Hello everyone and thanks for the ever present input so far. This forum has been a valuable source of information, solutions and advice for me.
Here is my problem (I did do a forum search and did not encounter the exact symptoms):
I have a Silvia/Rocky(with the Teflon tape mod) combination and have been enjoying it for 2 (Silvia) - 3 (Rocky) years. I home-roast. Last holiday season I decided it was time to change the Rocky burrs and ordered a set which I changed with no problems. I noticed there was no Rancilio logo on them. I immediately noticed that the grind was faster (expected). I also noticed that the Rocky absolute 0 point changed from -3 to +8. This was expected and anticipated as well. What I was not ready for was a change in my usual setting for espresso grinding. It changed from abs. 0+7 or +8 to abs. 0 +2 or +3. Mind you, the Silvia cannot be choked at +1. I performed the Ulka pump capacity curve measurement and came up with <9 bar (7.7-8.5).
Another change: I use both the Rancilio double portafilter and the La Marzocco double. I used to grind 18 grams for the Rancilio PF and 21 grams for the LM PF. Now, in order to get the same extraction from the Silvia, I have to grind 19+ grams for the R PF and 23 grams for the LM PF. The grind feels the same between my fingers.
Do you have any clues for me please? I would appreciate them.
Thanks,
Nikos
