Hello! I could really use some help with La Peppina. I finally rebuilt her with some assistance from Dad, using the wonderful step-by-step photo instructions from Doug and Barb..
The process seemed to go smoothly, except for one snag- I left the screwdriver jammed into the back opening for a few hours and then when I was ready to reassemble, the sides did not want to come back as close together as they used to be. We had to squeeze those lips together with pliers in order to get them close enough together to get the screw back through and into the nut. When we were finally done, the kettle was riding about 1/3-1/2 inch higher than it used to be- it did not want to fully seat.
Nonetheless, the unit held water with no problems, and dispersed it evenly through the shower screen on a test pull (which felt normal), so I figured I'd try some test shots. Unfortunately, after the first shot had been pulled, water began a steady drip out of the grouphead and would not stop, until the kettle was fully drained.
I'm guessing the flat washer somehow got jostled out of place? I can't take it apart yet, it's still hot, but I will be opening her up again in the morning, and would appreciate any tips on troubleshooting and getting this right on the second try.
Thanks,
~tMb
