Recharging cation water softener in water tank
Want to talk espresso but not sure which forum? If so, this is the right one.
Link to "Recharging cation water softener in water tank"by rudedog on Tue Nov 01, 2005 10:24 pm
Regarding this small softener device in my Isomac...
Is there directions somewhere on how to recharge it and with what?
Its the same as the one Chris sells for 18 bucks.
I dont have a water hardness test kit yet, in case you have one in mind?
Right now Im using gallon jug drinking water.
Back flush with Joe-Glo and have run some through the boiler.
Have not used a descaler yet but I should be able to find info on that.
Thanks.
rudedog
Link to "Recharging cation water softener in water tank"by cannonfodder on Tue Nov 01, 2005 10:34 pm
I have actually read reports of people having the top dislodge and the machine suck the softener pellets into the boiler. I have also heard of water flow issues with it attached. I pulled my softener off, put a float valve in the reservoir and filter inline.
cannonfodder
www.dailygrind.com: artisian roasted coffee and espresso equipment
Link to "Recharging cation water softener in water tank"by another_jim on Wed Nov 02, 2005 12:41 am
The pellet leakage issues have beeen solved; apparently the problems came from a bad production lot and Chris changed suppliers. These are pretty standard equipment for espresso machines and work well for moderately hard water.
They need to be recharged every week or two. Take a highball glass, fill with water, dissolve in a tablespoon of kosher (or pure, no additive) salt, and place the softener in the glass, sucking water through until you taste the salt. Let it recharge at least an hour, then rinse out the salty water (I suck on it to make sure it tastes sweet. Then you're set to go (after wiping off the nipple of course)
Some people have reported sharply reducd flow with these attached. I suspect this may have been caused by a pacing problem, since most people don't see a big reduction (there's always a little). If you have suction problems, give it a good shake.
If you've adjusted your OPV to get a maximum pump pressure for your shots, you'll see a reduction (about 1/4 to 1/2 bar) with it attached. If necessary, you'll need to readjust it with the softener attached.
another_jim
Link to "Recharging cation water softener in water tank"by cannonfodder on Wed Nov 02, 2005 10:40 am
Good to know, thanks for the heads up.
cannonfodder
Link to "Recharging cation water softener in water tank"by rudedog on Wed Nov 02, 2005 6:37 pm
Ok.
Think I get it now.
Will give it a try when I get proper salt, dont know if the table salt has additives or not.
I have about 9-9.5 bar with it attached so that should be good.
another_jim 's post made me laugh, but informative, thats what I need
I did not know there were pellets in the softener that would not be good if they got out.
My set up is used so the previous owner recharged it before I got it.
Thanks guys.
rudedog
Link to "Recharging cation water softener in water tank"by another_jim on Wed Nov 02, 2005 10:54 pm
rudedog wrote:dont know if the table salt has additives or not.
Regular table salt has iodine and anti-caking additives. I don't know what these do to the softener; but the instructions on cation softers always specify pure salt.
another_jim
Link to "Recharging cation water softener in water tank"by barry on Wed Nov 02, 2005 11:35 pm
you can get 40lbs of salt pellets at lowes/homedepot for about $5. enough to use forever.
barry
Link to "Recharging cation water softener in water tank"by cannonfodder on Thu Nov 03, 2005 8:58 am
You could try kosher salt. No iodine or anti clumping agents are added, just pure sodium chloride I believe. I prefer the taste and cook with it all the time.
cannonfodder
Link to "Recharging cation water softener in water tank"by DavidMLewis on Thu Nov 03, 2005 3:14 pm
cannonfodder wrote:You could try kosher salt. No iodine or anti clumping agents are added, just pure sodium chloride I believe. I prefer the taste and cook with it all the time.
You want to be more specific. The Diamond Kosher salt is pure, as you say. The Morton's isn't, and there's a definite difference in taste.
Best,
David
DavidMLewis
Return to Knockbox
