long. I try to order on the 1st and the 15th of the month, and between work, home and friends, I usually don't have anything in the freezer for more than ~3 weeks. I did however stock up during the holiday sales, and have a few pounds left in the freezer from that.
Jeff Sawdy
jesawdy
www.vanelis.com: top-notch espresso equipment and customer support
Link to "Refrigerator or Freezer for Coffee Storage?"by dsm363 on Sun Feb 04, 2007 11:22 am
Thanks for the reply. I have one of those glass, air-tight containers to store extra beans at room temp. I thought I had read to not put beans in the freezer anymore or does that just apply to long term storage (weeks in the freezer)? Thanks.
Dave
dsm363
Link to "Refrigerator or Freezer for Coffee Storage?"by HB on Sun Feb 04, 2007 1:40 pm
.... merged new topic with a similar topic...
I rarely store coffee these days, freezer or otherwise, but at one time I routinely bought two pounds and divided it among eight glass Mason jars. The jars didn't have one way valves. I would carefully tap tap tap and refill to minimize the air space. Over the course of a month, I would remove and defrost each jar, each jar holding enough to last for a few days (hmm-m my consumption is much higher than 1/2 pound per week nowadays :shock:).
The last jar of the month would "burp" when opened and the espresso tasted quite good. However, I haven't done a blind comparison between freezer beans stored a month versus freshly roasted. I would be interested in hearing your results.
Link to "Refrigerator or Freezer for Coffee Storage?"by kdkrone on Thu Feb 22, 2007 2:10 am
Our home situation has been very unpredictable for the past couple of years; sometimes I am home, sometimes I am working away from home. Sometimes we have guests for the weekend.
There is no decent roaster where we live and I don't roast at home. Our roaster is 2000 miles away in Nebraska. So we have been freezing beans for up to 4 months beginning 2 years ago. Our "house blend" is Code Brown from Coffee Emergency, and I must say it does exceptionally well frozen up to 4 months. We freeze is in the mylar package in which it arrives, making sure that as much gas as possible has been expelled before we freeze it (it spends about 3 days in transit to California). We have also done the same with the Milano espresso blend from Paradise Coffee in Minnesota with great success.
If there is one downside to freezing coffee beans, I would say that the beans have a slightly shorter lifespan when they are frozen than when they are fresh, perhaps 10 days, as opposed to 14 or so. That seems to be a small price to pay for the convenience. I think that part of the trick is to keep water off of the beans so that there is no freezer burn. The valved bags keep air to a minimum and all of the moisture with it. For those times when we have small glass bottles, we have covered the beans with plastic wrap so that the water in the air above the beans condenses on the plastic and not the beans.
Ken K
kdkrone
Link to "Refrigerator or Freezer for Coffee Storage?"by gtrman on Thu Feb 22, 2007 8:09 pm
after reading this thread i am more inclined to order roasted beans online. i have been buying my coffee from whole foods market, which i guess you would call an "organic grocery store" still relatively new to my area. they do have a roasting outfit there, from what the head roaster tells me its a 5 pound air roaster. the only problem is that they only have dark roasts (french and italian) for espresso blends which are a little too dark for my taste. it seems they have a medium roast. but it is not much if any lighter than the dark italian, however i am colorblind and that could be the problem. does anyone know of any roasters in the northeast which i could order online from? intelligentsia sounds appealing, but shipping cross country i would have to pay out the ears to get it here in a couple days. i see chris' coffee has a small roasting operation and the black pearl espresso blend seems like it would be good, and anyone speak to this?
thanks,
jeff
Jeff Hall
gtrman
Link to "Refrigerator or Freezer for Coffee Storage?"by jesawdy on Thu Feb 22, 2007 9:24 pm
gtrman wrote:does anyone know of any roasters in the northeast which i could order online from? intelligentsia sounds appealing, but shipping cross country i would have to pay out the ears to get it here in a couple days. i see chris' coffee has a small roasting operation and the black pearl espresso blend seems like it would be good, and anyone speak to this?
Jeff, if shipping cost (and time) is of big concern, Tony at Caffe Fresco has it going on. Low cost USPS shipping and fast. I have ordered from Intelly, UPS shipment was pretty fast but more costly. Rocket Coffee had a shipment from AZ to NC in 3 days USPS IIRC and they have a free shipping promo right now on the Espresso Sampler (and that's a lot of coffee!). I have not tried the Black Pearl but should be worth a go.
Jeff Sawdy
jesawdy
Next
Return to Coffees
