RancilioRancilio wrote:I was reading reviews on the Isomac Zaffiro and everybody seemed to say that it produced some of the best espresso shots they've ever tasted and I was wondering how the Alexia compared?
Have you read Chris Tacy's review of the Bricoletta? (link in jesawdy's earlier post this thread) His rating the Bricoletta shot quality higher than a stock Linea and equal to a modified Linea one of the factors in my decision. That said haven't spent enough time with QM machines to give a potential shot quality comparison and no time with Alexia only HX QM's.RancilioRancilio wrote:Sorry for all of the espresso machine questions but I keep discovering new products which makes choosing even harder. I had some questions regarding the Quickmill Alexia that I was hoping you could help me with. I was reading reviews on the Isomac Zaffiro and everybody seemed to say that it produced some of the best espresso shots they've ever tasted and I was wondering how the Alexia compared? Right now I'm thinking about purchasing a PID'd Alexia bringing the total cost around $1200 or so which is very close to a vibe pump Bricoletta. I usually only drink espresso so shot quality is my main concern but if I can get an HX machine that can produce a shot as good as the Alexia then I guess it would be good to have the instant steaming feature. So do you think the Bricoletta is the way to go given my situation? Any input would be greatly appreciated. Thank you.
If you attempted to run the Bric' on a 15A circuit the worst thing you could do was turn it on and off IMO. The Bric' is rated 1900w with the heater 1800w IIRC. If your power 120v that means fully engaged with heater & pump running simultaneously load would be 1900/120=15.8A and while heating only 1800/120=15.0A. Since once up to temp and stabilized heater duty cycle only about ~6% time on without insululation and ~3% if adding aftermarket insulation (mine). So while heating would be right at 15A limit, while pulling shots potentially briefly slightly over 15A. FWIW the heater is not normally on most of the shot unless pulling and steaming concurrently. Most breakers have short term overload wiggle room so might get away with it but I in no way advise intentionally overloading a circuit!I was doing some searching on Home Barista and noticed that you own a Bricoletta. I was hoping I could ask you a few questions. My biggest problem right now is the 20 amp plug needed to run the machine. My house only has one and it would be impossible to setup the Bricoletta next to it. So would it be possible to run the machine on a 15amp if I turned the machine off after every use? Do you have any experience with the Quickmill machines? I was wondering how they compared to the Bricoletta.
Marshall wrote:The long and the short of it is the HX was designed for constant use in a coffee bar. Home use of an HX requires greater skill and experience to achieve the temperature stability that a PID single boiler provides on a no-brainer basis.
Marshall wrote:Proper HX temperature control at home also requires several times as much water usage. So, you are looking either at plumbing an HX machine in or refilling the tank every day or two. Plumbing the machine in in most parts of the U.S. means installing and fine-tuning a water treatment system for the right mineral balance. A pourover machine can simply use bottled water.
Marshall wrote:If your top priority is straight espresso for yourself, go with the Alexia. If your top priority is milk drinks for friends, go with an HX.
I took a real hard look at the upgrade possibilities from my PID'd Zaffiro and decided the only real upgrade for my purposes was a GS3. (Yes, I'm on the list).
As an aside, I've thought for some time that many (but, by no means all) people who swear by their milk drinks would give up their HX machines in a heartbeat if they could make really great espresso at home on a regular basis (which they could with a single boiler).
Ken Fox wrote:In a place like Southern California, where no one but family pets drink the tap water and 5 gallon bottled water jugs are scattered throughout the house, with replacements delivered to your door every week, perhaps this makes sense. For most people living elsewhere who would need to buy bottled water at the supermarket and pay by the liter, do you think this is a very attractive option? Many people live in places where the water is soft and relatively boiler safe. Others who live in hard water areas may find that they need or want to soften the water in the entire house, in which case the household softened water can be used. In many cases, cation softened water will produce very good espresso shots; just ask the Italians for whom this is normal. And the tiny amount of sodium one would ingest in their espresso shots is not worth worrying about
Ken Fox wrote:Have you actually measured the output of your Zaffiro with a Scace and datalogger, in order to be able to make this statement? If you have done this, have you done it enough times over a long enough period of time to be sure that what you got once is repeatable?
Marshall wrote:Even our beloved Brooklyn friend, Fortune Elkins, who has the benefit of some of the best tap water in the U.S. uses bottled water (Volvic, I believe). I'm also pretty sure that home delivery of bottled water is available in most, if not all, metropolitan areas of the country (I've had clients in the business for years).
Marshall wrote:I could be wrong (I often am), but I believe just about every serious coffee bar in the country uses water treatment. This is not just to minimize descaling routines, but for flavor balance. Cirqua Water Systems may be based in Southern California, but they have coffee shop customers all over the country.
