My Silvia used to produce very decent shots, but its recent the quality is really, really bad. There seems to be a problem with pressure, I don't know how to resolve it and need a few suggestions.
The machine seems to choke, even without any resistance. A have unmounted the water spreader, and let some water down (without porta-filter), is was rather dripping then flowing. I played around with the pressure valve but no success at all. I also tried to descale the machine (I used vinegar-water 1:1 mix), the pressure was MUCH better when the vinegar-solution was running through, but it fell back to 'dripping' as soon as I used pure water again.
I made a test, you can try it with your Silvias to compare:
I put everything to its previous state (mounted the water spreader and put the pressure valve to its original position). Then, I plugged-in the empty porta-filter (no basket) and let water down for 28 seconds, catching it under the porta-filter as well as the water coming from the overflow hose.
I ended up having exactly 2oz in the front-cup AND 2oz from the overflow hose (4oz in total). I can't believe that this is normal, why should the machine pump any water through the overflow-valve if there is no resistance at the front? Something must be blocking the water-supply, do you have any idea what it could be?
I really appreciate every advice, thanks in advance,
Dim
