by dsc on Fri May 16, 2008 7:41 am
Hello again,
yesterday my NPF arrived and I decided to try it out using two of the dosing methods that proved quite effective:
- single light tamp, dose 15g, WDT with my needle tool
- split dose/tamp, light tamp, dose 15g
Temps somewhere in the range 88*C-90*C, Malabar Monsoon was used, although it's a bit past it's prime time (will be more than two weeks now). I used the same basket as before, the ridgeless double from Synesso. I did everything the same and the only thing that changed was the PF. The effect was, well quite a surprise to say the least. It was a perfect pour, even, no donuts, squirts, dancing streams or anything. Just a nice thin stream in the middle, with a bit of blonding near the end, but nothing major as I would've thought. I tried another shot and it also went very good. Tried another one today, a slight ristretto and again a nice even pour. Tastewise, the first two shots were quite nice, the ristretto was a bit too harsh, although this was probably caused by the fact that MM might not like to be a ristretto.
Now the main question is, what the hell is going on? I mean changing a PF shouldn't really affect anything, or should it? The only other thing that changed was the gasket, which went from 8.5mm to 8.0mm to get the NPF to lock in the group. This means there's 0.5mm less head space and I can see it in the pucks as they all have shower screen impressions after extractions. I'm still surprised as I used to get soggy pucks and now with 0.5mm I'm getting a full screen impression?
Will upload some vids today and update this topic with some links.
Cheers,
dsc.
