anyone know how to fix it? because it used to be very quiet....HELP~~
xxooxxoo wrote:currently i replaced the blade for my rancilio rocky by using the hammer and screwdriver to get original screw to come off. Ever since that, i got a unusual noise when i use it... anyone know how to fix it? because it used to be very quiet....HELP~~![]()
cafeIKE wrote:If impact is used to remove screws or nuts, the motor bearings can be damaged :
Brinelling is caused when a load is applied to a ball bearing that exceeds the elastic limits of the steel and the raceways are permanently deformed. Brinelling creates measurable dents at each ball location similar to the deformation caused by a Brinell Hardness Tester. This type of damage can occur quite easily if proper care is not taken. High energy impacts (from hammers and smash-ups), improper bearing handling and incorrect spindle assembly can all damage bearings. Remember that we are talking about bearings with raceways with roundness measured in millionths of an inch. Damage may result in increased vibration and non-repetitive run-out.
xxooxxoo wrote:i will say.....after you hit the right one and turn on the machine....you won't ever find any odd noise... so if it's not the right one, i guess you just have to hit it one more time.
