Recommended Surge Protectors
Want to talk espresso but not sure which forum? If so, this is the right one.
Link to "Recommended Surge Protectors"by Marleyisdead on Fri Nov 09, 2007 12:11 pm
Any recommendations on surge protectors for the home unit. I've got 20 amp service and a new machine on the way. All of the surge protectors at the chain stores are for computers (15A). Thanks in advance for your help.
Marleyisdead
Surge Protection Addendum
Link to "Recommended Surge Protectors"by Marleyisdead on Fri Nov 09, 2007 12:31 pm
The machine in question is a Fiorenzato Bricoletta with 110V.
Marleyisdead
Link to "Recommended Surge Protectors"by ntwkgestapo on Fri Nov 09, 2007 1:02 pm
The one here: http://www.homedepot.com/webapp/w...5&locStoreNum=4609
is a 20 amp receptacle with surge suppression built in! Available from Home Depot. Probably similar available from Lowes as well.
ONE thing that people need to understand about Surge Suppressors... they are NOT "lifetime" products! EVERY time the MOVs (Metal Oxide Varistor) in the SSup "cascades over" (protects you from a surge) it LOSES some of it's capacity. MOVs work like "variable resistors" and at their rated voltage they begin to function like a voltage regulator and FOR THE VOLTAGES ABOVE their rating appear as a "short circuit" (they're kind of a bi-polar zener diode, which functions like a BLOCK UNTIL you hit IT's rated voltage. ABOVE that point it "knees" over and, basically, strips the voltage ABOVE it's rated point off. It's a SIMPLE voltage regulator). Each and every time they "trigger" you lose a bit of their rated capacity. SOOOO, expect to REPLACE them every 5 years or so...
Steve C.
I'm having an out of coffee experience!
LMWDP # 164
ntwkgestapo
Some possible surge protectors for your equipment ...
Link to "Recommended Surge Protectors"by Colorado_Espresso on Mon Nov 12, 2007 6:25 pm
There's a Tripplite that's rated for 1440 watts, but only 15A
T105-5174
Available at TigerDirect.Com for about $60.00
For 20A ... I found something called the 'Brickwall' that's used by some audiophiles.
http://www.sellcom.com/brickwall.html
The cheapest 20A surge protector is from from Panmax
Panamax M2A20 20A Surge Protector (about $45 from Amazon) - this is likely your best bet.
Here's one that handles multiple lighting strikes and is rated at 20A
http://www.dxengineering.com/Part...%2DPLDO%2D120US20A
Colorado_Espresso
Return to Knockbox
