Thanks, KDM
erics wrote:To the best of my knowledge, all Silvia's are fitted with the Ulka EP5 pump and the flow characteristics of that pump are as shown below:
I realize that the definition of a double-shot is a debatable (and very rightly so) subject in and by itself but, strictly for discussion purposes, let's assume that a double-shot puts 60 ml of espresso (including crema) in a cup in 25 seconds when the puck is subjected to a pressure of 9.0 bar. If you look at the graph of the Ulka pump performance, you'll see that it is capable of fufilling this requirement and when it does so, there will be flow in the OPV line back to the tank. Naturally there are tolerances associated with pump manufacturing and, after so many years of operation (even in a home environment), some pumps are a little more tired than others. However, the solid line does represent a production average and the dashed lines represent min/max allowable to get the pump out the door.
duke-one wrote:...the gauge read full pressure while the pump was running without the filter basket in place, shouldn't it be lower without the resistance of the coffee and filter?
duke-one wrote:While it was off I turned on the water and got a steady slow flow if that means anything.
duke-one wrote:I'm just about ready to call for a service call from Mr. Espresso where I bought the machine. On the other hand it seams to be making good coffee so...............
