malachi wrote:I'd love to push ahead with organizing a research project for the SCAA show.
I've got one person interested - anyone else?
I'm not going to Charlotte, so my interest doesn't really matter. As Jim posted previously, we'll redo our prior Juniors (vibe vs. rotary) study in a grander fashion, before the SCAA convention.
The more I think about this whole topic the more I think the likelihood of showing a difference in such a study is vanishingly small, and that if the finer coffee establishment has the resources to do a large "pump study," that those resources could be better devoted to something else.
Think about this rationally: why the hell should a machine make different quality espresso based solely on the type of pump, vibe vs. rotary, contained within it? You could almost convince yourself that it should (I was personally convinced myself) in the case of an unregulated vibe pump vs. a rotary, but once you regulate the vibe pump with an overpressure valve, there is no rational reason to assume that the difference would be detectable. Does it really matter how the nearly constant 9bar of pressure are produced? Does the puck care?
Let's take this discussion to a more practical level; all things being equal, almost anyone who could have a rotary pump rather than a vibe pump in their machine would choose to do so. Afterall, vibe pumps are unpleasant to be around, because they make a racket and what's more, they vibrate.
The small incremental cost of the pump itself is not going to deter someone who is prepared to spend enough to buy a competent home espresso setup. I think we will see rotary pumps moving more and more into the home espresso machine market, albeit most probably just above the Silvia level of machine.
Commercial machines are now overwhelmingly run by rotary pumps; I don't see any study as likely to reverse this reality. I don't think that anyone rationally thinks that a vibe vs. rotary study will show conclusively that vibe pumps are better, so that likelihood can be dispensed with and we are not going to see vibe pumps regaining the commercial market. If one is studying home machines, unless you have a nearly perfect comparison such as my two juniors or some type of external pump situation, other factors differentiating the machines may well overwhelm any differences attributable solely to pump type, so the comparison will likely be meaningless. The reason that I say it would be meaningless is that few people are going to decide to buy one machine or another based SOLELY on what type of pump is inside it; they are buying a "package" that contains a certain type of pump.
Speaking only for myself, I think that if there is an effort to marshall enough resources and talent to test something, there are other things to test that are more potentially meaningful; for example, tight temperature control and other temperature manipulations that can be done, intrashot.
ken
