Now, the question is, what machine do I buy to go with it?
Here's the profile of what I drink...
Typically, 1 or 2 espressos daily. I'm the only coffee drinker in the house. I tend to (today) make a kinda "diluted" espresso; a double but with a bit more water (stretched?), perhaps 3-4oz total.
I do not do lattes and cappas, as I have mild Lactose issues - so for me, I will not be making milk drinks. I might make them for a girlfriend or if entertaining, but since I won't be doing them daily, I'm unlikely to ever get real good at the milk side of it - just no reason for me to put in the time to learn it.
On the other hand, the espresso part of things is another matter. I'd love to be able to pull real triples and drink those instead of the "half coffee" garbage that I am forced into with the fairly cruddy machine I have now. (The scary part is that my "half coffee" shots are in fact better than most of them from the local green franchise! Those guys are truly scary; half of what I buy there I classify as truly undrinkable.)
I tend to buy my beans from a place that roasts Hawaiian stuff, usually single-source (Kona), although I also drink some decaf (otherwise after the 4th or 5th cup I'm pinging and jittering REAL bad) - but again, the decaf is typically a hawaiian coffee. (Maui Coffee Roasters). They roast and ship. I do not have a local source for fresh-roasted beans, so I'm forced to have it sent from somewhere. Their coffee has been consistent and good for the last 5+ years.
If I buy a machine that is kept on, it also becomes a convenient source for hot water, which is useful. My kid likes the "cup of noodles" stuff and being able to pull the water from the machine without having to nuke a pyrex measuring cup full is a nice side benefit. Ditto if a guest would like a tea or something.
I'm not so much budget limited as I am not wanting to buy twice. That would REALLY get me upset. The M4 is likely a "you'll die before you wear it out" type of purchase, and I want the machine to be more or less the same sort of thing. 10 years is my minimum expected service life before I want to be shopping again.
Finally, I have severe hard water issues here. If I buy a plumbed in machine I have to drill a solid-surface countertop (not hard), find the fittings to make the hole look nice (not terribly hard either) and then deal with, probably, an RO cartridge + ion donation filter (not so nice and big - there goes one side of my under-sink storage area as those are typically 3 10" long cartridges between the RO and donation system!) Pour-over means bottled water. If I try to run straight tap water I'll be trashing the boiler for sure - my hot water heater produces calcium ROCKS within a couple of years of installation (water hardness is simply off the scale.)
Oh, and finally, I want something that will run on a 15A circuit. Adding a dedicated 20A is a non-starter primarily due to the fact that the breaker panel it would have to come from is full which makes for BIG BUCKS to do that retrofit.
I've narrowed things down to:
1. Alexia. Single boiler, no HX. How's temperature stability on that machine and how easy is to adjust brew temperature? Are you just plain screwed with that (since there's no HX, you can surf temperatures) unless you're willing to PID the thing?
2. Vetrano. Plumb in, HX, rotary. Quiet, nice, insulated boiler, temperature surf required but allows shot temperature control this way. Better valves (steam and water) than the Alexia.
3. S1 VII. Plumb in, double boiler, rotary. Quiet, nice, can disable steam boiler overnight but leave brew on (no wait in the morning but much less energy consumption and yet you can get a tea or hot soup water instantly), PIDed from the factory, 7-day timer can be ordered with the machine. Chris is currently out but more will be coming in within the week.
Am I missing one of the choices I should be considering?
(FWIW I also put this over at Geek but their web site is awfully slow and I've since bought the grinder... figured I'd see what the opinions looked like over here)
