jesawdy wrote:Hmmm... my concern would be that you just can't make enough steam to use a 4-holed tip with a small boiler. That being said, I wouldn't stop you from trying a multi-holed tip with the understanding that you may have to plug one or more holes to get it to work well.
http://www.1st-line.com, EPNW and others sell different steam tips.
Oyama wrote:BTW, thanks for the links, unfortunately 1st-line doesn't seem to ship outside the U.S.
HB wrote:I wouldn't be disappointed, it's not something to write home about. Check out Silvia steam tip alternatives for other opinions.
erics wrote:I would just add this one personal experience note to your adventure:
The 4-hole tip from EPNW produces better microfoam effortlessly but is relatively slow.
The 3-hole tip from 1st line also produces good microfoam with a little effort and is pretty fast.
Both are better than the stock Silvia tip in the hands of an average steamer (like myself) but a pro could make great product with any of the three.
The 3-hole tip does a nice job in taking boiler pressure (and thus temperature) down such that only 3 to 4 ounces of flushing is required after steaming if you were going to then produce another shot. The 4-hole tip does not put much of a dent in boiler pressure.
Eric S.
Oyama wrote:From what I've read, the 4-hole is not any faster than the 1-hole Silvia tip. I haven't had any problems with not having enough steam to finish my frothing (yet).
Grant wrote:My orders have usually been $40+ though, so worth a bit more to them perhaps than if you were only ordering a single tip.
