A few weeks ago I installed a thermocouple to the top of Silvia's boiler wedged in the small brace that holds the brew thermostat in place. Wanting to see how the brew temp at the top of the boiler corresponded to the brew temp at the shower screen, I drilled a hole in a single basket and snaked a separate k-type probe up in the basket close to the shower screen. While reverse temp surfing (temp dropping), I was able to see about a 10 degree C drop from top of boiler to temp in the basket (no coffee). So I've been hitting the brew switch at around 104 C (top of boiler) and this should start the shot at around 94 C.
Question? How much of a temp drop can be expected through out the shot?
Should I hit the steam switch while brewing? Will this take the temp too high during the shot?
If I brew without the boiler active I get a very large drop in top of boiler temp maybe 10 degrees or more. I don't think the temp in the basket is dropping that much is it? It doesn't taste like it drops that much.
If I brew with the boiler active the temp(top of boiler) doesn't drop much at all but it taste like the temp might be getting too high.
I'm kind of new to the taste of espresso, only been drinking straight shots for 4 months or so.
Or maybe I should try temp surfing up and see what I get.
Any thoughts?
Thanks Tim
