Rancilio Silvia powered on but no heat - Page 2
Link to "Rancilio Silvia powered on but no heat"by Bob Farmer on Mon Jan 07, 2008 1:37 pm
One more thing. I think I'm confused about the safety thermostat. Whatever trips has a little red button that is accessed by removing the top cover of the machine and contorting your finger amongst wires to press it. The BOL stays on when this is tripped.
Remember: Here at Roadrunner cafe we're not happy 'till YOU'RE not happy.
Bob
Bob Farmer
Link to "Rancilio Silvia powered on but no heat"by jggall01 on Mon Jan 07, 2008 2:39 pm
erics wrote:When the safety thermostat (165 degrees C) trips, all lights should go out and Silvia is "dead".
I agree, they should go out. But they don't. The orange light is really just an indicator of the status of the thermostats (light is on when both are closed). If the safety stat is tripped, the light can still be on (either if both stats are calling for heat, or if there is a short to ground at the heater/boiler interface).
Jim
jggall01
Link to "Rancilio Silvia powered on but no heat"by stefano65 on Mon Jan 07, 2008 3:37 pm
Note: The picture of the boiler that you see is THE ORIGINAL boiler that RANCILIO no longer sells or installs on Silvia.
Stefano Cremonesi
Stefano's Espresso Care
stefano65
Link to "Rancilio Silvia powered on but no heat"by erics on Mon Jan 07, 2008 6:09 pm
Jim is correct - you would think I would be able to read my own adaptation of Silvia's wiring diagram. :cry:
Skol,
Eric S.
erics
Link to "Rancilio Silvia powered on but no heat"by jggall01 on Mon Jan 07, 2008 8:17 pm
erics wrote:Jim is correct - you would think I would be able to read my own adaptation of Silvia's wiring diagram. :cry:
Unfortunately, I did not learn this by referring to the diagram. Instead, I conducted a full scale test on a machine specially modified with a shorting wire across the steam thermostat :-0
Jim
jggall01
My sick Rancilio Silvia
Link to "Rancilio Silvia powered on but no heat"by Bob Farmer on Tue Jan 08, 2008 6:15 pm
Thanks for all the info. I'm in over my head though. I called the tech dude, Roger at Chris Coffee who was totally friendly and helpful. He has the opinion that it's the brew thermostat and is sending one. I'll let you know how it goes.
bob
Bob Farmer
Got the thermostat
Link to "Rancilio Silvia powered on but no heat"by Bob Farmer on Wed Jan 30, 2008 10:26 pm
I'm not sure anyone is interested in this anymore but I just received the thermostat and have installed it and just turned on the machine. I'm so excited I'm going outside and watch the grass grow until it comes up to temp.
Bob Farmer
Link to "Rancilio Silvia powered on but no heat"by jggall01 on Fri Feb 01, 2008 5:14 pm
Bob Farmer wrote:I'm not sure anyone is interested in this anymore but I just received the thermostat and have installed it and just turned on the machine. I'm so excited I'm going outside and watch the grass grow until it comes up to temp.
Did that fix it?
jggall01
Link to "Rancilio Silvia powered on but no heat"by erics on Fri Feb 01, 2008 8:31 pm
Greetings Bob:
First and foremost, I am sincerely happy for you that the machine is working - at least that is what I gleaned from your "Is anybody still interested post". I believe it is GREAT that you posted a follow-up - lots of times people don't.
HOWEVER, I for one believe you UNINTENTIONALLY left something out of your original troubleshooting as replacement of the brew thermostat would NOT have solved your problem as stated.
Perhaps your Silvia is wired a little differently than the schematic I posted earlier?
Skol,
Eric S.
erics
Previous
Return to Espresso Machines
