mrgnomer wrote:About the spare parts for Cremina's I'm pretty sure atleast the top piston gasket on mine needs replacing but I'd like to find the gasket kit and do a complete overhaul. Mine is old but in very good condition.
I was thinking, as a treatment, I could find a food grade silcone lubricant that's water insoluable and also capable of restoring and sealing in a high heat, high vacuum environment. I found something that was perfect but the shipping charges on a $7 tube of the stuff would have been around $50. Too much. Can't find the link for it right now.
I got something out of California that seems to be o.k. Minimum order was $15 with a shipping charge of $8 USPS to Canada. Much more reasonable. It's in a syringe format. Bostik© N-S WT White Food Grade. No problems dealing with the company and the service was very good. Order has just been filled. Waiting on delivery.
http://www.aeroconsystems.com/Hillson/hillson.htm#types
What do guys think, though? Gaskets dry out over time and if they're totally gone, I guess they're gone, but if they're just dry you can restore them with the proper lube and it would save replacement. If that lube also acts as a sealant, so much the better.
I've used silcone spray on the rubber gasket around my car window when it started drying out and sticking and it didn't just act as a very good lubricant it also reconditioned the rubber.
Lubricants rated for "incidental food contact" are not, IMO, adequate to the task of lubricating piston-seals. You want something potable-water-system-approved. I'd look for a NSF61 rating. The listed applications for the Bostik are:
° Nuts, bolts, screws
° Pipe fittings
° Stainless steel fittings
° Valve stems and assemblies
° Pump gears
° Chain drives
° Gaskets
° Press fit assemblies
° Conveyor and oven bearings
° Packaging machinery
° Worm gears
° Slow speed or highly loaded bearings <500 RPM
Regards
Timo
