PKR wrote:If a Mini goes easily from espresso to drip, then I am sold. Is it stepless? If not, do you wish it were?
Also, just how hard is it to change settings w/a stepless? I assume there are marking so you can find the right place again, no?
The Mini can grind whatever you need and it is easy to change between settings. That said, if you plan on doing espresso and drip/FP/etc on a daily basis it gets old in a hurry. I am doing just that right now and plan on ordering a Rocky and leaving the Mini for espresso only. There are a few major problems with constantly changing settings. The first is that the Mini is sensitive. Small adjustments have a fairly large effect on the pour. Once you find the right grind for a particular bean it is nice to be able to just make minute adjustments around that point. Changing back and forth for the drip/FP setting obviously doesn't help. Of course you can mark your last grind point etc.. all of which I have little patience for at 5:00 am.
A bigger problem, in my view, is cleaning out the drip grinds (way too coarse for espresso) and remembering to change the settings between extraction methods. I can't tell you how many times I have started grinding coffee and realized I had failed to change the setting back. The result is drip grinds in my PF or espresso grinds in my drip filter. Either way, its not good.
The nice thing about the Mini is that it will meet all of your needs while you decide what is best for you. Good Luck.
