malachi wrote:I need another tasting volunteer.
Andy,
Do YOU need any volunteers????
Keith
malachi wrote:Day 11:
So, why is the GS3 worth $4500?
Abe Carmeli wrote:1) Can you program the preinfusion length, if so, what are the limits? 0.6 secs is very short for preinfusion, as compared to a vibe on most E61 machines doing 4-5 secs.
espressobsessed wrote:(for mike's benefit) in other words, you grinded differently at each temp to compensate for extraction rates which naturally change at different temps.
(emphasis mine)malachi wrote:Nick nick nick...
Unless someone has done a poor job with their cupping and sourcing, the odds of you having discernable variance in a group of shots of an SO espresso are really low (statistically relevant, yes, but very low).
espressobsessed wrote:Chris, have you messed around with different temps at same extraction ratios?
Nick wrote:That's where I'm trying to imagine the espresso grounds having a conversation among themselves: "Wow! This water is TEMP STABLE baybee!!! I'm loving this 200.2*F... WAIT... it just changed to 200.4*F!!!
HB wrote:gscace wrote:What about all of those other profiles that you haven't measured? Bury the thermocouple 5mm down inside the cake and you'll get a completely different profile. What is the correct profile there?
To give readers a perspective on just how much placement makes a difference, see the chart below:
Cimbali Junior - puck top and bottom temperatures
That's one thing that really drives me batty about temperature discussions. Someone will say temperature X is THEE correct brew temperature for espresso Y. In reality the coffee is subjected to a wide spectrum of temperatures throughout the extraction.
malachi wrote:Using a semi-blueprinted Cimbali Junior.
HB wrote:On one hand, I want to accept what Chris' taste says at face value without the urge to correlate with measurements. On the other hand, I ask myself: This 0.2F degree difference, would it also exist at the mid-point of the puck with such precision, not just the surface? I doubt it; things in nature are rarely so conveniently uniform.
skyryders90 wrote:Just an interjection - I got the official OK from the wife to get a GS3!! WooHoo!!
I now take you back to the discussion of minutia. :wink:
malachi wrote:Heh... it's "I started the process of re-working the grinder so that everything was as if it were blueprinted (perfectly built out according to blueprint) but ran out of time and had to re-assemble and work on the grinder for the review".
malachi wrote:It wasn't built that cleanly (IMHO).
There are some alignment issues, some fit and finish issues.
I just want to make it as good as it can be.
So no real modifications, just some fixes to get it to "as designed."
